Looking for advice
Looking for advice
Unread postby g3mustang » Fri Mar 18, 2016 6:55 pm
I'm looking to do a svo/turbo coupe swap. What are some of my best options in regards to tuning support, strategies things like that?
g3mustang
Supporting Member
Vehicle Information: 393 s475 b/w turbo 9:1 compresion 185 afr heads c4 trans a9l2 tunning with BE e85
331 180 heads, cobra intake, 50lb injec., cobra maf, anderson cam
Re: Looking for advice
Unread postby decipha » Fri Mar 18, 2016 7:06 pm
theres a few BE defs floating around for the LA3
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby g3mustang » Fri Mar 18, 2016 7:52 pm
So 87-88 turbo coupes.
g3mustang
Supporting Member
Unread postby decipha » Fri Mar 18, 2016 8:26 pm
oh i see now, i thought you meant you had one already
nah best bet would be to use a newer better supported ecu
The 91-93 4cyl C1A1 is completely broken out im BE by derek
otherwise, gufb or cbaza... will do nicely
soon ill be working on a strat for the 2006 eec-v ranger truck ecu, thats only if i cant pull a switch a roo
06 Chrysler 300 AWD
Unread postby g3mustang » Sun Mar 20, 2016 3:12 pm
Use 87-93 computer for turbo four cylinder?
g3mustang
Supporting Member
Unread postby decipha » Sun Mar 20, 2016 4:18 pm
you can yeah, derek broke out the complete c1a1 def
06 Chrysler 300 AWD
Unread postby YaBoyHalle » Mon Mar 21, 2016 12:05 pm
La2 is broken out as well, if you grab that harness it'll work fine until you swap in your distributor less GUFB setup later ;)
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby WhiteLX » Wed Mar 30, 2016 3:56 pm
decipha wrote:you can yeah, derek broke out the complete c1a1 def
Which would be a better starting point? GUFB or C1A1? I'm currently running an LA2 with MAP sensor and distributor.
1986 Merkur XR4Ti
2.3L turbo, crower 5.5" rods, Wiseco 8:1 pistons, ported/big valve head, gutted/ported intake, ported E6 manifold, T04e-44/T3 stgIII @ 21psi, NPR intercooler, Forge 004 BOV, T5 trans, PF3 ECU, VAM to SD conv. 3bar MAP, 55lb injectors, QH, BE, DataQ DI-148U, PLX SM-AFR
1992 Mustang 5.0L notch
stock shortblock, TTI single turbo 60-1 @ 14psi, GT40 irons, Crane 2031, Performer intake, 42lb injectors, A9L, QH, BE, LC-1
WhiteLX
Vehicle Information: 1992 Mustang 5.0L turbocharged
T04S 60-1/P-trim .96 A/R
12psi
GT40 iron heads
Performer intake
2031 cam
Tremec 3550
green 42lb EV1 injectors
Pro-M 42lb 3" Univer MAF
A3M ECU A9L2
Moates QH, BE, EA
Vehicle 2 Information: 1986 Merkur XR4Ti
2.3 turbo
44 Trim T4/stg III T3
19psi
ported head, ported/gutted intake
large NPR intercooler
Bob's log header
55lb injectors
Moates QH, BE, EA
LA2 ECU
SVO John's speed density LA BIN
Vehicle 3 Information: 1998 Explorer 5.0L
2wd/4R70w
stock
PCC1
Unread postby decipha » Wed Mar 30, 2016 11:17 pm
The c1a1 is a much more advanced strat its a significant improvement over the gufb strat
06 Chrysler 300 AWD
Unread postby PoetsRevenge » Tue Jul 31, 2018 2:04 pm
I have a 94 4cyl, dual vane crank + edis setup. I also have a turbo+manifold lying around, is it a lot to swap in a GUFB computer ( I ask because I have one already and wouldn't mind having full tuning capability)
Other than the settings in the tune, do you have to re-pin the ecm to line up with edis and only 4 injectors? (my GUFB came from a 93MAF 5.0)
PoetsRevenge
Vehicle Information: 2001 F150
Vehicle 2 Information: 2001 Mustang V6, swapped to 351W
Vehicle 3 Information: 1998 mustang 4.6 converted to cobra engine
Additional Vehicles: 1997 mustang 4.6 sohc
1984 porsche 5.0 conversion (in progress)
1996 F150 302 build
1999 cobra, converting to forced induction
Unread postby decipha » Tue Jul 31, 2018 4:56 pm
dual vane crank is not edis its dis
i dont know what u mean by repin the ecu but the details are on the homepage in the ignition write up
06 Chrysler 300 AWD
Unread postby PoetsRevenge » Tue Jul 31, 2018 8:59 pm
"re-pin" as in move all the pins in the ECU connector to new locations, or is it just add for the injectors.
I looked at the ignition write up, pulled the files, altering the tune doesn't look like an issue at all. I don't mind adding the wires to give it four injector control spots at all. Is there more that I would have to rewire?
the dual vane with module is dis, not edis? that is probably why i was confused on the connection write up. It didn't make sense to enable "high res" when essentially the dual vane is no better than the pickup in a distributor other than being mechanically more "solid"
So in the tune it's set like any other TFI type setup then?
Here is what i'm seeing to run:
HP_hidres = 0 since it's dis not edis
HP_cid =1 since it does have a cam position
HP_CIDSEL = 0 since cam is a hall effect
MHPFD = .99 Is there a reason not to just move the slider all the way to 1.o?
GUFB doesn't have "ign_type" i don't see DPL_DHP in there either, or am i just missing it? will gufb mind running both coil packs, or am I only going to use 1 of the two?
Is this type module the "grey" "push start" type.. or is this setup the computer controlled dwell? Is there a way to easily tell with aftermarket modules?
as far as running GUFB on only 4 cylinders..
NumCYL = 4
InJ output =4
ENGCYL =4
Sarcharg =140
NUMEGO =1
DEGPIP =180
INJOUT =4
FN1329 ....i have 8 data cells, do i zero the extras, or repeat? ie.. 13421342 or 13420000
FN1327 =1
MHPFD =.99
Now looking through the methods, could someone also run "2" HEGOS, and set it to "bank fire" , change the number of injectors per output to "2" set the number of injector outputs to "2" assign the each cylinders in the injector ouput port mapping to their respective banks, and run it like that? would that also be an option, or not a good idea with GUFB? I mean it would look really cool with two little tiny fabbed manifolds two tiny turbos and a dual setup :D :D
If you were going to use EDIS with the 35? tooth crank wheel What computer would be your first choice, and what donor would you look for? a 4.6 computer? I assume individual coil might be a bit of a pita and not really worth any benefits it might have over waste spark coil packs.
PoetsRevenge
1996 F150 302 build
Unread postby decipha » Tue Jul 31, 2018 11:14 pm
sounds like u got it
dis is an external tfi and is ccd
no leave it at .99, 1 is an incorrect value
the ecu doesn't control the coils the tfi module does - dis module
those other scalars dont exist in gufb just ignore
fn1329 the leftovers doesn't matter
yep you can do dual hegos if you want, not ideal on a 4 cyl since idle conditions and low exhaust flow conditions could cause some incorrect hego readings, thats why no manufacturer has ever ran dual hego control on a 4cyl to my knowledge, but go ahead and try it out and report back, keep in mind the hegos go in the downpipe after the turbo, hegos can never be mounted pre turbo
if your going edis the best option is to use the best eec-v, the 03-04 luxury sedan ecu and RZASA on the homepage, youd have to configure it correctly and may have some issues with the firing order on crank but I would give it a try if the opportunity presented itself.
06 Chrysler 300 AWD
Unread postby PoetsRevenge » Thu Aug 02, 2018 10:19 pm
is there any real advantage to SFI on these compared to just setting it to bank fire?
can i set it to "1" bank, and not have to rewire injectors, if i set "inj to output" number to 2 so that it knows there are two injectors per output pulse?
The current computer puts 1&4 on injector output "1" of gufb, and 2&3 on inj #2 of gufb
PoetsRevenge
1996 F150 302 build
Unread postby decipha » Fri Aug 03, 2018 2:44 am
not really but every little bit helps, no reason not to
i dont see why you couldnt
be aware that the svo uses low impedance injectors, you will have to swap to high impedance to use any other ford ecus
06 Chrysler 300 AWD
Unread postby PoetsRevenge » Tue Aug 07, 2018 10:12 pm
I knew that from long ago, learned it the "hard way" back in 2002 lol
This is in a pickup still has the stock 2.3 ranger injection on it. I didn't swap anything on yet, setting up a computer i can tune, making it run on that is going to be my first step on this build, then I'll start modifying components. I figure once i know my computer options, i'll build within the limits of what i can easily control This is after all, primarily a gas milage little pickup for running errands, i'd just like for it to not struggle to go up a small hill with 90hp lol
I was thinking of just picking up some 48 lbs ebay injectors to keep the cost down, since V8 sets are less than 100$ typically, once i have a comp i can tune, since having a stock motor under it and that being the only mod, should make it relatively easy to dial them in.. Then i'll add the charger and just a bit of boost.
PoetsRevenge
1996 F150 302 build
Unread postby decipha » Tue Aug 07, 2018 10:41 pm
I would never buy or recommend getting injectors off ebay most are junk, best to buy direct from a wholesaler so you know your getting genuine pieces
call chris at power adder solutions and get a set of 4x 80lb injectors, should be less than $200
would be much cheaper than buying a hundred $ set of injectors off ebay, spending countless weeks and months trying to dial it in just to wash down the engine and have to rebuild it then spend an addition $200 to buy good injectors and toss your ebay ones in the trash
significantly cheaper and easier to do it right the first time
06 Chrysler 300 AWD
cron
