2004 EAw0 Mustang V6
Unread postby adfosterm3 » Mon Sep 04, 2017 11:33 am
Trying to work on a 2004 Mustang v6 auto. Ecu code is EAw0.
Just trying to do a simple pats delete and disabling rear O2.
Can't seem to get a straight pull of information using the FgFb2 xdf, Im assuming it probably uses its own wierdo strategy.
In experimentation, I can set a RKn2 tune to run as a v6 and pats delete and load on the car and it will run. rough, but does run, just throws a code for p0600 processor error.
Figured I would see if I posted the bin that I was able to pull off the thing if someone could make heads or tails of it and maybe help me find out what I have to do to get this thing taken care of, or if it could help in getting an xdf put together to help the v6 crowd.
adfosterm3
Vehicle Information: 1999 Ford Mustang v6 with full 04 v8 swap Fgfb2 strategy, quarterhorse
Re: 2004 EAw0 Mustang V6
Unread postby decipha » Mon Sep 04, 2017 1:00 pm
youll have to copy all the pertinents over from your strat to fbfg2 and itll run fine, the fbfg2 write up has a list of the minimum values you need
Unread postby adfosterm3 » Mon Sep 04, 2017 2:44 pm
Tried using fbfg2 tune set up for v6.. had sane values for everything and it popped p0600 code and ect/chat was all over the place. Thinking the strategy on the way is differant and has data moved or shifted. Spark, maf tables, all wacked out with random numbers out of sequence. It did run but was way glitchy.
adfosterm3
Unread postby decipha » Thu Sep 07, 2017 8:40 pm
the user tecks on here back in march had an 04 v6 as well with the same fbde3 strategy his catch code was KWZ2, same tune as your eaw0
this is his tune with your pats code and vin copied over, i also applied the universal adx logging patch and disabled the perload hacks which i think was causing his to stall randomly
enjoy
Unread postby adfosterm3 » Fri Sep 08, 2017 9:01 pm
Thank you, I'll try it and check back tomorrow. Will the fgfb2 xdf read it or does it have it's own?
adfosterm3
Unread postby decipha » Sat Sep 09, 2017 1:26 am
its an fbfg2 tune
Unread postby david claflin » Tue Oct 31, 2017 12:05 pm
I take it this a tunerpro version, and not for use with BE?
david claflin
Vehicle Information: 1990 LX A9L/ DB1 Bin Editor Quarterhorse
Vehicle 2 Information: 1985 LTD LX A9P
Vehicle 3 Information: 1994 Cobra J4J1
Unread postby decipha » Tue Oct 31, 2017 3:49 pm
you can write it with tunerpro and read it with be if you desire
i have no idea why anyone would want to though but sure no problem
Unread postby david claflin » Wed Nov 01, 2017 10:36 am
I used to use tunerpro a long time ago, I thought you had an XDF as the template, and then the bin was what was used to populate the values, is that still correct?
david claflin
Unread postby decipha » Wed Nov 01, 2017 10:42 am
yep
thats how all tuning software functions
Unread postby david claflin » Thu Nov 02, 2017 9:03 am
For a CAX0 cal code ecu, I loaded 20170830 XDF, and the 170907a bin, seems to be working. I checked the MAF function, shows 0.00 for both IMAF and lbs. min at the top, and 5.1, and 31.2 at the bottom as the highest values, does that seem right? I guess I'm used to seeing KG/Hr is why I questioned if everything loaded properly.
david claflin
Unread postby decipha » Thu Nov 02, 2017 9:16 am
yep thats right, you clicked on the lbs/min maf transfer, theres another with kg/hr if you prefer that, just press ctrl anf F and type in maf, you'll see there's multipler maf transfer for doing multiple different things
Unread postby david claflin » Sat Nov 04, 2017 2:45 pm
decipha wrote:you can write it with tunerpro and read it with be if you desire
In case I decide to do this, are there instructions somewhere for doing this?? I didn't see any strategies on Clint's download page for this application...
david claflin
Unread postby decipha » Sat Nov 04, 2017 6:13 pm
you simply write it with tunerpro then read it back with BE
you need the fbfg2 strategy file for BE, i think popsracing sells them for $200
Return to EEC-V & SN95 Tuning
cron
