1/4 mile passes, warm or cold?
Forum for racing results, dyno pulls, track vids, etc... include time slip and/or link(s) to video(s) if you have them
Unread postby Squishy » Sat Aug 13, 2016 11:45 am
Some guys push there car to the line, fire it up, burnout and make a pass, others drive it to the line, any advantage to one over the other?
Should get to the track this month or early next, and just wondering, I had always just drove to the line with the car already warm?
Squishy
Supporting Member 35
Vehicle Information: 91 5.0(302) Stock Shortblock, A9l, QuarterHorse, F-303 (4*A), Crane Gold 1.6rr's, Edelbrock Performer 60379 Heads, TrickFlow-R Intake, PMAS-HPX-E 100mm Housing MAF, ACT Sensor Mounted In Discharge Tube Before Throttle Body, AFM 4" Power Pipe ,SD 80lb Injectors, Stock FPR@39PSI, GSS 340(255lph High Pressure) Fuel Pump, 70mm ThrottleBody, Vortech V3sci 10-rib 8" Crank 3.33 Blower Pulley, Vortech Mondo BPV, NX/Snow Stage 1 Meth Kit - 625ml/min Nozzle, 1-5/8" BBK Equal Length Headers, 2.5" BBK H-Pipe, 2.5" Flowmaster Origional 40 Cat Back, Taurus 2 Speed Fan, No Smog Pump. No EGR. T-56 Magnum (Close Ratio)
*WBo2-C*
Re: 1/4 mile passes, warm or cold?
Unread postby StangD » Sat Aug 13, 2016 12:20 pm
Opinions vary. I prefer warmed up, not hot. Cold engines wear far faster. Severely heat soaked intakes slow you down. You'll see a lot of trailered car guys driving around the pits to get the differential and tranny fluid warmed up some. If I can leave the line around 180F I am happy. She is plenty warmed up when I get to the other end of the track. :)
CBAZA-TM40
12.1 @119.50 NA
StangD
Supporting Member 25
Unread postby yeastieBoB » Sat Aug 13, 2016 4:45 pm
I also prefer it to be warm, but not hot/cold. I usually can't manage to keep it under operating temp though and most of my passes are made at 195*.
Good luck at the track Squishy. Make sure all your safety gear is up to snuff.
yeastieBoB
Unread postby Squishy » Sat Aug 13, 2016 9:57 pm
Good call ill have to make sure the cert. On my helmet is up to date
Squishy
*WBo2-C*
Return to Racing & Dyno Results
