IAC differences in 03 04 Cobra
Unread postby GT_Rich » Wed Jan 30, 2019 8:09 am
I'm looking for a smaller IAC to remote mount/hide. I currently have a 97 Cobra running CDAN4. The 03 04 Cobra IAC valves are much smaller and it appears they do not use an internal spring on the seat. Do these function they same? Direct swap physically if I change the transfer function?
Thanks,
Rich
GT_Rich
Vehicle Information: 65 Mustang Vert, A9L, Moates QH, Innovate LM-2 WB
302 w/ TF heads, F-cam, ported GT-40 lower/tubular upper, Vortech T-trim s/c, 60 lb/hr inj, Methanol injection, PMAS HPX blow-thru MAF, 400 lph pump.
Vehicle 2 Information: 92 Mustang GT, A9L, Moates QH, Innovate LM-2 WB
302 w/ TF heads, B-cam, ported GT-40 lower/tubular upper, Powerdyne BD-11 s/c, 42 lb/hr inj, 75 mm Pro-M MAF, 255 lph pump.
Vehicle 3 Information: 95 Lightning, ICY1, Moates QH, Innovate LC-1 WB
393 w/ TF heads, custom cam, GT-40 lower/tubular upper, 30 lb/hr inj, speed density. E4OD trans.
Additional Vehicles: 62 Mercury Comet, LLX4, Moates QH
32V 4.6L, IMRC delete, stock rebuild
Re: IAC differences in 03 04 Cobra
Unread postby decipha » Wed Jan 30, 2019 12:42 pm
yep you can swap it no prob, you don't have to worry about changing the transfer unless you plan on actually dialing it in
Unread postby motorhead1991 » Wed Jan 30, 2019 1:40 pm
The cobra ISC works really well on 2.3 Turbos as well, since they're not vented
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85
Unread postby GT_Rich » Wed Jan 30, 2019 9:24 pm
Thanks fellas. I picked up a Motorcraft unit on my way home from work. The compact size is a nice feature! Gets me the space I needed.
I'll change the transfer function. Of course I'm going to dial it in. Who on this forum wouldn't?
GT_Rich
Unread postby decipha » Wed Jan 30, 2019 9:43 pm
I was referring to dialing in the isc transfer itself
first you have to have your maf dialed in
then, go set the isc multiplier to 0 and the isc offset to 0 then update, let it idle stable for 10 sec or so and note the airmass, then set the isc offset to 10 and update, let it idle 10 sec and note the average airmass, repeat again at 20 percent, 30 40 50 60 70 80 90 and 98% (should never command 100% iscdc)
then subtract those airmasses from your base airmass at 0 iscdc and you have your isc transfer for fn800
the trick is the engine has to be at warm operating temp and the ac off all loads off and the fan cannot come on during that time which can be a daunting task if you have a mediocre radiator
Return to General Hardware
