Maf recommendations?
Unread postby kx250pilot » Sat Jul 07, 2018 3:54 pm
I'm can't decide which MAF sensor to use for my build. It's a 94 cobra, basically stock engine with Anderson b-21 camshaft and an on3 kit. What maf would you use?
kx250pilot
Vehicle Information: 1994 Ford Mustang Cobra
Stock 302, gt40, 24 lbs injectors
J4j1 Binary editor with quarterhorse
Off road h pipe
Cam duration @.050 222 int 232 exh
Valve lift with 1.7rr .540 int .565 exh on a 112
70MM throttle body and cold air
Re: Maf recommendations?
Unread postby decipha » Sat Jul 07, 2018 4:06 pm
best maf for all applications is the pmas hpx e
Unread postby kx250pilot » Sat Jul 07, 2018 4:39 pm
Thanks man.
kx250pilot
Off road h pipe
Unread postby kx250pilot » Sat Jul 07, 2018 5:43 pm
Just ordered the hpx e in a 3" tube. I looked on your reference chart and see hpx, but this wouldn't work for the hpx e, right?
kx250pilot
Off road h pipe
Unread postby decipha » Sat Jul 07, 2018 5:46 pm
that is for the hpx e
Unread postby OleBlue » Fri Oct 05, 2018 9:30 pm
decipha wrote:best maf for all applications is the pmas hpx e
My apologies for the thread jacking.
Is there a draw through MAF that you would recommend? I don’t have the space for a blow through using a Vortech kit.
OleBlue
Vehicle Information: ‘95 Mustang GT: 306, e7 heads, .512 lift cam, T-Moss ported HO lower intake, stock HO upper. Vortech v3 6-8 psi. 19# injectors, stock MAF, FMU, in-line fuel pump, oem in-tank pump. Dyno tuned sct chip. 332 rear horsepower.
Unread postby decipha » Sat Oct 06, 2018 12:46 am
pmas hpx-e will still work
Unread postby OleBlue » Sun Oct 07, 2018 8:59 am
decipha wrote:pmas hpx-e will still work
Vortech’s kit puts the MAF and filter in the fenderwell. Will the hpx-e work there, or will it need to be relocated? Is it plug and play (other than tuning) or is there something hardware wise that needs to be done to use a blow through as a draw though application?
If I were to switch to 42# injectors and the hpx-e at home would I be able to drive it to the dyno or would I have to have a trailer?
OleBlue
Unread postby decipha » Sun Oct 07, 2018 7:31 pm
no blow through and draw through makes no difference to any maf sensor itself, all the maf does is measure the air coming across it cooling the element
anytime you switch injectors or maf you have to retune
best bet would be to get a quarterhorse and work all the bugs out before taking it to get dyno'd, not only is it cheaper and saves you any diagnostics fees but it makes the tuners job easier and gives you control of the tune
