94 MUSTANG TUNING
MS tuning, support, and discussions
94 MUSTANG TUNING
Unread postby Mustang_Kid » Wed Jul 04, 2018 8:18 am
I WAS WONDERING IF SOMEONE COULD HELP ME WITH A BASE TUNE FOR MY MUSTANG.
Mustang_Kid
Vehicle Information: 1994 MUSTANG GT. 347 SUPERCHARGED, 10 PSI OF BOOST. 80LB INJECTORS WITH A 80MM MASS AIR FOXBODY SETUP. HAS WORLD SR HEADS AND A TRICK FLOW TRACK HEAT UPPER AND LOWER INTAKE. C4 TRANS, STOCK REAR END. MEGA SQUIRT ECU.
Re: 94 MUSTANG TUNING
Unread postby decipha » Wed Jul 04, 2018 11:27 am
post your project folder and copy and paste the vehicle info sheet
Unread postby Mustang_Kid » Wed Jul 04, 2018 12:29 pm
1994 MUSTANG GT. 347 SUPERCHARGED, 10 PSI OF BOOST. 80LB INJECTORS WITH A 80MM MASS AIR FOXBODY SETUP. HAS WORLD SR HEADS AND A TRICK FLOW TRACK HEAT UPPER AND LOWER INTAKE. C4 TRANS, STOCK REAR END. MEGA SQUIRT ECU. PROJECT FOLDER?
Mustang_Kid
Unread postby decipha » Wed Jul 04, 2018 12:43 pm
yea the project folder is the tune for MS
no need tho really thats a pretty simple setup
80lb data is on the homepage
shoot 28 degrees to it up top at 0 boost and 20 deg at 10 lbs
then simply dial in the maf / fuel and your good to go
Unread postby Mustang_Kid » Wed Jul 04, 2018 12:58 pm
OK THANKS BUT IM NEW TO THIS AND HAVE NO CLUE HOW TO DO IT. LIKE 28 DERESS OF TIMING UP TILL 0 BOOST AND 20 AT 10 POUNDS. IM NOT SURE WHAT YOU EXACTLY MEAN?
Mustang_Kid
Unread postby decipha » Wed Jul 04, 2018 1:04 pm
in that case you prob want to get someone to tune it for you
do u have a running tune in it now?
Unread postby Mustang_Kid » Wed Jul 04, 2018 1:06 pm
IT RUNS RIGHT NOW, BIT THE IDLE IS ALL OVER THE PLACE
Mustang_Kid
Return to MegaSquirt
