Too rich when warming up + dfso question
Unread postby Pappacosworth » Sun Sep 03, 2017 10:18 am
Car is 1994 5.0 Mustang GT, original 19lb injectors swapped to 24 lbs M-9593-A302F. I found injector data from Ford Racing pdf, but I have rich cold situation. BE suggests to scale FN348A according to low slope change. But low slope ratio is reversed, old slope 28.8 and new 26.21. Does FN348A have effect after cranking?
Tune started from Efidynotuning base file, and Sailorbops strategy.
Car details:
AFR 165 heads, Trick Flow Intake Manifold 5.0L Track Heat, 1.6 rollers
75MM tb, BBK Shorty Headers, X-pipe, Cold
Air Kit, Flowmaster exhaust, 24lbs injectors, fuel pump 190 Lph, Gss242
2.73 ->3.55. and automatic.
I have Megalogviewer histograms from warming up. I like the program, easier to adjust from log files.
Where should I make adjustments, lambse is correct, but wideband shows too rich?
base7loadscaled.BEB
Pappacosworth
Fabricator
Re: Too rich when warming up
Unread postby decipha » Mon Sep 04, 2017 1:04 pm
odd that its rich when cold, how rich?
once u have fuel dialed in then dial in the startup enichment table, the fuel and startup enrichment write ups on the homepage will give u all the details
Unread postby Pappacosworth » Tue Sep 05, 2017 1:18 am
I got it turned other way. Now it's lean. I made correction formula to calculate maf values and I have to make test drive again. But I have trouble to match low load lambse both cold and warm, I mean I always got it working either cold or warm not both. Injector slopes?
Lambse Subtractor Table FN1361 > does this output different fuel amount than lambse?
Pappacosworth
Fabricator
Unread postby decipha » Tue Sep 05, 2017 11:46 am
when an engine is cold lambse isnt going be the actual AFR due to the cold engine
Unread postby Pappacosworth » Wed Sep 06, 2017 10:41 am
I got it close enough so adaptives can handle it. Only one problem is left. When coasting, injector cut occurs at regular intervals for some time. It's annoying, like someone pulls handbrake. It happens at 1500 rpm. I tried to alter some parameters but can't find the solution. I don't understand dfso process clearly enough.
ReadyCL.BEB
Pappacosworth
Fabricator
Re: Too rich when warming up + dfso question
Unread postby decipha » Wed Sep 06, 2017 11:33 pm
you can adjust the dashpot closed throttle time delay and the dashpot time extended scalars
and as for RPM, you can kick up the min rpm to allow dfso, that value is added to dsdrpm so keep that in mind
Return to EEC-V & SN95 Tuning
