If adding A/C to an engine that did not come factory with A/C, does the EEC-V/EEC-IV need to be changed?
I know there is code that ups the idle when A/C compressor comes on.
Is that code in all EECs? or just ones that came factory with A/C?
Adding A/C to engine
Re: Adding A/C to engine
all of them
you can jusr wire it through the ecu same as stock so it kills it at crank and at wot.
Thanks, perfect!
