Injector Data
Non-specific forum for discussing hardware issues such as wideband faults, MAF, Injectors, etc..
Re: Injector Data
Unread postby decipha » Mon Feb 19, 2018 1:35 pm
ive never used those 120# injectors, you are aware they cannot be used on a ford ecu without an injector driver correct?
Name: Michael Decipha Ponto
Re: Injector Data
Unread postby Pappacosworth » Sat Jun 09, 2018 3:37 am
Ford GT500 5.8 Trinity injector data, 54 lb nominal value
Low slope 73,99080 lb/h
High slope 56,86920
Breakpoint 0,0000140
minimum pw 0,00045600
offset vs voltage:
6 0,00771498819813132
7 0,00532307894900441
8 0,00293116993270814
9 0,00238036597147584
10 0,00182956305798143
11 0,00154988095164299
12 0,00133582705166191
13 0,0011716129956767
13.5 0,00110780901741236
14 0,00104400503914803
14.5 0,000987946055829525
15 0,000931886024773121
Ford GT500 5.4 injector values 47 lb nominal value
Low slope 64.54513 lb/h
High slope 48.27437
minimum pw 0.00044800
offset vs voltage:
0.00479200016707182
0.00350999995134771
0.00222899997606874
0.00186700001358986
0.00150599994231015
0.00129000004380941
0.00112499995157123
0.000985000049695373
0.000929999980144203
0.000875999976415187
0.000829000025987625
0.000782000017352402
Pappacosworth
Fabricator
Re: Injector Data
Unread postby decipha » Sun Jun 10, 2018 7:50 am
should be good to go
Re: Injector Data
Unread postby 289Hilux » Thu Jan 17, 2019 2:47 pm
Looking for the correct data for the Bosch 0 280 155 968 "Green Giants"
The data seem hard to locate. I thought they were a very commonly used in the Ford 5.0L
Cheers,
Cheers 289Hilux! from down under
289Hilux
Vehicle Information: RN85 Hilux
370 Dart SHP Windsor
C4 3spd
EEC IV 2DCA now GUFB-A9L
Quaterhorse
Re: Injector Data
Unread postby decipha » Thu Jan 17, 2019 4:02 pm
on the homepage
Re: Injector Data
Unread postby 289Hilux » Fri Jan 18, 2019 1:05 am
Unless I am looking for the wrong thing I cant see a listing for the Bosch 42Lb
Unless I use the FRPP 42Lb data?
289Hilux
C4 3spd
Quaterhorse
Re: Injector Data
Unread postby decipha » Fri Jan 18, 2019 9:08 am
thats them
Re: Injector Data
Unread postby 289Hilux » Fri Jan 18, 2019 1:40 pm
Cool thanks. I will let know how I get on.
289Hilux
C4 3spd
Quaterhorse
Re: Injector Data
Unread postby motorhead1991 » Sat Jan 19, 2019 9:36 am
I'm running Bosch 0-280-155-831 on my 2.3L, would you like the information I'm using on them? They're a Volvo injector but are high-Z
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Re: Injector Data
Unread postby notched » Fri Mar 22, 2019 10:51 pm
Looking for injector data for Holley 50lb High impedance injectors. I contacted Holley but they would not provide me with any information on a discontinued item. Thanks Brad
notched
User
Vehicle Information: 1989 mustang lx notch
331 ci
vortech supercharger
moates quarterhorse
Re: Injector Data
Unread postby decipha » Sat Mar 23, 2019 1:22 am
hey motorhead do you have actual published data or some that you made yourself? I have my own data for them as well.
either way what values do you have ?
notched... no i do not have any data for those injectors
Re: Injector Data
Unread postby motorhead1991 » Sun Mar 24, 2019 1:52 am
decipha wrote:hey motorhead do you have actual published data or some that you made yourself? I have my own data for them as well.
It's a mix of my experience, a friends and published data. I had to move the slopes a touch on my 2.3 compared to my friends 302 though.
Alosl: 39.15
Ahisl: 31.5
offset vs volts:
15.94    0.69
14.00    0.81
12.00    0.81
11.00    1.09
10.00    1.34
9.00     2.03
7.00     3.09
6.00     3.50
5.50     3.78
0.00     4.09
0.00     4.09
0.00     4.09
Breakpoint:
16.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
0.000   0.0000132397
motorhead1991
Re: Injector Data
Unread postby decipha » Sun Mar 24, 2019 2:31 am
thats quite a bit higher than i would have expected
This is what I came up with at 55psi base fuel pressure
ahisl and alosl the same at 33.7
15.94 0.38
15.00 0.38
14.00 0.41
13.00 0.50
12.00 0.59
11.00 0.88
10.00 1.09
8.00 1.72
6.00 3.31
0.00 3.31
0.00 3.31
0.00 3.31
Re: Injector Data
Unread postby motorhead1991 » Sun Mar 24, 2019 3:08 am
Watching KAMS, the thing seems happy so I just left it. :grin:
motorhead1991
Re: Injector Data
Unread postby Sdinse » Mon Jun 17, 2019 1:37 pm
Has anyone come across any data for the Bosch 0 280 158 193 EV14 injectors as used in the Ford 5.4L Triton engines? So far, what I have been able to find is this:
Flow rates @ 43.5 psi / 3 bar
30.7 lb per hour
231.9 G per min. (N-Heptane)
322.5 cc per min
12 Ohm resistance
Courtesy of Injector Planet
Can anyone verify these specs? I believe the reference to their use in the Coyote engine is wrong, as has been pointed out in other places on the web. One person has put out flow test results showing the flow at 325 cc\min, which is close to the specs above.
What I'd really like to know is the dead time and voltage compensation for these.
Anyone?? :?:
Sdinse
Vehicle Information: 1971 Jaguar E Type V12
MegaSquirt MS3 Pro Speed\Density
Tuner Studio
Vehicle 2 Information: 2004 Ford Thunderbird
SCT
Re: Injector Data
Unread postby Sdinse » Sun Jul 14, 2019 10:46 pm
Bump
ANYONE??
Sdinse
Tuner Studio
SCT
Re: Injector Data
Unread postby decipha » Mon Jul 15, 2019 12:24 am
that is correct those are indeed 30lb injectors
Here is the stock injector data for a 2010 f150 5.4L 3v @ 64psi base fuel pressure - rxge6 strategy dvc0 catch code
Note this is at 64psi of base fuel pressure
39.24 lbs/hr - high slope
44.64 lbs/hr - low slope
0.0000119 breakpoint
voltage offset msec
15.89 0.719
15.00 0.742
14.00 0.852
13.50 0.921
13.00 0.985
12.00 1.139
11.00 1.341
10.00 1.608
9.00 1.950
8.00 2.601
7.00 3.873
6.00 7.633
you can approximate the flow data by multiplying all the above values by 0.785 to estimate for 40psi of base fuel pressure if you had to
Re: Injector Data
Unread postby Sdinse » Sat Jul 27, 2019 1:03 pm
Thank you so much for the data. This will help considerably. I am using these on a Jag V12 running them at 43.5 psi in a flex fuel set up. I guess now I just need to do a bit of math to fine tune my settings. I had no idea that they were run at such a high pressure in their stock setting, especially since I believe most of the applications for these injectors (E series vans, etc.) are normally aspirated.
Sdinse
Tuner Studio
SCT
Re: Injector Data
Unread postby Sdinse » Sat Jul 27, 2019 1:11 pm
Oh, one more thing, what does "rxge6 strategy dvc0 catch code" mean in laymans terms?
Thanks again
Sdinse
Tuner Studio
SCT
Re: Injector Data
Unread postby decipha » Sat Jul 27, 2019 4:25 pm
the strategy is the operating system on the ecu which usually varies by make model and often year
the catch code is the calibration tune file for that strategy
Re: Injector Data
Unread postby Sdinse » Sun Jul 28, 2019 12:31 pm
Ahah! Well, I'm not sure that would mean much to me since I'm using MegaSquirt to run my injection and ignition, though I'd be curious to know more about the calibration tune file. Maybe there is something useful in that. I just don't know what I don't know, but I always like to learn as much as I can.
Confirmation of the flow data and seeing something definitive on the voltage offset is really helpful. Most appreciated.
Sdinse
Tuner Studio
SCT
Re: Injector Data
Unread postby lowranger96 » Tue Sep 17, 2019 5:50 am
https://treperformance.com/i-20608663-t ... ors-4.html
Anyone ever used these or have the data for them?
1996 - 2.5 CP Flattops, Billet Crower 5.2 rods, Stock head bolts, Felpro 1035, Turbo VC, P&P BV Head, 2277 Cam/spring, Custom Log/Tial MVS, HE351, FMIC, FLH2, ID1000s, HPX Blowthrough, Binary Editor, E85
lowranger96
Vehicle Information: 96 ranger 2.3 turbo
Re: Injector Data
Unread postby decipha » Tue Sep 17, 2019 11:10 am
tre has been verified to sell knock off injectors I wouldn't chance buying any from them
Re: Injector Data
Unread postby lowranger96 » Tue Sep 17, 2019 11:49 am
That’s the same thing I told them customer when I found out that’s what he is running. Lol
lowranger96
Re: Injector Data
Unread postby lowranger96 » Wed Sep 18, 2019 4:57 am
How about fuel injector development FID750? Likely similar to Injector dynamic stuff?
lowranger96
Re: Injector Data
Unread postby decipha » Wed Sep 18, 2019 9:02 am
if they are who i think they are then i thought they publish their data have u contacted them?
Re: Injector Data
Unread postby skythunder83 » Mon Oct 14, 2019 10:55 am
So this thing has confused me a lot. I gut this set of Injectors with this number 0280158117 with Ford logo, black with orange ring and 6 spray holes, been told it's from GT500. Can't be sure is it 2007-2012 GT500 or 2013-2014, is it 47, 50, 52,54 or 55 lb and it data should be at 39.15 PSI or 55 PSI.
This type of injectors are everywhere with different data. Attached pictures
skythunder83
Premium Member
Vehicle Information: Fully customized Mustang 2008, power, styles interior and exterior
Vehicle 2 Information: Stock to rock Explorer V6 2006
Re: Injector Data
Unread postby ironmanisanemic » Mon Oct 14, 2019 11:14 am
skythunder83 wrote:So this thing has confused me a lot. I gut this set of Injectors with this number 0280158117 with Ford logo, black with orange ring and 6 spray holes, been told it's from GT500. Can't be sure is it 2007-2012 GT500 or 2013-2014, is it 47, 50, 52,54 or 55 lb and it data should be at 39.15 PSI or 55 PSI.
To me they look like the Ford racing g302 injectors. They publish their data on the Ford racing website.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, FRPP LU34 34LB injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. 4R70W
Re: Injector Data
Unread postby skythunder83 » Mon Oct 14, 2019 11:32 am
But this with orange ring not yellow! And if so, why there is two pressure drop ref? 39.15 and 55? And which should I use?
Sorry for all my questions I tried many data and I'm lost
skythunder83
Premium Member
Re: Injector Data
Unread postby decipha » Mon Oct 14, 2019 11:49 am
use the data for the fuel pressure your running. If you use the 55psi data then you have to set you base fuel pressure to 55psi.
Re: Injector Data
Unread postby skythunder83 » Mon Oct 14, 2019 1:17 pm
Okay clear, so 47 data or 52?
skythunder83
Premium Member
Re: Injector Data
Unread postby ironmanisanemic » Mon Oct 14, 2019 2:03 pm
I would start with the g302 data. None of the other ford racing injectors that I saw had a colored band. Also a few eBay listing also showed orange rings for that series of injectors.
ironmanisanemic
A+ Contributor
Re: Injector Data
Unread postby skythunder83 » Mon Oct 14, 2019 2:18 pm
Sounds good, thx
Another question might sound stupid. How about flow rate high/low multi vs press, breakpoints multi, PW minimum and offset multi vs press?
skythunder83
Premium Member
Re: Injector Data
Unread postby ironmanisanemic » Mon Oct 14, 2019 2:50 pm
skythunder83 wrote:Sounds good, thx
all of that is listed in the specifications listed on the ford racing website for the listed injectors...
https://performanceparts.ford.com/parts/ics/m-9593-g302.pdf
ironmanisanemic
A+ Contributor
Re: Injector Data
Unread postby skythunder83 » Mon Oct 14, 2019 2:53 pm
Stupid me, I have this list already but my mind was stuck here, thx bro
skythunder83
Premium Member
Re: Injector Data
Unread postby sspeedta » Mon Nov 04, 2019 5:18 pm
I'm looking for data on some 280155715 injectors at 43.5 PSI
sspeedta
User
Vehicle Information: 1996 Pontiac TA
0411 ECM
Hp Tuners
Re: Injector Data
Unread postby decipha » Mon Nov 04, 2019 5:23 pm
thats supposed to be the marauder injectors. Info is in the list.
Previous
Return to General Hardware
