4r70w swap woes
4TAD / E4OD / AODE / 4R70W / 4R100 / 4R75W / 5R55S/E / 6R80
4r70w swap woes
Unread postby SlowBox » Tue Aug 21, 2018 1:14 pm
Got the trans in and the car running after the U4P2/4r70w swap and now it's time to dial it all in. I figured out most of what I need to know regarding how the new ecu runs the engine and the trans but it's a little quirky and I'm not sure if it's wiring, pins I put in the wrong place, a shit trans or leaky valvebody, or a crappy tuner.
First question is about what functions or what scalar would cause the ecu to command 3rd gear during tip-out at highway speeds?
Attached is my dookie tune, but no logs. Next time.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 4r70w swap woes
Unread postby SlowBox » Wed Aug 22, 2018 2:29 pm
It's not doing it until I beat on it and TOT is over 220. Still have yet to find anything commanding a downshift. Maybe I'm not commanding enough CT line pressure?
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 4r70w swap woes
Unread postby Thicklovin » Wed Aug 22, 2018 4:40 pm
I can possibly compare it to mine and see what ya got going on. I’ll try and upload mine as well. It’s not perfect. I just got mine driving really well but some issue when it’s cold and hot. edit. i see your running tunerstudio im on be.
Thicklovin
Vehicle Information: 92 lx Turbo CBAZA Sailorbob strat and U4P2.
11.6 @ 122
Re: 4r70w swap woes
Unread postby SlowBox » Wed Aug 22, 2018 5:38 pm
Yeah, I use TunerPro. No BE dongle here.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: 4r70w swap woes
Unread postby SlowBox » Sat Aug 25, 2018 5:52 pm
Turns out it couldn't hold the OD band when I closed the throttle. Increasing the bottom cells of fn616f to 18 fixed this problem.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Return to Transmission Tuning
