Missing Information
Support forum for software related issues
BE / EA, Caledit / Calcon, TunerPro
Missing Information
Unread postby brewster » Tue Oct 06, 2020 4:53 pm
I bench flashed an A9L EEC-IV with a Moates Quarter Horse at my desk top after setting up a base tune for it using A9L2 and following the instructions in the getting started write up. Installed in the car and it flashed right up.
Problem is I recently bought a new lap top ( HP ENVY) and I set up TP and all the stuff I did on a previous laptop, so I took the new lap top out to the car and tried to read the current .bin to TP from the emulator to start logging and calibrating and it comes out all jumbled. What am I doing wrong, Pic attached.
brewster
Premium Member
Vehicle Information: 1992 fox A9L2 GUFX 347 10.5:1, AFR 165cc, Tremec TKO600, 373, OEM Slot Maf in 3.5" tube, Long tube headers, Lu34A injectors
Re: Missing Information
Unread postby decipha » Tue Oct 06, 2020 5:05 pm
you cant flash the eec 4
flashing is writing the ecu memory over obd2
thats obviously not a tune file you read your qh battery must be dead
Name: Michael Decipha Ponto
Other Vehicle(s): Others:
06 Chrysler 300 AWD - Sharifa
Unread postby brewster » Tue Oct 06, 2020 6:23 pm
I downloaded the .bin to the QH from my desktop where I set up the base file with TP using A9L2, Then installed into the EEC and installed them into the car. Car starts and runs good so I figured I could then use my new lap top which I set up and just read the file and carry on from there. QH is also brand new with brand new battery.
Same issue with reading my other fox with this laptop, same jumbled read out and that's a new QH from Moates as well.
brewster
Premium Member
Unread postby brewster » Tue Oct 06, 2020 6:26 pm
Start up .bin used
brewster
Premium Member
Unread postby motorhead1991 » Wed Oct 07, 2020 4:24 am
I've never had luck writing the QH without the ECU installed and power on. In fact, I have it on video that it can corrupt the tune.
Key off corruption
motorhead1991
Other Vehicle(s): Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Unread postby decipha » Wed Oct 07, 2020 4:50 am
Interesting I've never wrote a tune with the key on before lol
I think I know whats going on, most likely the bin is pushed over 1 byte due to needing E001 as the bin size from an issue with one of my patches in GUFX.
Unread postby 034v » Wed Oct 07, 2020 6:36 am
decipha wrote:Interesting I've never wrote a tune with the key on before lol
I have noticed that before too.
So what addresses would you read say if you read out a 56k with a QH? I have seen them range from 002000-00FFFF to 000000-00DFFF
Both were corrupted. One XDF was E001/-2000 and the other was E000/-2000. Same results..
Dead battery you think?
Created the TPRT XDF's below in my spare time. More to come as time allows. Let me know if you need one.
1996 Lincoln Mark VIII CDBA4
96-97 Ford Car CDAN4
97-98 Lincoln Mark VIII CMBA0/CMAI3/6/7/9
93-95 Lincoln Mark VIII CZAJL
87-92 Lincoln Mark VII SFI-SD3
034v
Vehicle Information: 1996 Lincoln Mark VIII, TPRT Tuning with my own XDF
Other Vehicle(s): 1989 Lincoln Mark VII, TPRT Tuned with my own XDF
Vehicle 3 Information: 2009 Ford F150, Work Horse, SCT Tuned by me
Unread postby brewster » Wed Oct 07, 2020 7:32 am
I sent myself the .bin via email from the desktop and then downloaded it into the QH from the new laptop and now its all correct. Not sure why I'm not able to read out a QH or F3 with the new laptop.
No running change though, the QH took the original file im assuming.
brewster
Premium Member
Unread postby 034v » Wed Oct 07, 2020 7:36 am
brewster wrote:I sent myself the .bin via email from the desktop and then downloaded it into the QH from the new laptop and now its all correct. Not sure why I'm not able to read out a QH or F3 with the new laptop.
Are these the addresses used?
034v
Unread postby decipha » Wed Oct 07, 2020 7:48 am
yeah thats what in the pre tune info
problem is when reading a chip its when reading the tune out from the QH with an eec-iv xdf loaded in tunerpro.
If that is indeed the issue with the e001 file size which isn't correct regardless I'll get fixed in the next tunerpro update.
Unread postby brewster » Wed Oct 07, 2020 8:24 am
Yea I never changed the addressing at all but figured that's what was happening.
brewster
Premium Member
Return to Software Support
