New Engine - high Idle
Tuning specific forum for all of Ford European and Australian specific tuning
Unread postby FAT245 » Tue Nov 19, 2013 6:36 am
I recently put a new motor together and I am struggling to get its idle under 900-1000RPM.
At First I thought it was a Vac Leak but it does not appear to be so.
If the engine was to idle WITHOUT the intake pipe connected, it will idle at its lowest possible to how i have set the TB Stop.
But as soon as I connect the Intake pipe, the RPM's increase and I cannot control them.
Do you have any ideas?
Nathan
FAT245
Vehicle Information: AU Fairlane
342 Windsor | Custom Cam | AFR185 Heads | DiFillipo Pipes | Dual 3" to Diff Dual 2.5 from Diff
Re: New Engine - high Idle
Unread postby decipha » Tue Nov 19, 2013 8:20 am
by intake pipe are you referring to the idle air control valve?
if u unplug the isc youll see real quick if the engine is getting too much air
have u tried backing down the throttle stop?
Unread postby FAT245 » Tue Nov 19, 2013 1:40 pm
I think you guys call it the Power pipe?
MAF to TB.
If i disconnect the ISC there is no change to the idle.
FAT245
Unread postby decipha » Tue Nov 19, 2013 6:20 pm
then you need to close the throttle body stop
regardless the engine is getting too much air
Unread postby FAT245 » Thu Jan 30, 2014 4:59 pm
Turns out the backfire I had, blew out the ISC/IAC.
Replaced it with a new one and it is all sweet.
One thing i am trying to solve now is a real rough idle.
I have 236/242 .568/.570 109LSA Camshaft
When at Idle, the EEC is throwing in fuel and then pulling it out again and my idle timing is going crazy.
I followed your Idle Air 101 and have got the idle smoother but after sitting i traffic for half an hour or more, it fuels up but cruises fine!
Been thinking of trying to force OL at idle?
Nathan
FAT245
Unread postby decipha » Thu Jan 30, 2014 6:41 pm
http://info.efidynotuning.com/tips.htm
yep, check out the tuning tips under reference on the homepage
Unread postby FAT245 » Mon Feb 10, 2014 3:27 pm
At idle, my ECU seems to be referencing my MBT Table and completely ignoring the CT Spark vs RPM Function.
I don't have the ability to log Spark Source either,
FAT245
Unread postby decipha » Mon Feb 10, 2014 5:04 pm
thats how idle is supposed to function
can u verify the closed throttle and idle flags are set?
Unread postby FAT245 » Mon Feb 10, 2014 7:53 pm
I have the ISCFLG Payload, That is at 1 which i believe is RPM Control when it is idling.
Is the other Flag APT?
FAT245
Unread postby decipha » Mon Feb 10, 2014 10:06 pm
Yes
apt= at part throttle
-1=ct
0=pt
1=wot
If the idle flag is set then the closed throttle flag must be as well
Are you trying to change the idle spark?
Unread postby FAT245 » Wed Feb 12, 2014 7:58 am
yes,
I had to change the MBT Table to lower the spark on idle.
Right now I am tryng to get my head around how the ECU Commands Spark at idle.
APT is at -1 and the RPM Control Flag is set at idle
FAT245
Unread postby decipha » Wed Feb 12, 2014 8:14 am
it uses whats called feedback spark
mbt spark is calculated and then the ecu tries to target the feedback spark desired torque which is the scalar SPK_LOAD_RES
a lower value will INCREASE idle spark, and a higher value will DECREASE idle spark,
you can increase this scalar to reduce idle spark, i usually try to stay between 0 and 1.0
the ecu then adds and subtracts spark based on the feedback_spark_gain scalar to control how much it adjusts per loop,
adding timing as rpms are low and pulling as its higher
i guess i should add that to the timing write up
Unread postby FAT245 » Wed Feb 12, 2014 8:15 am
Will those scalars still be viable in an EDIS EEC?
FAT245
Unread postby decipha » Wed Feb 12, 2014 8:17 am
yep
Unread postby FAT245 » Wed Feb 12, 2014 8:36 am
Interesting... Might have to look
FAT245
Return to Ford Euro & Aussie Tuning
