5.4 cyl heads
5.4 cyl heads
Unread postby xalibo » Sun Mar 20, 2016 4:19 pm
Hey Mike I can grab a set of 2v heads off of a 2005 E350. Are they the same as the 2000 L heads.?? Should both be PI heads I guess. The price is right.
I have to call the guy tomorrow.
Kauffman Engine Services
xalibo
Speed Shop Owner
Vehicle Information: 1995 SVT F150, Lightning, Speed Dens. LHBLO/ICY1, Sailor Bob strat. Engine & Trans redone,
chassis rebuilt, Mostly a tow wagon but starting to make changes. Finally have BE
, EA working. Current Eng. --5.8 .020 over, KB FT pists,.bigger valves, Bowels ported.1.6 roller rocks.Balanced,
. GT40 3bar hds, Bowl job, Comp roller cam,214 & 224 @ 050. 114 LC. .510 lft. 10:1 Comp,E4OD trans, TransGo kit, Stk. conv. 1 3/4 long tube headers, 3" duels. 50# inj. Vortec "T" trim,14# boost, 4.11 rear gears. DIY water injection. MSD box & coil, smog pump crankcae evac syst,
Vehicle 2 Information: 2000 SVT F150 Lightning, low miles , All stock, highway machine,from 70 up she's a beast
Vehicle 3 Information: 88 mustang GT . 302 CI, Iron GT40 heads , not P's , bowls blended, F303 cam 8.7 Comp.
42# green top Injectors, Saleen intake, 76 MM TB, Vortec SC , 15# @ 5800, #AP103 Autolite,
55# Fuel Press, 10 deg. Initial, C&L green tube 76 mm, stock 55mm Ford sensor, screened
meter inlet, T5 trans, 3.70 rear, 1 3/4 BBk long tubes, bbk x pipe, 2 1/2 exh, 93 /E10 fuel
Re: 5.4 cyl heads
Unread postby decipha » Sun Mar 20, 2016 4:30 pm
afaik the 5.4 heads are all the same the only difference being that the 2003+ heads have the extra spark plug threads where as the 02- only have 4 threads
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Re: 5.4 cyl heads
Unread postby xalibo » Sun Mar 20, 2016 4:36 pm
I though that was the deal,thanks
xalibo
Speed Shop Owner
Re: 5.4 cyl heads
Unread postby xalibo » Sun Mar 20, 2016 8:27 pm
Yo Mike , Bored as hell tonight. TV sucks. I bought that core motor with the PI 8 thread heads and got a steel crank and all the small parts with it.
timing cover for a van is different but no biggie. I will start working on a short block when gen 1 is done. Take er easy mate...
xalibo
Speed Shop Owner
