4R70W Overdrive switch
Unread postby TonyPDX » Mon Sep 19, 2016 8:52 pm
I am trying to wire the O/D lockout switch on my 4R70W without the Transmission Control Switch Module.
From all that I have read I can apply a momentary 12V signal to PIN 41 to switch the OD lockout on/off. Is this true?
I Read a discussion about making your own transmission control switch module (F4ZF-7E453-AA) so that the OD indicator lamp can be functional. I would like to make the light functional so I know the status and could get trouble codes for the transmission from the light. Do you have any information on this?
Thank you for your help and time.
Regards, Tony
1995 W4HO EEC-IV
1998 4R70W
TwEECer programmer
TonyPDX
User
Vehicle Information: 1966 Ford Bronco
1995 5.8L roller motor, Kenne Bell supercharged
1998 4R70W
1995 EEC-IV W4HO/CBAZA
Pretty much nothing stock....
Re: 4R70W Overdrive switch
Unread postby decipha » Wed Sep 21, 2016 10:21 am
without using the stock module you can enable the tcs switch in the tune and use the tcil output, it works fine on a V6, i did it on my 91 supercoupe, but with a v8 those pins are reassigned so you'll loose those pins
the pin out is on the homepage, look and see
easiest to just use the module on a v8
Unread postby TonyPDX » Tue Jun 13, 2017 10:19 am
Thankyou! I ended up finding a Transmission Control Module.
Best Regards, Tony
TonyPDX
User
1998 4R70W
Return to EEC-V & SN95 Tuning
Users browsing this forum: Bing [Bot] and 3 guests
