2001 v6 turbo tuning
Unread postby Mustang024 » Thu Mar 09, 2017 9:09 pm
I was looking at the WOT/stabilized fuel table and I know that changing the lambda values will not adjust fueling needs. I have a turbocharged 3.8L only have 4psi for time being until I get this car sorted out. Question is the I know to richin or lean out I adjust the injector slopes.
In the table it shows x/y axis throttle position voltage and RPM.
Would i fill the first row with 0.0750 and just increase from top row to bottom ending up at 14.1???
I have a kamrf 1 of 1.00 but Kamrf 2 is .004 for some odd reason. Also battery voltage is not registering correctly under the universal adx.
Mustang024
Vehicle Information: 2001 3.8L 5 speed.
Moates QH.
Tuner pro r/t
EEC-V.
Re: 2001 v6 turbo tuning
Unread postby decipha » Wed Mar 15, 2017 8:07 pm
hey joe welcome to the forum
post the tune your currently using and i'll take a look
Unread postby Mustang024 » Wed Mar 15, 2017 8:39 pm
I attached the tune.
I started to change commanded lambse in the Wot/stabilized table. Have a wideband installed and will adjust slopes to dial it in/ Not sure if correct, havent had a chance to get to the car with the snow this week.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Wed Mar 15, 2017 8:47 pm
fn1360b is used for enrichment on a stock fbfg2 tune, in your tune you had the perload hack enabled but not the force perload hack enabled, thus the ecu wasn't correctly controlling fuel as I intended it to, those hacks are to be used together as per the comments
here I disabled the perload hack and set your fn1360b fuel table back to sane values, go ahead and dial her on in, it looks like you hadn't entered in your maf or injector info yet
Unread postby Mustang024 » Wed Mar 15, 2017 8:52 pm
Thanks decipha, I am trying to beat this stuff into my head and getting familiar with the software. I have a stock maf and 21lb injectors.
Does your MAF doubler act like an extender/mafia of sorts??
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Wed Mar 15, 2017 8:54 pm
nope, a mafia is a voltage range extender letting the maf measure more airflow, the maf doubler just allows you to enter in a higher maf flow so you don' t have to scale the tune if you have a maf that flows more than 1750 kg/hr
all the details are in the maf and scaling write ups, give them a read good stuff in both
http://www.efidynotuning.com/maf101.htm
http://www.efidynotuning.com/scaling.htm#airflow
Unread postby Mustang024 » Wed Apr 05, 2017 3:00 pm
Question, I have a stock 2001 v6 maf in a 3inch tune would this effect the tranfer data to,be plugged,into the table?.
I was under the impression it would effect the range by making it greater.
Also I cannot find the maf xfer data for this car anyone point,me to where I can find it.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Thu Apr 06, 2017 12:43 am
yes a new meter will cause the maf transfer to change
all the details are in the maf 101 write up on the homepage, heres the direct link
I can post the maf transfer for the stocker for you or you can search for v6 fbfg2 and yank it out of one of the v6 converted tunes ive posted
Unread postby Mustang024 » Wed Apr 19, 2017 3:07 pm
I am noticing that some parameters in my datalog aren't recording they stay at a constant value i.e. vbat, atmr and tps counts. What has to be done to get these to log.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby Mustang024 » Wed Apr 19, 2017 3:09 pm
Also what parameter is rpm I an only seeing idle rpm.
Seein
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Thu Apr 20, 2017 6:56 am
i have to add them to the datalogging list A
Unread postby Mustang024 » Thu Apr 20, 2017 1:10 pm
Another thing I have noticed is sct uses load in the y axis of the stabilzed fuel tables and tuner pro uses tprel? What's the advantage or disadvantage of using tprel?
Is adding those parameters in the diassembly write up?
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sat Apr 22, 2017 12:31 pm
yep its in there
sct and tunerpro just shows the tune data, the axis scaling is done by the strategy unless someone changes it manually
Unread postby Mustang024 » Sat Apr 22, 2017 9:42 pm
I am still getting automatic transmission codes, I look through the scalars and turned some of them off. There are a few that I cannot find to turn off. I did the auto trans sw to 0 also the trload strat to 0. This is a manual trans car.
p0708
p0740
p0740
p0743
p0750
p0753
p0755
p0758
p1702
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Apr 23, 2017 10:45 am
theres a bunch of auto switches for different checks that should be changed when going from an auto to manual or vice versa
best bet would be to use an rkn2 cal and modify it as you need since its already a manual cal so all the auto switches are disabled
fill out a vehicle info sheet from the homepage and copy and post the text in a reply here, omit the top personal details as thats for sending chips in the mail
ill go through it and post a file so you can get started
Unread postby Mustang024 » Mon Apr 24, 2017 7:56 pm
ONLINE / REMOTE TUNING VEHICLE INFORMATION
www.efidynotuning.com/remote.htm
vehicleinfo.txt (DO NOT CHANGE FILE TYPE)
REV. 9-16-2016
________________________________________________________
NAME:
FORUM USERNAME:
TELE#:
EMAIL:
DATE:
ESTIMATED ALTITUDE (FT):20
POSTAL ADDRESS (FOR SHIPPING ONLY):
PRE-TUNE CHECKLIST VERIFIED [Y,N]:
IS VEHICLE 100% READY TO BE TUNED [Y,N]?
LIST ALL DEFICIENCIES/COMMENTS BELOW:
VEHICLE YR/MAKE/MODEL: 2001
VEHICLE WEIGHT:
ECU CODE:
J3 DEVICE (QH,Tweecer,etc): quarterhorse
TUNING SOFTWARE (BE,TunerPro,Caledit,SCT,etc): tuner pro
PRIMARY VEHICLE USE (street,strip,etc): street
MINIMUM IDLE RPM: 750
MAXIMUM ENGINE RPM: 6000
TRANSMISSION TYPE [AUTO,MANUAL]: Manual
Gear Ratios: 1st: 2nd: 3rd: 4th: 5th:
REAR WHEEL TIRE SIZE: 315/35/17
REAR GEAR RATIO: 2.73
TQ CONVERTER STALL SPEED:
INJECTOR SIZE/BRAND/COLOR: Seimans Deka 60lb
INJECTOR PART NUMBER:
ADJUSTABLE FUEL PRESSURE REGULATOR [Y,N]: N
BASE FUEL PRESSURE: 40psi
FUEL PUMP SIZE [LPH]: TRE 255
MASS AIR FLOW SENSOR TYPE: Stock with Mafia
MAF TUBE/HOUSING SIZE: 3”
MAF/INLET PIPING SIZE: 3”
MAF CALIBRATION SIZE: ???
MAF CALIBRATION VEHICLE: 2001 V6 Mustang
MAF CALIBRATION [GT or COBRA]: V6
MAF BLOW-THROUGH or DRAW-THROUGH: Blow Through
ADDITIONAL MAF NOTES/COMMENTS:
***IF MAF FLOW SHEET IS AVAILABLE, SEND WITH INFO***
EXHAUST HEADER TYPE [LONGTUBES/MID/SHORTY]:
EXHAUST CROSSOVER TYPE [X,H,Y-PIPE]:
EXHAUST PIPE SIZE, SPECS, & COMMENTS: 3” down pipe
FUEL TYPE OCTANE & GRADE: 93
FUEL QUALITY [POOR,FAIR,AVG]: AVG
METH INJECTION GPH & ACTIVATE LBS:
N2O SHOT / NOZZLE SIZE:
o2 SENSOR AGE & MILEAGE: 50K miles
WIDEBAND PRESENT & TYPE: YES, Innovate LC1
CYLINDER HEAD BRAND, MODEL# & SIZE: Stock
STATIC COMPRESSION RATIO: stock
ENGINE BLOCK SPECS: stock
CUBIC INCH DISPLACEMENT/LITERS: 232”
CAM SPECS: Stock
Intake Lift: Duration: Centerline:
Exhaust Lift: Duration: Centerline:
CAMSHAFT COMMENTS:
***IF CAM CARD IS AVAILABLE, SEND WITH INFO***
POWER ADDER TYPE [Turbo,SC,n2o]: Turbo
TURBO/SC MAKE/MODEL#: Holset Hy35
TURBO SIZE & AR /PULLEY SIZE: 54mm
#s BOOST: 4psi
IGNITION COIL TYPE: Coil Pack
DISTRIBUTOR TYPE:
PLUGS BRAND, ITEM #, and GAP: Autolite 103’s gapped .24
PLUG WIRES, SIZE, BRAND & AGE: Motorcraft stock wires
IGNITION BOX TYPE & AGE:
***BASE IGNITION TIMING MUST BE 10 BTDC***
IS BASE TIMING 10 dBTDC [Y,N]?:
ELECTRIC FANS PRESENT [Y,N]: Yes
COOLANT THERMOSTAT TEMP: 160
LIST ANY ADDITIONAL VEHICLE DETAILS/COMMENTS/NOTES BELOW:
www.EFIDYNOTUNING.com - EFI DynoTuning LC - New Orleans, LA
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby Mustang024 » Sat Apr 29, 2017 6:30 pm
Any chance you located that rkn2 cal?
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Apr 30, 2017 8:32 pm
rkn2 is a stock fbfg2 cal its on the homepage
Unread postby decipha » Thu May 04, 2017 5:22 pm
how does the car run? does it seem like its only running on a few cylinders? if so you may need to run a cvaf1 based tune due to the difference in the aice version
here load this in and give it a go, set the mafia to stock or remove it to verify it runs correctly first
Unread postby Mustang024 » Sun Jun 04, 2017 2:23 pm
Car spun a rod bearing last month. Just picked up a 4.2 out of an f150. Most likely going to reach out to have you tune it. Once I get it all back together.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Jun 04, 2017 5:53 pm
thats the best thing to do
sucks to hear about the rod bearing
Unread postby Mustang024 » Sat Nov 25, 2017 5:28 pm
well i got the new motor in loaded previous tune which would idle and was close when driving. Now loaded with the new motor and she wont stay idling. She is very sporatic and then she will putter out.
New motor is a 4.2 f-150 motor.
New injectors are 39lb cobra blue's
Maf is stock but placed in a 3" pipe
Anychance you can send me a base tune to atleast keep her idling long enough so she gets up to temp. Would be appreciated.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sat Nov 25, 2017 11:24 pm
did u toss in the injector and maf data?
Unread postby Mustang024 » Sun Nov 26, 2017 8:23 am
Yes pulled the inj. Data from the site and used the existing maf values from previous tune.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Nov 26, 2017 9:54 am
if you have a new maf you need to put the new maf transfer in, if its in a bigger pipe now go kick up the maf transfer by 15% or so for starters and then dial it on in
Unread postby Mustang024 » Sun Nov 26, 2017 11:15 am
looked up injector data for the 30lb cobras didn't see the pulse width for them. Also what about the DeltaP tables for high low and breakpoint do those need to be updated or leave them be.
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Nov 26, 2017 8:00 pm
i have no idea what you mean by the pulsewidths for them?
you said 39lb cobra injectors which are 03/04 cobra, im not aware of any cobra 30s other than maybe the cobra r's
yes the deltap multipliers need to be updated
Unread postby Mustang024 » Mon Nov 27, 2017 10:05 am
sorry that 30 was a typo is was refering to the the 39lb cobras. The Minimum pulse width entry under the injector parameters. I didn't see a value for that under the reference tab. I did a little digging and found some info will load it up and see how she runs.
I did get her to idle steady put had to lower the injector low slope all the way down to 17. So i am guessing them my MAF xfer is off then correct?
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Fri Dec 01, 2017 7:46 am
you need to put accurate injector info in first but yea if it persists then the maf is off a tad
Unread postby Mustang024 » Sun Dec 03, 2017 4:44 pm
Ok well I have the car idling ok on cold engine. Little bit of surging but stays running. But once I shut the engine off and start her back up when warm, she is not happy. Afr will go way rich down to 10:1 and she will sputter and stall out. Tried changing maf flow at this MAFV but to no avail still the same result. Also tried messing with the warm stabilized fuel table and that did nothing as well. I will attach a log and my tune for someone to view any help would be appreciated.
cold start today.xdl
novembertune.bin
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Dec 03, 2017 7:04 pm
if it's going to the tens why are you changing the maf if you already have it adjusted ?
is it going rich ?
Unread postby Mustang024 » Sun Dec 03, 2017 7:23 pm
Because it was going to rich so I reduced flow at those mafv parameters to keep it running
Mustang024
Moates QH.
Tuner pro r/t
EEC-V.
Unread postby decipha » Sun Dec 03, 2017 11:01 pm
but if you already had that area dialed in then the maf isn't the problem
are you sure it was going rich? what was the fuel error
Return to EEC-V & SN95 Tuning
Users browsing this forum: No registered users and 3 guests
cron
