04 crown vic data logging issues
Unread postby mustangman1992 » Sun Nov 19, 2017 6:00 pm
I currently have a old 04 crown vic wich is 100% bone stock with the exception of a turbo, 80lb injectors and a lightening meter. I am having trouble getting the data logging to work in tunerpro. I have set it up exactly as stated in the write up. it connects but the gauges just read jibberish if anything at all.. any thoughts ?? my xdf file is from this site rzasa I also have the universal adx file installed....
oh and one other thing..... would I be able to use any of the base tune bin. files on this site? Thank you in advance!
mustangman1992
Premium Member
Vehicle Information: dss 331, on3 turbo 7psi
Re: 04 crown vic data logging issues
Unread postby decipha » Sun Nov 19, 2017 7:27 pm
are you using an rzasa bin file?
you have to load a crd1 file in her with the changes needed for your setup
the rzasa stock bins can be had from the homepage
the eecV swap write up will tell u what all needs to be updated in your tune
with 80s and a turbo your best bet would be to get a remote tune
Unread postby mustangman1992 » Fri Nov 24, 2017 2:09 pm
so I loaded in a crd1 file with the injector and maf values.. it starts and runs not too terribly.. the only problem i am having is that its running pig rich like afrs in the 9s or 10s, and no matter how much i play with injector slopes or the maf curve i cant get it to change at all. any thoughts?
i am going to try tuning this thing myself first. i will definitely hit you up for a remote tune once i finish destroying this tired old motor. haha
mustangman1992
Premium Member
Unread postby decipha » Fri Nov 24, 2017 2:56 pm
haha
did you set minpw to 0 ?
Unread postby mustangman1992 » Fri Nov 24, 2017 3:33 pm
Yeah I think at the current rate new motor will be in order very soon haha.
Yes I do have minpw set to zero...
mustangman1992
Premium Member
Unread postby decipha » Fri Nov 24, 2017 6:28 pm
youve got to be doing something wrong then no reason for it to be idling so rich
post a log and the tune file
Unread postby mustangman1992 » Sat Nov 25, 2017 12:53 pm
I do not yet have a log... here's the tune file though.
mustangman1992
Premium Member
Unread postby mustangman1992 » Sun Nov 26, 2017 7:22 pm
here is a quick log I took . its was still dumping gas afrs in the 9s and 10s. the wideband doesn't change at all no matter how much I change the injector slopes or the maf transfer. when I start the car lambse starts at 1 goes down to .85ish for a few seconds then climbs straight to 1.3 and stays there.. any advice is greatly appreciated! also I have no idea why some of the gauges in tunerpro give crazy readings....
mustangman1992
Premium Member
Unread postby decipha » Sun Nov 26, 2017 8:14 pm
i just realized your a premium member, why didn't i send u a startup tune for it?
if u hadnt already fill out the vehicle info form and ill shoot u a base tune for it to get going
https://www.efidynotuning.com/info.php
Unread postby mustangman1992 » Mon Nov 27, 2017 2:46 pm
yeah a year or two ago I had you do a full remote tune for my mustang. that car is gone , I now have an 04 crown vic cop car I slapped a turbo on . was wondering what you could do for me on a tune for that one. I am good at a lot of things.... tuning and computers is not one of them. haha
mustangman1992
Premium Member
Unread postby decipha » Mon Nov 27, 2017 10:01 pm
Return to EEC-V & SN95 Tuning
Users browsing this forum: No registered users and 3 guests
cron
