Header Gaskets
Header Gaskets
Unread postby thequietman45 » Mon Oct 29, 2018 5:05 am
Good Morning,
I have a blow out on #3 exhaust port on a 351W block. I am using JBA coated shorty headers along with soft aluminum header gaskets. The bottom of the port has the blowout and the bolts are tight. What is a better gasket?
thequietman45
Vehicle Information: 1995 Bronco;
Fiveology racing MAF conversion with F5TF-12A650-JB. QH with BE 5.138 and EEC analyzer.
Re: Header Gaskets
Unread postby decipha » Mon Oct 29, 2018 6:11 am
check out rim flex
Re: Header Gaskets
Unread postby gamh44 » Mon Oct 29, 2018 1:32 pm
Is there a sealant that is worth using in this situation?
gamh44
Re: Header Gaskets
Unread postby decipha » Mon Oct 29, 2018 5:14 pm
I've used copper rtv sealant before with no problems. In fact on the supercoupes they come from the factory with no exhaust manifold gaskets. On those cars we have always just tossed some rtv on there and never a problem. YMMV
Re: Header Gaskets
Unread postby thequietman45 » Mon Oct 29, 2018 5:55 pm
Thanks, I will give that a try.
Appreciate the help. I finally got some feedback on my tune and the bronco runs solid...……………... great AFR according to my LC2. Then I heard that dang tick tick tick
thequietman45
Re: Header Gaskets
Unread postby SlowBox » Tue Oct 30, 2018 7:24 pm
I use straight red rtv on my turbo manifolds. Works mint.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: Header Gaskets
Unread postby thequietman45 » Wed Oct 31, 2018 4:38 am
Ok, thanks. I got it fixed. The last bolt took almost an hour...very hard to get a wrench on it due to the header. I ground the edge off a 3/8" craftsman to fit.
Brute force and ignorance :D
thequietman45
