Any update on the LA3 strategy?
Unread postby JamesDee » Sat Apr 01, 2017 9:07 am
Can anyone confirm if the T23B.xdf strategy for the LA3 on the Tunerpro site is valid?
I'm looking for an unmodified strategy and bin file so I can use quarterhorse to datalog my factory sensors. I don't want to do any tuning right now.
I'm using the t23b.xdf file with a la3.bin tune with tunerpro v5, and I'm having trouble getting my car to start. If it's a software setting or driver issue, I'll work it out. I just want to make sure the definition and calibration files I'm using work together.
I hope someone sees this "message in a bottle" since the last post here was 2015....Lol.
Thanks.
JamesDee
Vehicle Information: 1984 SVO
Re: Any update on the LA3 strategy?
Unread postby decipha » Sat Apr 01, 2017 2:13 pm
I cant help with the svo's I hadnt seen one since jesus was a baby
regardless, write the stock tune to it and fire it up, then try to log afterwards
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby JamesDee » Sat Apr 01, 2017 3:30 pm
Ok, I might be confused. There is the stock tune (LA3.bin) and then there is the definition or strategy, ie, T23b.xdf or LA3.xls. Don't I need both the tune and the strategy together?
I know quarterhorse can read stock tunes, but when i write to the quarterhorse using Tunerpro, dont I have to load both the tune and the strategy file? Isn't the strategy "gone" once the quarterhorse is on the J3 port?
JamesDee
Unread postby decipha » Sat Apr 01, 2017 9:57 pm
no
you can write the stock tune to it and be done
the definition is only to tune it
you have to have a def file open when writing so tunerpro knows wherevat on the qh to put the tune but thats all
no the strategy isnt gone, the stock tune is disabled and the qh serves the tune, if its the stock tune then it will be the stock strategy
06 Chrysler 300 AWD
Unread postby JamesDee » Sun Apr 02, 2017 10:00 am
Ok, but the def file "to have open" is the file from the "download bin definition files" page on the Turnerpro site, right? My SVO has the LA3 computer so Ive download the Ford T23B bin definition file and saved it as T23B.dxf. So when I open tunerpro, this is the definition file I "select". Unless I can also use Quarterhorse to import the definition off my computer into Tunerpro...
Sounds like should do some reading....
Thanks.
JamesDee
Unread postby decipha » Sun Apr 02, 2017 11:27 am
u lost me
are you trying to save the bin as an xdf?
a bin file is a tune file, the same u can read off the ecu
and XDF file is a definition file, someone has to manually type in each parameter it takes several hundred hours
if your bin file is 56k you can open the gufx xdf and write the stock tune to the QH
06 Chrysler 300 AWD
Unread postby YaBoyHalle » Wed Apr 05, 2017 9:04 am
i had asked sailorbob about it before, the file on tunerpro is the most up to date. he doesn't have a datalogging adx for it either.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Thu Apr 06, 2017 12:40 am
ah i see
well when i get around to it ill toss the universal adx patch in it so you can log with tunerpro wont be for a bit tho
06 Chrysler 300 AWD
Unread postby BlakeFondren » Sun May 14, 2017 11:23 am
this has been a little while, but any progress on the adx patch? i am sitting in mine currently and pulling my hair out fighting it! i keep having crazy issues and trying to figure out what is car and what is tune :| :| :| :|
BlakeFondren
User
Vehicle Information: 89 mustang 4cyl quarter horse work in progress
Vehicle 2 Information: 89 mustang built 2.3 p.i.m.p. ecu
Vehicle 3 Information: 01 silverado turbo hptuners
Additional Vehicles: 02 silverado 2500hd 6.0hptuners
Unread postby decipha » Sun May 14, 2017 2:44 pm
there wasnt enough interest so i never did anythig else with it
06 Chrysler 300 AWD
Unread postby BlakeFondren » Sun May 14, 2017 4:31 pm
well poo! i have 2 and trying to find a datalogging solution has been a chore. i have tunerpro and be, but no luck for me. then to top it off, the icm on the dis decided to die in the middle of tuning today... that really adds to the confusion!
BlakeFondren
User
Unread postby YaBoyHalle » Mon Jul 31, 2017 12:16 am
On the DIS? With an LA3? There hasn't been any progress as far as turbo computers sadly. I moved on to megasquirt.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
cron
