2DCA Definition File (.xdf) for TunerPro
Unread postby Ghiaed1994 » Thu Sep 19, 2019 9:07 pm
All,
Would anyone have access to a complete or near complete 2DCA Definition File (.xdf) for tuner pro? I am currently using the 2DCA_256k_v8.xdf from the Ti Performance Website but it dosnt have all the Scalers, Functions, Tables etc defined. I have changed to 42lb Injectors. The High Slope and Low Slope are available but not the break point, voltage offset etc. There are also a few other items i would like to adjust but are not available.
Any help would be much appreciated.
2DCA_256k_v8 TP V7.xdf
Thanks,
Nathan
Ghiaed1994
Vehicle Information: 1994 Ford Fairmont Ghia - Supercharged 5.0L
Re: 2DCA Definition File (.xdf) for TunerPro
Unread postby Andrew » Fri Sep 20, 2019 12:18 am
Hi Nathan,
I did some of the work on that 2DCA definition. Attached is the most recent I have with more of the functions/scalars mapped. I was having difficulty identifying where all the scalar addresses belonged, so tried GUFB/A9L and has been working fine on my car for the last 3-4 months, an 94 Falcon XR8 Sprint wth 2DCA computer.
Make sure you grab the 256KB bin and definition file for GUFB, and you won't have to worry about missing scalars and functions again.
If you have a trip computer on your car the A9L strategy outputs in what I think is gallons, so the read out on LCD screen will be gallons / 100km. This can be changed in the strategy.
Cheers,
Andrew
Andrew
Vehicle Information: 1994 Ford Falcon XR8 Sprint, 2DCA/A9L, Tuner Pro
Unread postby ranga83 » Sun Sep 22, 2019 2:09 am
As above, i use a9l/gufb for boxcar v8s.
ranga83
Unread postby Ghiaed1994 » Fri Sep 27, 2019 6:18 am
Andrew and Ranga83,
Thank you soooooo much!
Really appreciate it - ready to test this weekend.
Nathan.
Ghiaed1994
Unread postby Ghiaed1994 » Fri Sep 27, 2019 6:43 am
Andrew,
Sorry to be a pest - all i could find was the Attached GUFB.xdf.
Would you have access to both the 256kb bin and definition files? Would you be happy to post?
Thanks,
Nathan
Ghiaed1994
Unread postby decipha » Fri Sep 27, 2019 3:47 pm
the gufx xdf is in the downloads on the homepage
Name: Michael Decipha Ponto
Other Vehicle(s): Others:
06 Chrysler 300 AWD - Sharifa
Unread postby Andrew » Sat Sep 28, 2019 6:13 pm
Nathan,
These are the files I use. From TI Performance website.
Cheers,
Andrew
Andrew
Unread postby decipha » Sun Sep 29, 2019 4:37 am
those are old and missing several hundred parameters
Unread postby Andrew » Tue Oct 01, 2019 1:23 am
I appreciate those files are old.
The chip I use is 256Kb and I assume Nathan has the same.
A little project one day will be to work out how to change the 64Kb files to work with the 256kb chip.
Andrew
Unread postby decipha » Tue Oct 01, 2019 5:41 am
what are you talking about?
Unread postby ranga83 » Tue Oct 01, 2019 10:49 pm
Andrew, the ti chips should be able to use a 64kb bin,
However its quite easy to modify the 64kb xdf to suit a 256kb bin. I have them at home i can send when i get there
ranga83
Unread postby Ghiaed1994 » Sun Oct 20, 2019 2:19 am
[color=#000000]
Andrew wrote:I appreciate those files are old.
Andrew - I am using the Ti Performance Chips.
ranga83 wrote:Andrew, the ti chips should be able to use a 64kb bin,
ranga83 - would you be able to send them across?
There isnt really too much i want to change, i just cant seem to find what im after in the 2DCA files that are available. Essentially i have a supercharged (9psi) 302W. I have the Trickflow Street Burner Manifold, GT40 Heads, B303 Cam, 75mm Throttle Body Bosch 42lb Injectors and have 2 x MAF Options, the 90mm Lightning MAF or the FMS 70mm MAF (The whole point is to upgrade to the 90mm MAF). I am also running Water/Methonal Injection - the Stage 2 Kit from SNOW Performance which runs off Vacuum. 4.11 Diff in the Rear. Upgraded Fuel Pump.
What i need to change i believe:
Injector High Slope.(Available in the 2DCA FIle i Have).
Injector Low Slope.(Available in the 2DCA FIle i Have).
Injector Breakpoint. NOT AVAILABLE.
Injector Offset vs Battery Voltage. NOT AVAILABLE.
Throttle Body Air Flow. NOT AVAILABLE.
Idle In Gear.(Available in the 2DCA FIle i Have).
Idle In Neutral.(Available in the 2DCA FIle i Have).
WOT Spark Advance vs RPM (Available in the 2DCA FIle i Have).
MAF Transfer. (Available in the 2DCA FIle i Have).
Thanks to you all for your help.
Nathan
Ghiaed1994
Unread postby Ghiaed1994 » Sun Oct 20, 2019 2:20 am
Ghiaed1994
