Aussie Ford ECU Catch Codes and Strategies
Unread postby decipha » Tue Dec 19, 2017 7:21 am
General rule of thumb for the Catch Codes are:
First digit is the year of design: 7 = EA, 0 = EB1, 1 = EB2, 2 = EB2, 3 = EB2, 4 = EF, 5 = EF, 6 = EL
Second digit is Ford/Tickford: D = Standard Ford, T = Tickford
Third digit is the model: A = 6cyl manual, B = 6 cyl auto, D = Fairmont or Fairlane, E = Gas of some sorts, J = EL Fairmont Ghia, L = South African Export, N = Police
Fouth digit is the ECU revision.
Catch Codes:
XF
JA - XF Leaded, Auto
JM - XF Leaded, Manual
WA1- XF Uleaded, (unsure if auto or manual)
WA2- XF Uleaded, (unsure if auto or manual)
EA/EB1
7DAC - EA Wagon "S Pack" MPFI, Manual, 3.9
7DBC - EA 3.9 MPFI Auto
7DBD - EA 3spd Auto
7DCD - EA Manual
7DCE - 3.9l CFI 5 speed
7DDE - 1989 EA 3.9 CPI 3spd Auto
0DDA - 3.9 CFI EA
0DDC - Series 2 EA 4 Spd Auto
0DBC - EAII 3.9L MPFI 4Spd Auto...
0DBF - EB Auto 3.9 MPI
EB2/ED
1DAC - XG Manual ute without smartlock
1DCC - 4.0l 4 speed AUTO EB II Pre Smartlock ends 6/92
1DCD - EB 4Spd Auto
1DCE - 1993 EB II Auto, smartlock, 3.23 diff
1DDC - EB XR8 Manual, smartlock
1DEB - EB XR8
1DEC - ED XR8 Autos
1DGA - 1991 EB XR8, 4spd auto, no speed limit
1DHA - 91 NC Fairlane Ghia V8
1DKE - EBII, Smartlock
2DAD - ED XR6 Manual
2DBD - 1993 ED XR6, AUTO, SEDAN
2DCA - EBGT and/or Sprint
2DDA - EBGT and/or Sprint, Auto
2DMA - 1993 XG UTE, AUTO, No Smartlock
3DAC - 1994 ED Falcon, manual,
3DAC - 1994 XG 4.0L Manual. with Smartlock
3DBC - ED GLi/Fairmont Sedan
3DCA - ?
3DDB - XG UTE 6cyl Auto Outback 3.45:1
3DDC - XG UTE 6cyl Auto OutBack 3.45:1
3DEA - Jul 1994 ED XR8, manual, 3.27 diff
3DFA - ED XR8 Auto, Smartlock
3TBA - ED XR6 Auto
3TBB - XG XR6
EF/EL
4DAC - EF Falcon 94' 6cyl Manual
4DAD - EF Falcon 95' 6 cyl Manual Wagon
4DAF - EF Falcon 95' 6 cyl Manual
4DBC - Ford Falcon EF
4DBD - EF Futura 95' Sedan, 4.0, Auto, 3.08
4DBE - EF Futura sedan auto
4DBF - EF Auto
4DBG - Gli/Futura Sedan Auto
4DCC - 1994 EF Fairmont Ghia, 4.0, Auto, 3:23
4DCD - 95 EF Fairmont Wagon,4.0, Auto, 3.23
4DCF - EF Fairmont 4.0L Auto
4DCG - EF Fairmont 4.0L 3.23 auto
4DDF - EF XR8 Manual Sedan 3.23
4DED - Jan 1995 EF Futura, V8, Auto, 3.23
4DEF - 1995 Series 1 NF Fairlane V8 Auto 3.23
4DEG - 1995 EF V8 fairmont auto, 3.23
4DKF - 1996 EF ex-pursuit 5.0 Auto 3:08
4TAA - EF XR6 94' 4.0L Manual 3.45:1
4TAB - EF XR6 94' 4.0L Manual 3.45
4TAC - EF XR6 96' 4.0L Manual Sedan 3.45
4TAD - EF XR6 96' 4.0L Manual 3.45
4TBD - EF Fairmont Ghia Tickford Auto 4.0L
4TDB - EF XR6 Auto.
4TEB - EF GLI DUAL FUEL I6 (Tickford Gas)
4TED - EF GLI DUAL FUEL I6 (Tickford Gas)
4TFA - XR6 Auto
5DAA - 1996 XH ute, manual, smartlock. no central locking.
5DAC - XH Manual Smartlock 3.23:1
5DBA - XH 4.0 Auto
5DBB - May 97 XH series 1 panel van with auto, smartlock and 3.23
5DBF - XH 4.0 Auto
5DCA - EF Series II Fairmont Ghia (Tickford I6HP - 4 Speed Auto - 3.45 LSD 15" Wheels
5TAC - XH XR6 Manual
5TCA - EL Police XR6 (No Speed Limit)
5TFA - EF XR6 Auto (01/03/96)
6DAB - EL Futura I6 Hybrid Manual 3.23:1
6DBA - EL GLI 4.0 AUTO OPTION 20 WITH 3.23:1
6DBB - 1997 EL Fairmont Auto.
6DBD - 1997 EL Auto 3.08 Diff
6DBE - EL Falcon 6cyl Auto
6DDB - EL Fairmont 6 cyl Auto.
6DFC - Jan 1997 EL XR8, manual, 3.23 diff.
6DFD - 1998 series1 XR8 (lo-po).
6DJA - 4.0 Tickford, Auto, Fairmont Ghia
6DJB - 4.0 Tickford, Auto, Fairmont Ghia Revision
6DHD - 1997 EL XR8 Auto.
6DLE - 4.0L Auto (South african Export)
6DNB - EL Police 4.0L Auto
6TAC - EL XR6 Manual - 3.45:1
6TAD - EL XR6 Manual - 3.45:1
6TBB - Police Spec EL - 3.23:1
6TBC - EL XR6
6TBD - EL XR6 Auto - Revision D
6TED - EL, Auto, Tickford with GAS (6 cyl)
6TGB - EL Falcon GLI - Tickford GAS ECU revision B, 1996 model
6TGE - EL Falcon GLI - Tickford GAS ECU revision E, 1998 model
6THx = EL GT Manual..
7DYA - XH 4.0 Auto
7DYB - XH 4.0 Auto
AU
WABF - AU Dual Fuel Auto.
WACG - AU Auto Series 1 VCT
WANA - AU Auto
WAKD- AU GHIA SERIES 1.5 VCT (SMARTSHIELD)
WTAB - AU XR6 Manual
WTLB - AU XR6 3.45 Manual - June 99 - Feb 2000
X2CA - AU1 TS50
Y3EC - AU1 XR8 Auto (Adaptive Shift)
Y3DF - AU - 2001 - Auto XR8
Y3EC - AUI XR8 Auto (Adaptive Shift)
12BD - AU2 6 Cyl Auto
12BE - AU2 6CYL AUTO (future)
12ED - AU Auto Police ECU
12MB - AU2 Ute 6 Cyl Manual
12?D - AU Series 3 XR6 Manual ECU
12XB - AU Series 2 xr6 vct auto. (adaptive shift)
12RB - AU series 2 xr8 auto. (adaptive shift)
12QB - AU series 3 xr8 220kw manual.
22CA - AU Series 2/3 XR8 200kw Manual
22DA - AU series 2/3 xr8 200kw auto ute?(adaptive shift)
22NA - AU Series 2/3 xr8 220kw auto / 250kw pursuit xr8 ute
BA
A3AB - BA XR6 auto - 3R23-12A650-AAB
A3HA - BA XR6 Turbo 4spd Auto Sedan - 3R23-12A650-AHA
A3GC - BA XR6 Turbo Manuel Sedan - 3R23-12A650-AGC
A3LA - BA GTP - 3R23-12A650-ALA
A3MA - BA Boss GT Sedan Manual 5speed - 3R23-12A650-AMA
A3XA - BA 2004 Boss XR8 Ute Manual 6spd - 3R23 12A650 AXA
BF
A5GC - BF XR6 Turbo 6spd Manuel Sedan - 5R29-12A650-AGC
A7FA - BF 2008 Typhoon (270Kw) 6spd Auto sedan - 7R29-12A650-AFA (ASU-224)
Information copied from this link
http://www.fordmods.com/ecu-fuel-system ... 30186.html
here is an xls list of catch codes from ti performance
link
https://www.google.com/url?sa=t&rct=j&q ... KXkPjKWwce
and the actual xls in case the one from t I becomes unavailable
Re: Aussie Ford ECU Catch Codes and Strategies
Unread postby ranga83 » Wed Dec 20, 2017 1:50 am
I can get strategy names for each bin when i get a chance if you want
ranga83
Unread postby decipha » Wed Dec 20, 2017 7:41 am
i dont want but others may
Unread postby bmwz3r0 » Wed Apr 18, 2018 6:33 am
Hi im curious if one of you more knowledgeable lads has a base xdf and bin file for a F250 04 Australian 5.4l equivalance is a 2001 F250 5.4 auto. Mlc-496 ecm 1C3A-BA ZUC0 having trouble finding the 2 files anywhere
Model Year Type Litres Part No Strategy Catch Code Hardware
F-SERIES MY01 ANY 5.4L 1C3A-BA MMAH0 ZUC0 MLC-496
F-SERIES MY01 ANY 5.4L 1C3A-BA MMAH0 ZUC0 MLC-496A
bmwz3r0
Vehicle Information: 04 5.4 F250 Australian, 2001 U.S
Unread postby decipha » Wed Apr 18, 2018 7:19 am
no problem, i use mzak0 on all the f250s
youd be looking $650 for a remote tune w/ development
Unread postby bmwz3r0 » Wed Apr 18, 2018 3:47 pm
I have a J3 programmer eec-v reader blank j3. Just can’t pull the tunes
bmwz3r0
Unread postby bmwz3r0 » Wed Apr 18, 2018 6:40 pm
How much for base .xdf and stock bin file emailed decipha?
bmwz3r0
Unread postby decipha » Wed Apr 18, 2018 9:28 pm
i can post a stock file no problem but to create the xdf takes a bunch of time, i have mzak0 most of the way disassembled just never wrote the logging patch and never put am xdf together at that point it only makes sense to write the tune file
Unread postby bmwz3r0 » Wed Apr 18, 2018 9:58 pm
So I’m stuffed? Piggy back system to run it then? From reading it says flashing a different bin to the ecu will stuff it?
bmwz3r0
Unread postby ranga83 » Wed Apr 18, 2018 10:02 pm
Bmwz3r0, where abouts are u located? If down south, i can pull the tune.
ranga83
Unread postby bmwz3r0 » Thu Apr 19, 2018 1:36 am
I’m in Victoria Australia Bendigo
bmwz3r0
Unread postby ranga83 » Thu Apr 19, 2018 3:46 am
Bit far unless you come southeast at all, im down near cranbourne
ranga83
Unread postby bmwz3r0 » Thu Apr 19, 2018 3:48 am
If you can find the xdf I’ll run there :)
bmwz3r0
Unread postby ranga83 » Thu Apr 19, 2018 4:33 am
Wouldnt be the case of finding the xdf. Would be the case of dumpimg the ecu so i can have the bin then see what i can do with disassembly.
Unless decipha wants to share his files he has to see what i can do with them..
ranga83
Unread postby bmwz3r0 » Thu Apr 19, 2018 5:45 am
I’ve read the ecu and got the bins one 64k other is normal
bmwz3r0
Unread postby ranga83 » Thu Apr 19, 2018 7:17 am
64k for an 04 ecu seems off.
ranga83
Unread postby decipha » Fri Apr 20, 2018 3:53 pm
its a 4 bank ecu, so it will be minimum 216k, typically 224k or full size with filler 256k preferred
Unread postby bmwz3r0 » Sat Apr 21, 2018 1:36 am
Yer I thought the file was small as well. Doesn’t matter to much now just going to piggy back with aem spent far to much effort on the ecm
bmwz3r0
cron
