EEC-IV knock sensor
EEC-IV knock sensor
Unread postby SlowBox » Sun Aug 13, 2017 5:41 pm
Is there hardware on any of the fox-compatible EECs for a knock sensor? I'd love to play with a knock sensor on my motor since I don't have access to a dyno.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: EEC-IV knock sensor
Unread postby decipha » Sun Aug 13, 2017 6:35 pm
none that i know of, u can snatch the hardware out of a supercoupe ecu, i wouldnt bother with it though, theres very little knock sensor support in gufx, ud be better off going to a lincoln mark viii or the like ecu that has better knock control but would require edis, at that u might as well swap in an eec-v and go coil on plug with far greater support and controls
a knock sensor is incapable of dialing in spark though
for example, on my marauder at part throttle 1750 rpm and 60 load, I can advance the timing all the way to 35 degrees before it gives any audible knock, the knock sensor starts kicking in at 31 deg, yet it makes max tq/power at only 18 degrees thats with 93, with 87 octane in that cell i only command 8 degrees, i cant recall the exact number but i think it was 43 ft lbs on 93 and 39 ft lbs with 87 octane, its not much power loss driving but is noticeable, i do some trickery with the iacdc on acceleration to give it more throttle so its rly not anything youd notice driving
your best bet would be to just play with it, throw timing around and see if it seems to make it feel more or less responsive, the objective is to run the least amount of timing that gives u the most power
Unread postby SlowBox » Mon Aug 14, 2017 11:18 am
Just looking for an easier way to dial it in on the street. P heads with higher than stock compression are finicky.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Return to EEC-IV Tuning
cron
