Squishy's custom 2x2 subframe connectors
Forum for getting assistance with mechanical issues and custom fabrications/modifications
Unread postby Squishy » Thu Jun 22, 2017 6:41 pm
Decided it was time for some subframe connectors, decided on 1/8 2x2(as per nhra requirements not that it matters where im at) full length, plate under torque box. Not perfect but I'm happy with them for 90 bucks (like 70 American greenbacks)
They did really limit flex felt through the chassis, the bumps are absorbed by the suspension now instead of through the car, way less rattles car feels way better
Squishy
Supporting Member 35
Vehicle Information: 91 5.0(302) Stock Shortblock, A9l, QuarterHorse, F-303 (4*A), Crane Gold 1.6rr's, Edelbrock Performer 60379 Heads, TrickFlow-R Intake, PMAS-HPX-E 100mm Housing MAF, ACT Sensor Mounted In Discharge Tube Before Throttle Body, AFM 4" Power Pipe ,SD 80lb Injectors, Stock FPR@39PSI, GSS 340(255lph High Pressure) Fuel Pump, 70mm ThrottleBody, Vortech V3sci 10-rib 8" Crank 3.33 Blower Pulley, Vortech Mondo BPV, NX/Snow Stage 1 Meth Kit - 625ml/min Nozzle, 1-5/8" BBK Equal Length Headers, 2.5" BBK H-Pipe, 2.5" Flowmaster Origional 40 Cat Back, Taurus 2 Speed Fan, No Smog Pump. No EGR. T-56 Magnum (Close Ratio)
*WBo2-C*
Re: Squishy's custom 2x2 subframe connectors
Unread postby SlowBox » Thu Jun 22, 2017 6:54 pm
They look good. Pretty similar to the MM subs I had on my nitrous car.
Reminds me. I need to cut these short subs out of my white car and order some full length ones. After having a car with good ones welded in, I can tell these suck.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby decipha » Fri Jun 23, 2017 4:39 am
yea I got a set on the white 95, they sure do stiffen it up
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Return to Mechanics & Fabrication
