Anybody have a tune for 3.8 mustang supercoupe blower swap?
Unread postby Mustang124 » Wed Aug 16, 2017 12:08 am
Looking for a tune or something to start with I have a 95 mustang 3.8 CCAQE did a thunderbird supercoupe swap have a quarterhorse and BE/EC on the way I'm new to this looking for something to get me started
Mustang124
User
Name: Coty blackwell
Vehicle Information: 95 mustang 3.8 super coupe swap 30 lb injectors 70 mm tb 70 mm mass air 10 lbs boost , C4J3/ CCAQE quarterhouse BE/EC
Re: Anybody have a tune for 3.8 mustang supercoupe blower sw
Unread postby BKB » Sat Sep 23, 2017 11:39 am
The stock 94 v6 mustang EEC using CCAQE is pretty much identical to the 94 Thunderbird SC CZAWO. I ran my SC motor in my 94 mustang for 15+ years on CCAQE but switched to the 94 SC computer to give me more control and in general it seems to fuel better than the CCAQE. What im saying is use the sc CZAWO and start copying things over or at least compare the two. That's how I learned and its been a fun trip. Started with the EEC Tuner, then QH helping Sailerbob work on CCAQE, and now CZAWO. More specific questions let me know, and how about some details on the engine.
BKB
Vehicle Information: 1994 V6 Mustang with 94 Thunderbird SC 3.8 motor. 16psi, 80lb injectors, 05 slot in 3.88 ID tube. Tr6060 6speed trans from 2010 Camaro. QH CZAW0
Unread postby Mustang124 » Tue Nov 28, 2017 4:47 pm
It's the mustang block with the 89-93 blower 30 lb injectors,cold air intake,95 gt throttle body,stock super coupe intercooler 10 lbs of boost,dual exhaust,screaming demon coil pack. I had a guy try to help me remote tune it couldn't get it to data log and said it seamed like it wasn't excepting the whole tune. Changed the computer still no luck. Thanks for the thought of copying over the other strategy I'll try that once I figure out what's going on with it. How did you go about using the SC computer change wiring an all? or they work with they work with mustang harness?
Mustang124
User
Unread postby BKB » Mon Dec 18, 2017 2:41 pm
I started by moving the pins around because things are in different locations, then I realized the pin diameter is also different. Not fun re-pinning all those wires. Its not horrible but I probably would have just made my own harness at that point. My problems came after I went to a larger cam, before the new cam the car ran almost stock with minimal tuning. Hell this thing ran many years on a EEC Tuner and that didn't give you much control and zero data logging.
BKB
Return to EEC-V & SN95 Tuning
Users browsing this forum: No registered users and 15 guests
cron
