Data logging issue - GUFX - A9L2
Unread postby nc5l » Fri Apr 14, 2017 8:49 am
Hi All,
I have searched everywhere to see if I can solve this on my own but with no success.
I have an Australian Falcon with a 2DCA ecu currently running A9L2 binary on a Quarterhorse.
Engine runs fine,I can write bins successfully but my issue is with data logging. I am using the GUFX.adx in TunerPro RT and some PID's do not work.
TPS
RPM
AIT
ECT
I can see hegos, lamse, vbatt and others all seem to work fine.
Is this a patch code issue with Aus spec ecu?
Thanks Dan.
nc5l
Name: Daniel Richardson
Vehicle Information: 1994 Ford Falcon ED XR8 2DCA ECU With A9L GUFB QH BE EA TunerPro RT
Re: Data logging issue - GUFX - A9L2
Unread postby jsa » Fri Apr 14, 2017 2:55 pm
At a guess it might be a version difference between the bin and the adx.
Cheers
John
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
Unread postby nc5l » Fri Apr 14, 2017 8:08 pm
Thanks for the reply JSA,
I initially thought the same although I tried multiple different GUFB calibrations, all stock and experienced the same result.
Thanks.
nc5l
Unread postby jsa » Sat Apr 15, 2017 3:57 pm
A9L2 is not stock.
Decipha has had more than one patch code implementation over time.
I don't think the hardware is relevant to the issue.
Cheers
John
EEC-IV GHAJ0
Unread postby decipha » Sat Apr 15, 2017 8:44 pm
Are you using this?
viewtopic.php?f=36&t=2160
Name: Michael Decipha Ponto
Unread postby nc5l » Sun Apr 16, 2017 2:03 am
jsa wrote:A9L2 is not stock.
Yes, I tried good old A9L too and had the same issue.
decipha wrote:Are you using this?
Yes I'm using GUFX_20160927.adx
Also tried two different EEC's and still the same.
Dan
nc5l
Unread postby nc5l » Sun Apr 16, 2017 2:34 am
Would the battery on the QH have anything to do with the issue?
I have tried BE with both matching 2DDA strat and Bin as well as A9L and GUFB strat with no luck.
PIDs in BE don't even change then the dataloging just ends.
Dan
nc5l
Unread postby jsa » Sun Apr 16, 2017 6:40 am
If the QH battery was an issue the car would not run.
You said in your first post some pids work, is that still the case?
Cheers
John
EEC-IV GHAJ0
Unread postby decipha » Sun Apr 16, 2017 8:29 am
your j3 port isnt clean
make sure u take a razor to it and get the plastic off of it before putting the QH on
Unread postby nc5l » Sun Apr 16, 2017 5:30 pm
jsa wrote:If the QH battery was an issue the car would not run.
Yes that was the case. IEGO1 & 2, LAMBSE's and VBAT were all fine. RPM, ECT, ACT, & TP didn't work.
decipha wrote:your j3 port isnt clean
I managed to get it to work by knife-and-forking.
First I tried manually writing the patch code as found in the ADX (including checksum byte) to the QH using REALTERM, although the QH always responeded with a 0x3E ASCII ?. If I remember correctly this means the QH failed to interperet the command.
Failing that I eneded up copying the patch code from command in the ADX to 0x84B2 in the binary using HEX Workshop.
Wrote the newly patched bin to the QH and all PID's worked as they should.
Still beggs the question as to what is causing the issue from TunerPRO when writing the patch code...
Thanks or your help.
Dan
nc5l
Unread postby Bad86capri » Wed Aug 02, 2017 6:38 am
I'm having the same issue. All the gauges were working and as of yesterday they stopped. Well the ones that are not working are ect, act, and rpm. I was having issues with hegos not switching on the dashboard. I assumed it was a mechanical/wiring problem. Yesterday my ect and act were both showing 82. The tach was not working at all. Is this a similar issue to yours?
Bad86capri
Vehicle Information: 86 Capri T-Top. Oxford white, grey trim and canyon red interior. 306 with twisted wedge heads with 54cc chambers, Anderson b3 cam, Edelbrock RPM II intake, Ford Racing 80lbs inj., c&l 80mm maf, BBK 75mm tb, longtube headers. Im currently using a plx wideband mounted in the driverside header. Tuning with moates quarterhorse and Tunerpro.
Unread postby decipha » Wed Aug 02, 2017 12:15 pm
that was an issue with the old patch code
download the latest gufx xdf and universal eec IV adx off the homepage
Unread postby decipha » Wed Aug 02, 2017 12:21 pm
decipha wrote:POST: viewtopic.php?f=7&t=2379
updated universal eec-iv adx and updated gufx xdf posted on the homepage
be sure to enabled the "restore console routine" patch first if you have an tune that may have existing patch code in it.
simply do the follow
download the new adx and xdf
open the files in tunerpro and your existing tune
apply the restore console patch
apply the universal adx patch
click on poll and start logging
enjoy
decipha wrote:POST: viewtopic.php?f=22&t=2139
download the latest universal adx file off the homepage for eec-iv
go to the dash make sure eec-iv dash is being view and not the eec-v dash, its the default dash so it should pop up first, anywho, wbo2-aem is the wideband, it should show up right in the middle of the screen already, you can right click on it and select an lc1 plx etc... aem is the default though
be sure to download the latest gufx xdf off the homepage too, i added some things to it just last night, you will have to remove the universal adx patch and re-enable it to get the latest and greatest goodies
I must admit im fuckin tickled with where i finally got her, i went from a foxbody to my marauder using the same ADX, its so nice
Unread postby Bad86capri » Wed Aug 02, 2017 4:03 pm
the latest gufx wont download.
Bad86capri
Unread postby decipha » Wed Aug 02, 2017 4:59 pm
well shit imma check it out
Unread postby decipha » Wed Aug 02, 2017 5:06 pm
yep fixed, it helps to upload it lol
Unread postby Bad86capri » Wed Aug 02, 2017 5:25 pm
Thanks man!! Sorry for double posting I was wanting to make sure you seen it. Lol
Bad86capri
Unread postby Bad86capri » Wed Aug 02, 2017 6:10 pm
How do I change ad counts back to mafv?
*edit* the maf transfer is in imaf instead of mafv. is there anyway to change it back?
Bad86capri
Unread postby decipha » Wed Aug 02, 2017 7:06 pm
yea but why?
it logs as imaf adcounts and the maf transfer is imaf adcounts too
Unread postby Bad86capri » Wed Aug 02, 2017 7:17 pm
everything ive done to this point has been in mafv. when put a curve in do i need to convert the voltage to current or are the data points in the same place?
Bad86capri
Unread postby decipha » Wed Aug 02, 2017 7:50 pm
should be the same
16V = 3200
5.00v = 1000
4.75v = 950
4.50v = 900
4.25v = 850
4.00v = 800
3.75v = 750
3.50v = 700
3.25v = 650
3.00v = 600
2.75v = 550
2.50v = 500
2.25v = 450
2.00v = 400
1.75v = 350
1.50v = 300
1.25v = 250
1.00v = 200
0.75v = 150
0.50v = 100
0.25v = 50
0.05v = 10
0.00v = 0
Unread postby Bad86capri » Wed Aug 02, 2017 8:06 pm
with some simple reverse math i figured it out. just not used to look at those numbers. lol.
Bad86capri
Unread postby Bad86capri » Thu Aug 03, 2017 3:04 pm
Ok it's not applying the universal adx patch. Any ideas??
Bad86capri
Unread postby Bad86capri » Thu Aug 03, 2017 3:18 pm
Two step patch is acting crazy also. If you apply the patch without setting the rpm limit it shots the car off because the limit is automatically set to 95 rpm. If set the limit then apply patch it does not apply. It has this message.. indeterminate: data does not match
Bad86capri
Unread postby decipha » Thu Aug 03, 2017 3:41 pm
enjoy
[/quote]
The two step code i didnt finish.
Before applying or removing any patches ALWAYS read the comments in them
Unread postby Bad86capri » Thu Aug 03, 2017 4:05 pm
I applied the console patch and then the universal adx patch. Still didn't work. I'll try downloading gufx again when I get home. What all does the two step code need?
Bad86capri
Unread postby decipha » Thu Aug 03, 2017 4:15 pm
im not sure, i copied it over from one of my other strats and never tested it so until then I cant say
if i get time this weekend ill look over the code and make sure its functioning like i want it to
Unread postby Bad86capri » Thu Aug 03, 2017 4:24 pm
Ok. I'll redo everything just to make sure
Bad86capri
Unread postby Bad86capri » Thu Aug 03, 2017 4:55 pm
Did you make the dashboard imaf match the transfer function?
Bad86capri
Unread postby decipha » Thu Aug 03, 2017 6:41 pm
yea
Unread postby Bad86capri » Thu Aug 03, 2017 7:45 pm
I think I may have the issue. When I open the restore console patch it won't let me remove the patch. It's showing the patch as being applied. It's not letting me apply the universal adx patch either.
Bad86capri
Unread postby decipha » Thu Aug 03, 2017 9:40 pm
you cant remove the restore console patch and you shouldnt be trying to
post your current tune file ill take a look
Unread postby Bad86capri » Fri Aug 04, 2017 6:23 am
I'll post it when I get home this evening. Thanks for taking a look!
Bad86capri
Unread postby Bad86capri » Fri Aug 04, 2017 3:19 pm
Here's my bin.
Bad86capri
Unread postby Bad86capri » Sat Aug 05, 2017 8:31 am
I opened up the new xdf and adx with a stock a9l2 bin and apllied the console restore patch and then the universal adx patch. i noticed when i applied the universal patch it automatically removed the console patch. is this normal?
Bad86capri
Unread postby decipha » Sat Aug 05, 2017 9:13 am
yep thats why u have to do them in that order
you have to restore the console routine then write the patch code over it
Unread postby Bad86capri » Sat Aug 05, 2017 9:44 am
On the bin I posted up I think there's something wrong with that one. It won't apply the universal adx patch and console patch is already applied when it's opened. On the a9l2 bin the console patch is not applied at first. I went back through the bin to make sure I didn't miss anything and I can't find anything obvious.
Bad86capri
Unread postby decipha » Sat Aug 05, 2017 11:00 am
I see the issue with your tune file and not accepting the universal adx, its due to a small segment of the code being there so it won't allow it to overwrite
I posted an updated xdf, I broke out the universal adx and the disable datalogging patches as two seperate patches, will make it much easier now and no chance of error :)
enjoy, its on the homepage
Unread postby Bad86capri » Sat Aug 05, 2017 1:16 pm
Thanks!!
Bad86capri
Unread postby Bad86capri » Sat Aug 05, 2017 2:12 pm
Well either I'm a complete retard or something is still wrong!! Still not doing anything
Bad86capri
Next
Return to EEC-IV Tuning
