Tune for bracket racing consistency
Non-vehicle specific forum for tuning all ford ecu's 1994-2004, including the 1994-1995 Mustang, 93-98 Mark VIII, 99+ F-150, 99-04 Mustang, 03-04 Cobra, 99-04 Lightning and Harley Davidson F-150
CBAZA, CDAN4, CRAJ0, CVAF1, FBGI0, OMAE2, RZASA
Re: Tune for bracket racing consistency
Unread postby Patricktjms » Mon Oct 22, 2018 7:18 am
How low can I go with the manifold volume. It was already at 4 and im down to 1.8 with no noticeable improvement.
Patricktjms
Vehicle Information: 1994 mustang gt 5.0 stock. Bracket car, C4 w/10" converter. K&n filter, pypes short headers, 2.5 off road pipe with 40 series flowmasters, no smog no egr, 255 pump adjustable fuel preasure @ 55, small shot for finish line driving. 4.10 with 295/55-15 m/t drag radials. Stock ecu cbaza
Unread postby decipha » Mon Oct 22, 2018 7:51 am
0.13 or 0.25
Unread postby Patricktjms » Fri Oct 26, 2018 3:11 pm
Here's an odd question......with it being colder outside, is there a way I can hook up a switch, or use what used to be the a/c wiring to be able to switch on and bring the idle up to say 1700 or so in the staging lanes if I need to put a little more heat in the engine quicker? Kinda like using a lean-out valve on my alcohol cars. I like to pull into the water at 180 but sometimes I need to get it there a little quicker.
Patricktjms
Unread postby decipha » Fri Oct 26, 2018 5:44 pm
just use the act dsdrpm adder to make it idle higher when cold
Unread postby Patricktjms » Thu Jul 18, 2019 6:56 am
Any harm done if I just drain gas, flush, and fill with E85 and adjust the tune? Stock 19# injectors with 255lph pump. Will everything handle it?
Patricktjms
Unread postby decipha » Thu Jul 18, 2019 4:04 pm
19s on E85 will only support 195hp. A stock engine on e85 makes 240hp.
You should have 30s minimum to run e85 on a stock engine and at least 36lb minimun if its modified.
Details are in the pre tune info write up
Unread postby Patricktjms » Thu Jul 18, 2019 6:43 pm
What lambda should I command for the E85? I run OL all the time. I run it at 1.0 on C110 race gas.
Patricktjms
Unread postby decipha » Fri Jul 19, 2019 7:34 am
1.0 is lean
on e85 at wot max power na is usually around .85
Unread postby Patricktjms » Fri Jul 19, 2019 3:08 pm
1.0 is where the car makes the most power and runs the most consistent laps down the ttrack.
Patricktjms
Unread postby decipha » Fri Jul 19, 2019 3:45 pm
thats lean and puts a lot of heat on the exhaust valves. Would be best to richen it up slightly for safety.
Previous
Return to EEC-V & SN95 Tuning
cron
