U4P2 and trans
U4P2 and trans
Unread postby RIKIL » Thu Jun 30, 2016 10:51 am
I have the U4P2 but it is not connected to my trans. I have a separate trans controller for that.
What am seeing is my O/D cancel light will blink. Because of this I don't have control over O/D. I think this is because of pin 53, TCC, which expects an input but is not getting it. Could this be the case?
I think the ECU is seeing a problem with the trans but the trans is fine.
RIKIL
+Premium Plus Member
Vehicle Information: Red, 1992 F150, 351W, E4OD, Vortech V-2 Si trim blower, Snow Performance water/meth injection system, custom cam, Edelbrock Performer intake, Twisted Wedge 205cc heads, shorty full-length headers, MASS Air (converted), tuning with CBAZA / QuarterhorseRT, 4x4, short bed, 33" tires
Re: U4P2 and trans
Unread postby decipha » Thu Jun 30, 2016 11:30 am
if the ecu isnt controlling a trans then load a manual tune on it and simply change the trload to auto non eec controlled
/done
Re: U4P2 and trans
Unread postby RIKIL » Thu Jun 30, 2016 1:22 pm
2 questions...from looking at T4M2, I found TRLOAD, it looks like my options are:
4 = auto, non electronic, neutral drive switch
5 = auto, non electronic, neutral pressure switch
I don't know about the switches listed, does it matter?
Second, what would I need to take from the tune you created for me and copy it to the T4M2 bin? I was just going to use TunerPro and open both tunes to copy parameters but what should I copy?
RIKIL
Re: U4P2 and trans
Unread postby decipha » Thu Jun 30, 2016 6:22 pm
yeah 4 is what you want
ill go ahead and swap it / copy it over and post it in your thread
<edit>
I just looked through your tune and it is a t4m2 tune
Re: U4P2 and trans
Unread postby RIKIL » Fri Jul 01, 2016 7:51 am
decipha wrote:yeah 4 is what you want
<edit>
I am only guessing at the problem. When I swap in the A9L I don't get the problem with the O/D light. The other reason why I brought this up is because I had to remove my trans, it wasn't acting right and wanted to see if there was an issue here.
Can you tell me any more about the TCC, input, output???
RIKIL
Re: U4P2 and trans
Unread postby decipha » Fri Jul 01, 2016 10:02 am
if the trans controller is setting a fault why are you messing with the ecu?
pull the trans controller codes and see whats wrong with it
the ecu does not send out any signals, theres absolutely nothing in the ecu that can cause the trans controller to freak out
Tcc is an output, its not used since you dont have an ecu controlled auto
Return to EEC-IV Tuning
