Porting the 5.8 GT40 lowerr
Sub-forum for all Tmoss porting discussions
Tmoss Write Ups
Unread postby PRHutch67 » Sun Oct 04, 2015 4:20 pm
Have you ever done any porting/testing on the GT40 5.8 liter lower? I'm planning a street build 408 and would like to use the GT40 setup from the Lightning motor. I opened up the upper intake and radiused the entries into the runner tubes. The lower already seems pretty generous but porting it seems like it may help due to the extra cubes. I just wanted your input on the matter. Thanks!
PRHutch67
Vehicle Information: 91 Mustang LX 5.0 Ported GT40p heads. GT40 tubular intake. Lunati cam with .500 lift on intake, .512 exh.
Re: Porting the 5.8 GT40 lowerr
Unread postby Tmoss » Sun Oct 04, 2015 8:55 pm
The Lightning lower flows about 275 cfm stock and once ported to a 1262 size port, it will flow over 300 cfm. So, it is the Lightning lower that is the big choke point at about 260 cfm. On a 408, I'd suggest running it with a GT40 style box upper if you want more power, like the Cartech/Downs or Comp Polymer to let the cubes breath better.
Tmoss
Aerodynamic Engineer
Vehicle Information: .
Unread postby PRHutch67 » Mon Oct 05, 2015 3:40 pm
Thanks for getting back to me so quickly! I've been reading your stuff for years and I really appreciate you taking the time! Am I right in gathering that the UPPER is the choke point at 260 cfm, not the lower? I'll definitely look into those box uppers. Since I'm still in the acquisition phase I'll just ask. Is there a single manifold that you'd recommend for a street driven 408?
PRHutch67
Unread postby StangD » Mon Oct 05, 2015 4:00 pm
No, the lower is the chokepoint, which is the case with most Ford intakes. Have Tom port it if you really want to use the intake. He did my last combo and it worked very well.
94 Mustang GT-T5-347(Fordstrokers DIY)-TF190s,FTI Cam,Ported Victor EFI,42s-LMAF,85MM TB-Nitrous-Suspension mods and DRs.
CBAZA-TM40
12.1 @119.50 NA
Pulling baby wheelies and breakin stuff.
StangD
Supporting Member 25
Vehicle Information: 94 Mustang GT T5 CBAZA TM40
347 TF190-Victor EFI-LMAF- 85MM TB- 42s,4.10s-DRs
Unread postby PRHutch67 » Mon Oct 05, 2015 4:15 pm
Then I'm still a little confused. If the stock lower can be ported to 300 cfm, then where is the 260 cfm restriction coming from?
PRHutch67
Unread postby StangD » Mon Oct 05, 2015 4:26 pm
It must be ported to flow more than 260. The 300cfm flow is for the upper is how Tom's post reads to me. I'm sure he knows about what the lower can be ported to as well.
CBAZA-TM40
12.1 @119.50 NA
StangD
Unread postby PRHutch67 » Mon Oct 05, 2015 4:35 pm
Porting a gt40 tubular upper sounds like an interesting trick.
PRHutch67
Unread postby red5.0fogger » Mon Oct 05, 2015 4:44 pm
Lol ya the tubular is run wat cha brung
Premium Member
Unread postby PRHutch67 » Mon Oct 05, 2015 4:57 pm
Yup. My take on his post is this. The lower flows 275 cfm stock and can be opened up to 300 cfm because there's enough material for porting. The upper on the other hand is limited by the diameter of the tubular runners and can't really be ported. I did cut open the upper and radius the entry into the runners but on a 408 that's only going to be a band-aid. I think that's why tmoss recommended the box upper.
PRHutch67
Unread postby Tmoss » Mon Oct 05, 2015 5:33 pm
Yes, the length and limited cross section of all 3 of the GT40 style uppers is the choke point on bigger engines, the 9.2 deck Lightning 351W lower is a GREAT piece, far better than the 8.2 deck model. If hood clearance is not an issue, I like the TFS-R Box on larger cubes. The EFI Super Vic is also a good choice but has an impact on inlet hardware selection. Next, maybe a Victor EFI.
Tmoss
Unread postby PRHutch67 » Mon Oct 05, 2015 6:03 pm
Thanks again! How much extra clearance does the TFS box r require? Could i get away with a 2 inch cowl?
PRHutch67
Unread postby StangD » Mon Oct 05, 2015 6:35 pm
PRHutch67 wrote:Porting a gt40 tubular upper sounds like an interesting trick.
I suppose it has trouble standing up on it's own fairly rapidly. :) And sorry for my misunderstanding. Didn't realize you were talking about a tubular upper.
CBAZA-TM40
12.1 @119.50 NA
StangD
Unread postby PRHutch67 » Mon Oct 05, 2015 6:48 pm
No worries stangD. I appreciate anybody who's willing to help!
PRHutch67
Return to TMoss Porting
cron
