Universal ADX - One ADX file to datalog all fords
Re: Universal ADX - One ADX file to datalog all fords
Unread postby decipha » Tue Jan 17, 2017 11:07 pm
ladies and gentlemen, it works!!!!!!
i couldnt get it to connect using 01 had to use 05 same as before, i dont know why but it works as expected, I have 51 payloads making up the universal adx right now which is 102 bytes worth, that leaves 12 more payloads i can setup, i figure might as well fill it. -3 for fuel level, cht, iat2 which i need to add back
ill make a new thread with the list of current payloads ive chosen so we can all discuss it
also ive thought about revamping the bitflags, instead of wasting those addresses and snatching only one bit per word im considering bitmapping out a list of bitflags and addresses to assign per bit at a single byte, that way i get free up all those bytes and log even more bits flags, i figure 3 bytes of bits for 24 flags should suffice, if even that much
im going to chat with craig soon and see what he says about possibly finding an overlap of RAM between all bank ecus, 4 banka shadow down low of ram1 between 20000-2ffff where as single bank goes in upper memory at ram slot 07 which i think falls somewhere in the 22xxx range. ill check with him and see.
Unread postby jsa » Wed Jan 18, 2017 6:35 am
Congrats. Well done.
Cheers
John
EEC-IV GHAJ0 ANTI or COSY
Unread postby decipha » Sun Jan 22, 2017 2:19 pm
thanks
here's the current payload order I have it in
lmk what yall think
<list moved to disassembly write up--->
http://efidynotuning.com/dis.htm#ram
roughly 12 more addresses I can add and if I rewrite the flag code we will have another 5
Unread postby ranga83 » Sun Jan 22, 2017 7:45 pm
Needs mappa and mapope for sd based ecus. Unless you swap load and perload for them?
ranga83
Vehicle Information: 1996 EF Falcon 4.0 inline 6, 4TAD ecu, tunerpro, and moates q/h
Unread postby decipha » Mon Jan 23, 2017 12:00 pm
imaf and pct load would be ideal
sunday i loaded in the 2000 explorer im driving with the reac4 strat and went for a cruise, the logging is only updating at ignition key on, my first thought was that the code isnt being caught in the loop but i highly doubt it since its in the console routine, i went and doubled checked and it appears to be in the main loop
im going to do some testing tonight to see if i can isolate the cause
my second thought was that it was the QH timing out but with a flick of the key she updates, odd indeed imma digg into it
Unread postby decipha » Tue Jan 24, 2017 12:23 am
well i found out why she would only update at initial key on, im kinda embarrased to admit it :roll: but when i put my bank calls in for the multi bank ecu i attempted to do a bank call on a comparison :lol: all fixed now
as soon as i thought about what it was doing i knew it had to be runnig off into la-la land
so as of this instant the first of the 3 steps are functional, the byte swap isnt functioning so figured id knock that out before debugging the bits although i hadnt checked to see if thats functional or not, not that it matters since i intend on compressing it, i thought about it earlier and figured id do a simple *2 incrent on a 3rd counter
here is where she's currently at, disregard the comments if they don't line up I changed it up a bit so they could be off
<updated code posted below>
Unread postby decipha » Tue Jan 24, 2017 11:06 am
i just had another idea, instead of wasting bytes for single byte word polls im thinking about "stacking" bytes together, its as simple as changing the second part to just poll load bytes
digging into it deeper i realize my second and 3rd manipulations wont work unless i poll the FF3A list again to load the actual value being that and read from the offset will return the rom value and not the QH value, a little oversight on my part but easily remidied
Unread postby sailorbob » Tue Jan 24, 2017 11:18 am
You may find that the 8061 doesn't like the ROMBANK instruction and throws an exception or treats the instruction as NOP.
sailorbob
Tuning Extraordinaire
Unread postby decipha » Tue Jan 24, 2017 12:39 pm
my daily is an 8065 right now
well i rewrote it during my lunch break, scribbled it on a napkin lol, ill load her up and see how she does on my way home this evening and post back
Unread postby decipha » Wed Jan 25, 2017 12:02 am
here she is as of right now, something is amiss with the ffff compare at 8xfee7, its corrupting everything after it hits an ffff, I have no idea why, too late to debug her tonight, i'll go over it tomorrow and try to isolate the cause, at first look though its odd indeed, I don't see a direct cause for it
Unread postby sailorbob » Wed Jan 25, 2017 3:56 am
I've not looked too closely at this because I find the listing style not particularly easy to read but here's a couple of items to look at.
At line 0x8FEED you are incrementing 0x34; is this correct? Shouldn't you be adding 2 to the value?
You need to look at your payload addresses as I have a suspicion you are trying to read word size data from odd value addresses.
sailorbob
Unread postby decipha » Wed Jan 25, 2017 7:20 am
you are absolutely correct, im only incrementing once and not twice, that's definitely the cause right there
odd bytes are read out in the 2nd loop
I don't think I have a functioning BL disassembler, I can check when I get a chance
Unread postby decipha » Thu Jan 26, 2017 10:11 pm
cool i rewrote it a touch to clean it up, now shadowing words and odd bytes to specific addressing works perfectly
now i just gotta sort out the bit flags and all will be well in the world
Unread postby decipha » Thu Jan 26, 2017 11:58 pm
well I got it working correctly, now I just gotta put 2 counters in the last step to stack the bit flags
here it is as is as of right now, its 100% but not stacked, this is my original idea functional
A1 50 FF 32 A1 00 C0 34 10 08 A2 33 36 89 FF FF 36 DF 0B 88 36 00 DF 0C A2 36 38 C2 34 38 65 02 00 34 27 E4 10 08 A2 33 36 88 36 00 DF 0D B2 36 38 10 08 A2 33 36 C6 36 38 27 E9 10 08 A2 33 36 88 36 00 DF 1B B2 36 38 10 08 A2 33 34 70 34 38 98 38 00 DF 03 B1 FF 38 B1 C0 35 C6 34 38 27 DB 71 EF 90 F0
I just copy and pasted out of tunerpro just for reference, i'll break it down after I stack the flags
Unread postby decipha » Fri Jan 27, 2017 10:59 pm
alright making some excellent progress, I wrote down some logic for stacking bits, its pretty well knit with some heavy layering. I dont know why but I always have to go against the grain and make things so intricate. Its pretty basic but involved, im going to code it now and try it on my test jewel here. I see a really long night ahead of me still. Im pretty dead set on finishing before i go to bed though.
ill post back if theres anything worth posting
Unread postby decipha » Sat Jan 28, 2017 1:17 am
well that was easy!!
the universal datalogging patch code is now 100% complete, ill be tossing it up tomorrow
Unread postby decipha » Sun Jan 29, 2017 6:12 pm
posted on the homepage, along with a new RZASA xdf with the universal patch code in it, i'll be implementing it on others as time permits
Unread postby SlowBox » Sun Jan 29, 2017 7:36 pm
I didn't realize it was only for SN cars. I was excited.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
Alex's Parts springs
10:1
FMS B303
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby decipha » Sun Jan 29, 2017 10:26 pm
keep your excitement cuz its for the older cars too, i just hadnt verified i can shadow into the lower bus yet since i dont have any eec 4s here to play with
i should have one soon hopefully
Unread postby ranga83 » Mon Jan 30, 2017 2:58 am
decipha wrote:keep your excitement cuz its for the older cars too, i just hadnt verified i can shadow into the lower bus yet since i dont have any eec 4s here to play with
Its the AUS 2 bank (single code bank) eecv's that are going to be the fun ones i think haha.
ranga83
Unread postby decipha » Mon Jan 30, 2017 7:23 am
send me your latest xdf and your current tune and ill toss the patch in there for you tonight
Unread postby ranga83 » Mon Jan 30, 2017 7:46 am
pm sent
ranga83
Unread postby decipha » Sun May 21, 2017 9:23 am
universal adx code has been updated to 0 out unused logging addresses by setting the log word to fffe, note that ffff skips the word to be logged as two bytes in list b
i also but the raminit flag first in the code to make it easier for people to implement logging on other strats as its far less intrusive.
0x6D is the maximum limit of pollable bytes == 108 bytes
thus the listing will be updated and rearranged to better suit eec-iv autos (cbaza)
and the universal adx code will be rewritten again to 0 out unused bits as well so inaccurate flags dont pop up when not logged
will do the same for unlogged bytes as well
im also reducing the default poll list to FExx once i calc the max bytes used for a full implementation which will be on RZASA
Unread postby decipha » Fri Jun 09, 2017 10:57 am
just so everyone knows whats in the works ive added some FFFE clauses to clear unlogged payloads in the universal adx code now. Ive implemented logging on craj0 and cmai9 but hadnt posted them yet.
I restructured the payload order to make it much easier and lighter on the eec-ivs to save from wasting rom.
Ive added an injector fault array for eec-v along with 2 more bytes of stacked bits i have yet to assign. The array gives you a warning indicator on the dash if any of the injectors have a fault, extremely helpful.
Ive been updating the datalogging section in the disassembly write up which as of this moment has the most up to date and hopefully final and last payload order.
Heres the quick link
http://www.efidynotuning.com/dis.htm#ram
if anyone sees any way to make the payloads order more efficient or sees any payloads that should be logged and arent please speak up.
Ive shot mark and craig an email regarding stacking the poll offsets from the QH so I can make numerous polls from the QH incrementing the offset all the while until the complete macro is executed.
If it works out and is fairly straight forward to implement ill be adding more payloads such as all ad count channels and more diagnostics flags. The rear hego voltages and coil faults / misfire counters would be helpful me thinks.
Unread postby jsa » Fri Jun 09, 2017 1:53 pm
BAP & MAP as volts insted of frequency?
Cheers
John
Unread postby decipha » Fri Jun 09, 2017 5:39 pm
yes, on the later eec v bap and map is voltage such as on my marauder
Unread postby Pym » Sun Aug 06, 2017 3:35 pm
Just started this evening to play with quarterhorse. Not so easy to make it work.
I am not doing it in a car (too dangerous for me for the moment), but on an EEC IV just properly powered, without any sensor.
My goal is to prepare the binary and to use at least the universal adx definition, to read some counters to begin.
Thank you Michael for all you documents on this subject and for this adx definition.
I have also tried the patch from the GUFX definition (think it is the last one) on an A9l binary, to see if I can replicate it on my current binary, which already possesses hacks.
The answer is yes, it should work properly at the defined addresses.
But I can not call it from the console routine, because of a direct return just after the last loop.
Any advice on another place to put this call ?
Pym
Hacker
TunerPro on Moates chips
Unread postby decipha » Sun Aug 06, 2017 8:09 pm
thats where u want it
Unread postby Pym » Mon Aug 07, 2017 2:09 am
decipha wrote:thats where u want it
Where it will work, outside a loop and in always executed code. I have found a place for it.
For now I receive values, the famous counters I was expecting, but not where I was expecting them. PW1_15Mhz, EFTRFF & AM.
Now the most interesting part, understanding what are this values and why they are appearing in this place.
Pym
Hacker
Unread postby decipha » Mon Aug 07, 2017 3:25 am
your posts has no relevance to the universal adx, u should start a new thread in the programming and coding section with what your trying to do
Unread postby Pym » Mon Aug 07, 2017 3:48 am
decipha wrote:your posts has no relevance to the universal adx, u should start a new thread in the programming and coding section with what your trying to do
Yes and no. I have 2 choices to obtain the result I am expecting, modify the universal adx (which becomes less universal) or update my registers in patch code.
Now, if you confirm universal adx is able to show all required values, without any modification, I will not touch it at all. That is what I wanted to know.
Pym
Hacker
Unread postby decipha » Fri Feb 02, 2018 5:05 pm
updating the universal adx patch code yet again, this time hopefully for good as i cant foresee any other neccessities in it.
Just like the byte list im going to put the address as the next word in the words list. That way I can shadow ONLY inaccessible word addresses ( <0x400 ) to the designated 1Fxx word address exactly the same as I do the bytes list.
I'm putting all the upper accessible memory directly in to the adx and assigning each strategy its own read. That way it takes the burden off the ecu processor and doesnt slow down at higher processing demands. Most efficient way yet still maintaining university and keeping it simple.
Unread postby decipha » Sat Feb 03, 2018 1:04 am
crunched out the new code!!
<-------Universal ADX Patch Code------->
Subr_UniversalADX():
8 ff74: 71,ef,90 an2b R90,ef raminit_flg = 0; // execute removed code
8 ff77: a1,00,fe,32 ldw R32,fe00 temp7l = fe00; //list of payload operations at 0xFE00
<----Loop Words() til value of 00 00 is reached---->
Shadow_Words(): // shadow word ram addresses first
8 ff7b: 10,00 rbnk 0
8 ff7d: a2,33,36 ldw R36,[R32++] tmp2l = [temp7l++]; // r36 contains RAM address, R32 contains shadow address
8 ff80: 88,36,00 cmpw 0,R36
8 ff83: df,0d je ff92 if (0 != tmp2l) { // end of list check; break to bytes list
8 ff85: a2,36,38 ldw R38,[R36] tmp3l = [tmp2l]; // R38 = RAM_ADDRESS_VALUE
8 ff88: 10,00 rbnk 0
8 ff8a: a2,33,34 ldw R34,[R32++] tmp1l = [temp7l++]; // r34 == shadow address
8 ff8d: c2,34,38 stw R38,[R34] [tmp1l] = tmp3l; // save ram value to shadow address
8 ff90: 27,e9 sjmp ff7b goto ff7b; } // Loop until end of word list is reached
<----Broke Loop, all WORD ram addresses are now shadowed--->
Shadow_Bytes(): // bytes for odd addressed ram values
8 ff92: 10,00 rbnk 0
8 ff94: a2,33,36 ldw R36,[R32++] tmp2l = [temp7l++]; // R36== ram address; R32== shadow address
8 ff97: 88,36,00 cmpw 0,R36 // check if end of list; break to shadow bits
8 ff9a: df,0d je ffa9 if (0 != tmp2l) {
8 ff9c: b2,36,38 ldb R38,[R36] tmp3l = [tmp2l]; // R38 = RAM_VALUE of [odd byte]
8 ff9f: 10,00 rbnk 0
8 ffa1: a2,33,34 ldw R34,[R32++] tmp1l = [temp7l++]; // R34 == shadow address
8 ffa4: c6,34,38 stb R38,[R34] [tmp1l] = tmp3l; // shadow addy == ram value
8 ffa7: 27,e9 sjmp ff92 goto ff92; } // loop til end of byte list
<----Broke Loop, all byte ram addresses are now shadowed--->
Setup_New_Stack_Byte(): // done once for every stacked byte
8 ffa9: 01,30 clrw R30 temp6l = 0; // r30 offset to save to 0x1F_[R30]; doubles as next flag
8 ffab: 01,40 clrw R40 tmp7l = 0; // r40 byte thats stacking bit flags
8 ffad: b1,01,42 ldb R42,1 tmp8l = 1; // r42 current bit position
Shadow_Bits(): // stack bits to universalize flag addressing
8 ffb0: 10,00 rbnk 0
8 ffb2: a2,33,36 ldw R36,[R32++] tmp2l = [temp7l++]; // R36=ram address; R32 == bit position and XX offset (1FXX)
8 ffb5: 88,36,00 cmpw 0,R36
8 ffb8: df,38 je fff2 if (0 == tmp2l) goto fff2; // check if end of list; break to end
8 ffba: 89,fe,ff,36 cmpw R36,fffe // fffe value means to skip that bit position
8 ffbe: df,26 je ffe6 if (tmp2l == fffe) goto ffe6;
8 ffc0: b2,36,38 ldb R38,[R36] tmp3l = [tmp2l]; // R38 = bitmask_ram_value;
8 ffc3: 10,00 rbnk 0
8 ffc5: a2,33,34 ldw R34,[R32++] tmp1l = [temp7l++]; // R34 = bit position,offset <--- operational code
8 ffc8: 99,00,30 cmpb R30,0
8 ffcb: df,0b je ffd8 if (temp6l != 0) { // check if new shadow stack byte
8 ffcd: 98,35,30 cmpb R30,R35
8 ffd0: df,06 je ffd8 if (temp6l != tmp1h) { // if new bitmask address (doesn't match) current then go save current b
itmask
8 ffd2: 69,04,00,32 sb2w R32,4 temp7l -= 4; // go back up the operations list to find the shadow address
8 ffd6: 20,1a sjmp fff2 goto fff2; } } // end of current bitmask byte, go save current stacked byte
<----New Byte to Stack Bitmasks---->
8 ffd8: b0,35,30 ldb R30,R35 temp6l = tmp1h; // R30 == new shadow address
8 ffdb: 70,34,38 an2b R38,R34 tmp3l &= tmp1l; // check if ram bitmask is set
8 ffde: 98,38,00 cmpb 0,R38
8 ffe1: df,05 je ffe8 if (0 == tmp3l) goto ffe8; // if ram bit is not jump to skip enabling stacked bit;
8 ffe3: 90,42,40 orb R40,R42 tmp7l |= tmp8l; // enable stacked bitmask
8 ffe6: 01,38 clrw R38 tmp3l = 0; // clear test flag for next loop; or set unlogged value to 0; or "skip"
8 ffe8: 99,80,42 cmpb R42,80 // check if at bit7 == last position of stacked byte
8 ffeb: df,05 je fff2 if (tmp8l != 80) { // if end go save new stacked byte of bitflags
8 ffed: 7d,02,42 ml2b R42,2 tmp8l *= 2; // increment to next bit, bit shift <<
8 fff0: 27,be sjmp ffb0 goto ffb0; } // loop to do next bitmask position check
8 fff2: 99,00,30 cmpb R30,0
8 fff5: df,08 je ffff if (temp6l != 0) { // break to end; else check to see if a current bitmask is in progress (
next flag)
8 fff7: b1,1f,31 ldb R31,1f temp6h = 1f; // 0x1F is always the shadows address range
<----NOW is LATER, save the new flag value---->
8 fffa: c6,30,40 stb R40,[R30] [temp6l] = tmp7l; // save stacked byte to shadow bitmasked byte
8 fffd: 27,aa sjmp ffa9 goto ffa9; } // reset bitmasks temporary variables to do next stacked byte
Sub382:
8 ffff: f0 ret return; // fin!
don't mind the comments as they may not line up correctly most should be right though
tested it on the master rzasa and all works well
I'll post it up tomorrow fidna hit the sheets
this took the shadowed words down from 55 to 12, and bytes from over 15 to only 3, significantly freeing up the processor
Unread postby decipha » Sun Feb 04, 2018 12:34 pm
So I was taking a shower this morn and in my relaxation I realized that its pointless to shadow the lower registers to declared addressess in the 1Fxx range. Its useless and just slows down the processor. Since the adx is pulling in the upper addresses from all over memory having a simple C000 or D00 offset for lower memory is a no brainer. And it doesnt make sense to have two separate polls for words and bytes. Since its not going to declared addresses just delete the second byte poll and poll in bytes as words. Then just pull the value needed lsb/msb in the adx.
So it would appear after the last year and change we have come full circle. Excluding the stacked bitmasks which is probably the most important part of the patch code.
anywho, I'll revamp it yet again on rzasa and post it when done. Hopefully this reduces the patch another 20 or so bytes and speeds up the processor a bit more.
Unread postby decipha » Sun Feb 04, 2018 2:17 pm
nice, freed up 26 bytes
Unread postby Pym » Tue Feb 20, 2018 1:29 pm
Thanks,
I will update my binaries to test this version, but I am still waiting for a better weather to run related cars (Quarterhorse batteries will be dead each time, if it continues like this).
Pym
Hacker
Previous
