Knock Off Siemens Deka Fake Injectors
Sub-forum for all Tmoss porting discussions
Tmoss Write Ups
Unread postby decipha » Fri Apr 26, 2019 9:53 pm
This has become quite an epidemic so figured its definitely worthy of a sticky
The following vendors are VERIFIED to sell knock off fake china made siemens deka injectors:
TrePerformance
FIC
Amazon
eBay
The siemens deka line of injectors are the most copied injectors on the market. Unfortunately there is no possible way to verify them visually since the knock offs use actual genuine siemens deka housings. Only way to know is to cut them open and inspect the internals or simply try to run them. The knock offs have extremely poor intolerable transient fuel delays that cannot be mistaken. The genuine siemens injectors do not have those issues.
The only vendor for siemens deka injectors in the US is poweraddersolutions that I know of. If anyone knows of another genuine vendor please do post here.
Re: Knock Off Siemens Deka Fake Injectors
Unread postby Turbo95stang » Sun Apr 28, 2019 5:40 pm
I got my set from Ballenger Motorsports the web site is bmotorsports.com there good injectors I paid $450
Turbo95stang
+Premium Plus Member
Vehicle Information: 95 mustang 5.0 with hellion fox turbo kit 76mil Turbonetics turbo jgs wastegate 50mil tail bov and gt40p heads with trick flow upgraded valve springs,93 cobra upper,lower intake,3in pro m maf ,80lb seimen deka injectors,PRO M fuel pump hanger 8an feed 6an return,Glen performance fuel rail,aeromotive remote regulator with BBK pressure gauge ,snow performance stage 3 meth kit,70 mil throttle body,sailor Bob strategy, quarterhorse tuned by Michael Decipha
wbo2-MTX-L
Unread postby fernando_221 » Fri Jun 14, 2019 12:13 pm
I also got my set o 60lbs Siemens Deka at Ballenger Motorsports and it's running great.
fernando_221
Vehicle Information: Ford Focus Turbocharged tuned with SCT Advantage III, WNCDAQ4 strategy
Unread postby Mustang408 » Wed Aug 21, 2019 9:53 am
What injector information did you use in your tune?
Did you start by setting fuel pressure to 43.5 psi?
Mustang408
User
Vehicle Information: 88 Mustang GT-302, AFR 165, Cobra Intake, Custom Cam .565/.535 LS 109*, 65mm TB, 70mm MAF from 92 Crown Vic, 1.6 RR, FRPP 30# EV1, Shorties 2-1/2 full exhaust, T5, 3.55, A9L, QH, BE, EA, AFX/NGK WB-O2, Data-Q
Unread postby decipha » Wed Aug 21, 2019 12:04 pm
its on the homepage under reference
Return to TMoss Porting
