1999 f150 read &write
Unread postby gj187222 » Sat Mar 23, 2019 8:01 pm
i would like to know what software and hardware i need to get a 1999 f150 ecu to run efi and coil near plug on a sbf with a 4r70w.
gj187222
User
Vehicle Information: wrecked 2007 mustang gt 5 speed
Vehicle 2 Information: 1999 f150 5.4 auto
Vehicle 3 Information: 1966 f100 289 with aod the engine was build by me in 1986 wornout 4 water pumps 3 fuel pumps 1 starter and a dist. and 1 c4 in 280000 miles. also had to replace head gaskets at 148000 miles. engine still runs good but has a lot of blow by. wanting to rebuild it adding comp 274 roller cam,roller rockers with screw in studs, and efi a 4r70w using what i can from the above like the ecu sensors wires ect.
Additional Vehicles: 1965 mustang gt a code 4 speed
Re: 1999 f150 read &write
Unread postby decipha » Sat Mar 23, 2019 8:41 pm
moates quarterhorse and tunerpro
depending on the ecu you have it will be either fbgi0 which was mostly the 01 and up ecu's or cvaf1 for the older ecu's
you have to configure it correctly for your setup see the eec-v swap link on the homepage
Unread postby gj187222 » Sun Mar 24, 2019 7:03 pm
thank you very much i will be getting those . thanks again.
gj187222
User
Return to EEC-V & SN95 Tuning
Users browsing this forum: dleach1407 and 1 guest
