I'm new to TPRT and the QH but, as I understand it, I should be able to set the QH to mode 0 and bypass it if I need to use the OBDii port?
If that is true, how do i set the mode for the QH in TunerPro? It would be so much handier than pulling the ECU every time.
Thanks,
Paul
Set QH mode in TunerPro?
- Vehicle Information: 1998 Ford Mustang GT 5 speed box code BAI1, CRAI8
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
Re: Set QH mode in TunerPro?
obd2 port works with tge j3 active you just cant read or write tunes
there is no way for the time being tunerpro doesnt currently support selecting alternate qh modes
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
That explains why I couldn't find it. I was just trying to speed up reading my assorted SCT tunes into TunerPro.
Thanks for clearing it up!
