Tire size, recommendations, launching
Forum for racing results, dyno pulls, track vids, etc... include time slip and/or link(s) to video(s) if you have them
Unread postby Fasterthangas » Sat Nov 28, 2015 4:27 pm
I currently run Nitto 555 tires. Rears are 315/35 ZR 17 They actually measure about 25.5" tall.
If I were to hit the track; I don't think I can get a decent launch with these tires and I suspect more sidewall is recommended.
I'm not much of a track guy so I hate to fork out a wad of cash for a one or two day thing.
I'm not sure how to launch if I used the existing tires or bought new ones.
My converter is a 2800 stall. Gears are 4.10's.
Suspension wise; I'm crippled also. Rear arms are BBK units and springs are Eibach Pro's with progressive rate. Front springs appear to be stock but the front is lowered.
I'd like to get some sort of consistency to optimize my tune.
If I bought some sort of drag radials; do they grip in the corners for sporty driving out of town? Not much rain to worry about here.
Fasterthangas
Vehicle Information: CBAZA
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
230/238 @ .050 custom cam
AFR Renegade 185 heads
Ford Racing EV14 34lb. injectors
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
1-3/4" shorty headers into 2.5" duals out the back with H pipe. Jones Maxflow straight through mufflers
Re: Tire size, recommendations, launching
Unread postby decipha » Sat Nov 28, 2015 6:03 pm
315*0.35*2*.03937=8.68 + 17 = 25.68" diameter
it may be best to foot brake her at 1200 or so and see how she hooks
Unread postby Fasterthangas » Sat Nov 28, 2015 6:17 pm
decipha wrote:315*0.35*2*.03937=8.68 + 17 = 25.68" diameter
So pretty much baby it off the line. I assume that I want to lower the pressure in the rears?
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Sat Nov 28, 2015 6:22 pm
Its street tires no need in trying to go to far with it, no need for a burn out, maybe drop em to 28 or so
you dont want to baby it you want to find the sweet spot where it hooks the best, ideally you want a slight spin and not a dead hook that bogs it down
Unread postby Fasterthangas » Sat Nov 28, 2015 6:33 pm
decipha wrote:Its street tires no need in trying to go to far with it, no need for a burn out, maybe drop em to 28 or so
Gotcha. That's very much like we did in sand drags.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Sat Nov 28, 2015 7:19 pm
yep same principle for all racing really, you want to find the optimal spot where you can get the most traction/power ratio
Unread postby bunso » Tue Dec 08, 2015 8:06 pm
Those Nitto 555's will never hook. I tried them all the way down to 18psi and still blew them off. Way too hard of a tire. However they will last forever tho
bunso
+Premium Plus Member
Vehicle Information: 2004 GT MMR Streetmod 900, On3 76mm turbo, 4r70w. (Still in Process)
Unread postby bunso » Tue Dec 08, 2015 8:08 pm
If your dead set on a decent hooking street tire after I could not get the 555's to bite I swapped over to the NT05 and it actually hooked pretty good for a street tire
bunso
Unread postby decipha » Tue Dec 08, 2015 10:50 pm
Ive had excellent experiences with the nitto 555s, I could pull a 1.7 60' in the rain
I had a set on my 98 camaro ss 6spd and I loved them
Unread postby Fasterthangas » Wed Dec 09, 2015 4:22 pm
You'd think with a 315 Nitto 555 in the rear that I'd hook up. It ain't happening. I suspect that the car doesn't have good weight transfer to the rear. The rear arms are BBK's with poly bushings. From what I've read; they need to go. Stiffer lowering springs hurt weight transfer also.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby StangD » Sun Dec 13, 2015 5:50 pm
Never found a drag radial that would hook anywhere near as well as Mickey Thompson. They don't last as long as Ntito or BFGs either.
94 Mustang GT-T5-347(Fordstrokers DIY)-TF190s,FTI Cam,Ported Victor EFI,42s-LMAF,85MM TB-Nitrous-Suspension mods and DRs.
CBAZA-TM40
12.1 @119.50 NA
Pulling baby wheelies and breakin stuff.
StangD
Supporting Member 25
Vehicle Information: 94 Mustang GT T5 CBAZA TM40
347 TF190-Victor EFI-LMAF- 85MM TB- 42s,4.10s-DRs
Return to Racing & Dyno Results
cron
