CDAN4 Tunerpro
CDAN4 Tunerpro
Unread postby ZCHondaCRX91 » Sat Jun 10, 2017 9:35 am
We are putting a 3.8 in an older mustang chassis, and we need some help figuring out our method of tuning. Right now we have a CDAN4 PCM (from 1997 Mustang 3.8 Auto). We can't run the factory PCM because of the changes seen below. I've tuned a lot of other cars before, but this is my first Ford EFI project. I've used Tunerpro in the past, but from what I read using the CDAN4 strategy with Tunerpro is not ideal. I really don't need to do a lot of tuning at the moment I just want to get it up and running without any CEL. Is there any advice on using Tunerpro for our setup, or should I just consider Binary Editor instead?
Thank you.
Engine/Transmission
- 1997 Mustang 3.8 with Split Port Head Swap
- Windstar Upper Intake Manifold
- Headers and Dual Exhaust
- 21 lb/hr injectors
- Bored 0.040" over with slightly higher CR (milled head)
Deleted Components
- EGR and EVAP
- Rear O2 Sensors
- PS and A/C Components
- Need to Disable PATS
ZCHondaCRX91
Vehicle Information: 1997 Mustang 3.8, 99/00 split port head and windstar intake
Re: CDAN4 Tunerpro
Unread postby decipha » Mon Jun 12, 2017 12:16 am
cdan4 support with tunepro is minimal at best, I hadn't went through it nor have I put the logging patch code in there since no one has requested it
best bet is to start from a tbird 3.8 bin as pats is already disabled and you can simply disable the rear hegos and egr, p/s and a/c require no changes, evap is going to require some code looking to disable correctly
you'll have to toss in your injector info, simplify spark and toss in a typical spark table for your setup
what trans are you using?
Re: CDAN4 Tunerpro
Unread postby ZCHondaCRX91 » Mon Jun 12, 2017 4:40 pm
We are using a T-5 Manual transmission (from 1998 Mustang 3.8).
ZCHondaCRX91
Re: CDAN4 Tunerpro
Unread postby decipha » Mon Jun 12, 2017 5:44 pm
SPP5 is the catch code for a 96/97 tbird 3.8L V6 CDAN4, it comes with no PATS so that's ideal to start from
attached
Re: CDAN4 Tunerpro
Unread postby ZCHondaCRX91 » Mon Jun 12, 2017 6:45 pm
Thank you, I will let you know if I have anymore questions.
ZCHondaCRX91
Re: CDAN4 Tunerpro
Unread postby decipha » Mon Jun 12, 2017 8:18 pm
no need, i can assure u there will be several
Return to EEC-V & SN95 Tuning
Users browsing this forum: Google [Bot] and 1 guest
