89 Bronco 393W Tune Review
Unread postby ironmanisanemic » Sat Oct 05, 2019 9:13 pm
CUSTOM TUNING VEHICLE INFORMATION
http://www.efidynotuning.com rev.2019-07-11
__________________________________________________________
FORUM USERNAME (if applicable):ironmanisanemic
TELE#:
EMAIL:
DATE:
ESTIMATED ALTITUDE (FT):
POSTAL ADDRESS (FOR SHIPPING ONLY):
Zip Code: (required for altitude):98665
TUNE SERVICE TYPE [DYNO/REMOTE/ONLINE/PCM-SHIPPED]:
---IF DYNO TUNE---
IS VEHICLE BEING DROPPED OFF [Y,N]:
IS VEHICLE DRIVEABLE [Y,N]:
LICENSE PLATE#:
HOW DID YOU HEAR ABOUT EFIDYNOTUNING:
REFERRER:
PRE-TUNE CHECKLIST VERIFIED [Y,N]:
If NO, Verify the Pre-Tune Checklist (linked above) Before Proceeding!
IS VEHICLE 100% READY TO BE TUNED [Y,N]?
LIST ALL DEFICIENCIES/COMMENTS/NOTES BELOW:
VEHICLE YR/MAKE/MODEL: 89 Ford Bronco
VEHICLE WEIGHT:
PCM/ECU CODE: U4P0
TUNING DEVICE (None,SCT,QH,Tweecer,etc): QH
TUNING SOFTWARE (BE,TunerPro,Caledit,SCT,etc): BE
PRIMARY VEHICLE USE (street,strip,weekend,show,daily,etc):Daily/offroad
IS THIS YOUR PRIMARY VEHICLE[Y,N]:N
PREFERRED IDLE RPM: 750
DESIRED REV-LIMITER RPM:
BILLET OIL PUMP GEARS [Y,N]:N
THROTTLE BODY SIZE: 75MM
BRAND AND PART #: Summit Racing
TRANSMISSION TYPE [AUTO,MANUAL]:Auto (4R70W)
Gear Ratios: 1st: 2nd: 3rd: 4th: 5th:
REAR WHEEL TIRE SIZE: 31x10.5R15
REAR GEAR RATIO: 3.54
TQ CONVERTER MAKE & STALL SPEED: Stock 99 Explorer
TRANS FLUID TYPE & SPEC: Mercon III
ENGINE BLOCK SPECS: Stock 351W
STATIC COMPRESSION RATIO: 10.5:1
CUBIC INCH DISPLACEMENT/LITERS: 393
CYLINDER HEAD BRAND, MODEL# & SIZE: Unknown aluminum heads (got second hand, probably pro comp)
APPROX. HOW MANY MILES ON ENGINE?:3000
INJECTOR SIZE/BRAND/COLOR: Ford stock coyote
INJECTOR PART NUMBER:
INJECTOR PURCHASE PRICE $:
INJECTOR VENDOR PURCHASED FROM: Ebay
FUEL SYSTEM TYPE [STOCK,RETURN,RETURNLESS]: stock return
ADJUSTABLE FUEL PRESSURE REGULATOR [Y,N]: y
AFPR MAKE & MODEL#: Summit Racing
BASE FUEL PRESSURE: 39
FUEL PUMP QUANTITY & SIZE [LPH]: Walbro 255L
FUEL RAIL SPECS:
MASS AIR FLOW SENSOR TYPE: Pro-M
MAF TUBE/HOUSING SIZE:
MAF/INLET PIPING SIZE: 80MM
MAF CALIBRATION SIZE:
MAF CALIBRATION VEHICLE:
MAF CALIBRATION CURVE [Ex: GT,COBRA,SC,etc...]:
MAF BLOW-THROUGH or DRAW-THROUGH:
ADDITIONAL MAF NOTES/COMMENTS:
***IF MAF FLOW SHEET IS AVAILABLE, LIST HERE OR ATTACH BELOW***
Volts KG/HR
15.9998 1542.585
5 1542.585
4.7998 1381.888
4.5999 1233.865
4.3999 1097.248
4.2 971.5292
4.0999 912.7255
3.8999 802.4684
3.7 702.35
3.5 611.1028
3.2998 528.7268
3.2 490.7072
3 419.9906
2.7998 357.1314
2.5999 301.1158
2.5 275.7693
2.2998 229.1319
2.0999 188.5775
1.8999 153.346
1.7 122.9303
1.5999 109.7501
1.3999 85.92445
1.2 65.90076
1 49.42557
0.7998 36.24541
0.7 30.6692
0.5 21.29101
0.2998 14.19401
0.0999 9.12472
0 7.350469
FUEL TYPE OCTANE & GRADE: 93
FUEL QUALITY [POOR,FAIR,AVG]: AVG
METH INJECTION NOZZLE GPH:
METH ACTIVATION TYPE OR PSI:
N2O SHOT / NOZZLE SIZE:
N2O Wet/Dry Shot:
N2O Bottle Warmer Present [Y,N]:
N2O WOT Safety Switch [Y,N]:
POWER ADDER TYPE [Turbo,SC,n2o]:
TURBO/SC MAKE/MODEL#:
TURBO SIZE & AR / PULLEY SIZE:
#s BOOST MAXIMUM:
BOOST CONTROLLER PRESENT [Y,N]:
BOV/BYPASS LOCATED BEFORE OR AFTER MAF?:
CAM SPECS:
Intake Lift: Duration: Centerline:
Exhaust Lift: Duration: Centerline:
Rocker Ratio:
Intake Manifold:
CAMSHAFT COMMENTS:
***IF CAM CARD IS AVAILABLE, ATTACH FILE AT BOTTOM***
Serial # I 8064-06 Spec Card# 10762606
Part # 35-000-8RF CAMSHAFT, FW FORD 351W HR RETRO-FIT
Core C35-8Q CAMSHAFT BLANK, FW 351W RETRO AUSTEMPERE
Grind # FW 3613B /3299S HR112 +4 RF
DURATION @ .050 INTAKE 230 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 236 INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3210 EXHAUST 1.60
VALVE LIFT INTAKE .513 LOBE LIFT EXHAUST .3290
VALVE LIFT EXHAUST .526 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 108.0
TAPPET LIFT INTAKE 282 CAM ADVANCE 4
TAPPET LIFT EXHAUST 289 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 7 JOURNAL DIAMETER STD 2.036
VALVE OPEN EXHAUST 54 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 43 DEPARTMENT P
VALVE CLOSED EXHAUST 2
EXHAUST HEADER TYPE [LONGTUBES/MID/SHORTY]: EQUAL LENGTH SHORT TUBE
EXHAUST CROSSOVER TYPE [X,H,Y-PIPE]: Y PIPE
EXHAUST PIPE SIZE, SPECS, & COMMENTS:2.5IN MERGED INTO 3IN
o2 SENSOR AGE & MILEAGE:NEW WITH ENGINE
WIDEBAND PRESENT & MODEL#: Innovate LC-1
WIDEBAND WIRED IN TO PCM? [Y,N]:Y
***IF YOU HAVE YOUR WIDEBAND TRANSFER, LIST HERE OR ATTACH BELOW
IGNITION COIL TYPE: MSD
DISTRIBUTOR TYPE: MSD
SPARK PLUGS BRAND, ITEM #, and GAP:Autolite
SPARK PLUG WIRES, SIZE, BRAND & AGE: Ford Motorsports 9mm
IGNITION BOX TYPE & AGE:
***BASE IGNITION TIMING MUST BE 10 BTDC ON DISTRIBUTORS***
IS BASE TIMING AT 10 dBTDC [Y,N]?: y
ELECTRIC FANS PRESENT [Y,N]: n
HIGH AND LOW WIRED TO PCM:
COOLANT THERMOSTAT TEMP: 180
AIR CHARGE TEMP SENSOR LOCATION: intake
QUICK CHECK LIST:
DOES ENGINE BURN OIL? [Y,N]: n
IS FUEL FILTER NEW? [Y,N]: y
ARE SPARK PLUGS NEW? [Y,N]: y
CAP AND ROTOR NEW? [Y,N]: y
SPARK PLUG WIRES NEW? [Y,N]: y
AIR FILTER NEW? [Y,N]: y
O2 SENSORS NEW? [Y,N]:y
EXHAUST SEALED NO LEAKS? [Y,N]: y
IS BASE TIMING AT 10 dBTDC [Y,N]: y
FIRING ORDER VERIFIED [Y,N]: y
LIST ANY ADDITIONAL VEHICLE DETAILS/COMMENTS/NOTES BELOW:
(ERASE THIS TEXT AND EXPAND THIS SECTION IF NEEDED)
___________________________________________________________
http://www.EFIDYNOTUNING.com - EFI Dyno Tuning LC - New Orleans, LA
I just finished installing a 4R70W in place of the AOD that came in the bronco. I copied over the trans parameters from a 95 F150 CBAZ0. I have no real issues with my tune before the swap, other than now i have no idea how to optimize the trans portions. The trans is a stock unit out of a 5.0 98 explorer, so it shifts pretty softly, but i dont know if i need to adjust the tune, a j-mod, or both to make its shifts feel firmer and crisper. I dont have any datalogs yet or been able to fully vet out the trans yet due to the registration being expired.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, FRPP LU34 34LB injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. 4R70W
Re: 89 Bronco 393W Tune Review
Unread postby ironmanisanemic » Mon Oct 07, 2019 8:28 pm
So i went through the trans write up, and made the recommended changes. It feels better, but shifts are still vague and feel very soft like i was driving a Cadillac. I ran out of time yesterday, and didnt get to fire up tunerpro to pull an unencrypted bin for you. I still dont know if it would benefit to do the jmod or if i can get it to shift firmer without it.
ironmanisanemic
A+ Contributor
Return to <<--Tune Review-->>
