Base Tune Review
Base Tune Review
Unread postby Someone82 » Sun Sep 15, 2019 8:42 pm
Trying to get a base Tune started for my 93 Cobra which I have recently Supercharged with a Vortech V3 unit and I want to eliminate the FMU all together.
Started with the A9L2 Base, punched in my injector and MAF information and divided Load Scaling by 1.5
Running extremely Rich (have to start by holding throttle WOT), once running AFR is 13-12:1, will not go closed loop. because of this we have not moved passed startup tune.
Someone82
Premium Member
Vehicle Information: 1993 Mustang Cobra
Vortech non intercooler V3, 6lb kit
moates qh, wbo2-C, prosport
Re: Base Tune Review
Unread postby decipha » Sun Sep 15, 2019 9:47 pm
i deleted your vehicle info since you had personal info in there
you clipped your maf to 980 ad counts thats not good you should always take it to 1024 ad counts
i have no idea what you were trying to do with the dashpot decay but thats surely not helping
the bottom of fn035 must stay at 2.00 load
your cranking pw was significantly high. I lowered your cranking pw to help her fire off without having to do flood clear mode == pedal at wot
you had the top cell of the injector offset at 0, i see you interpolated 9 volts ... very good job
your making dialing in the maf significantly harder by using those in between maf points.. i simplified it to round numbers that match the histogram to make it simple
what load scaling are you referring to? your sarchg is still set for a 302 and you have your actual maf and injector data in so your tune is not scaled. I see you cut fn035 back which is just wrong.
you didn't add any timing to the spark table for your gt40 heads. I added 5 degrees across the board.
you'll see some background changed I made to bring you up to date to the latest a9l2 which hasn't been posted yet.
200 0
190 -10
175 -12
from 174 to 189 the hegos didn't switch since it was still trying to ramp back lean when you stabbed the throttle again so it failed the hegos since it exceeded byples and went in to open loop. I kicked up byples to 60 (same as stock) since your o2s seem to be working perfectly.
The reason why it did that is because you cut fn035 down when you shouldn't have and you also shouldn't be snapping the throttle like that either until you get the fuel dialed in.
you were idling near 170 maf counts so i reduced it there 12%.
at warm stable idle ipsibr is at .300 adding 300% more air to maintain idle than it should. You need to open the throttle stop by about 1/2 of a full turn to give it more air to idle correctly.
Otherwise she looks excellent. This should help you out.
All you have to do is dial in the maf, fn035, the isc multiplier table and then dashpot in that order and you should be golden.
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby Someone82 » Wed Sep 18, 2019 9:33 pm
Great, thank you as of now starts and idles better then OEM, will start dialing her in this weekend!
Here is the new datalog.
Someone82
Premium Member
Unread postby decipha » Wed Sep 18, 2019 10:40 pm
still not enough ipsibr was red at .1 before the end of the log. You need to open up the throttle stop more still.
06 Chrysler 300 AWD
Unread postby Someone82 » Thu Sep 19, 2019 8:24 am
I didnt notice that, thanks, do I want to aim for .00?
Someone82
Premium Member
Unread postby decipha » Thu Sep 19, 2019 1:42 pm
yes ideally you want a 0% correction but if its just over < 0.05 thats fine
06 Chrysler 300 AWD
Unread postby Someone82 » Sun Sep 22, 2019 6:28 pm
For future Reference, I will be having to pass smog, I know the EGR comes automatically disabled in A9L2, is there anything else I need to re-enable for smog?
Will the EGR affect the tune much when enabled?
Someone82
Premium Member
Unread postby decipha » Sun Sep 22, 2019 6:31 pm
nope
nope
06 Chrysler 300 AWD
Unread postby Someone82 » Sun Sep 22, 2019 6:42 pm
Love it! To confirm, from what I'm seeing from your ADX file, the wide band values that you have entered are already set for Pin 27, correct?
Someone82
Premium Member
Unread postby decipha » Sun Sep 22, 2019 6:54 pm
yea tunerpro is ready to go rifht out of the gate no user setup required
simply right click on the wideband on the dash and select your from the list
http://www.efidynotuning.com/config.htm
06 Chrysler 300 AWD
Unread postby Someone82 » Sun Oct 06, 2019 2:20 pm
Moving along slowly, but I feel I'm making progress (life vs toys :) ). I have idle and drive-ablity at a happy medium currently, Dashpot still needs work but it's livable for now.
Being boosted I feel like I might be doing something backwards, when I have throttle tip in I'm leaning out on lambda and I did the 1/2 throttle pull today and the car stayed right at Stoic practically. I didn't hear any detonation as I have pulled a degree of timing.
Could you take a look at these logs? drive100619 is a short drive i did to my house and the other is my 1/2 throttle pull.
Someone82
Premium Member
Unread postby Someone82 » Sun Oct 06, 2019 6:30 pm
Well shoot... something just dawned on me. I have an adjustable fuel pressure regulator (I know I know), I just set it to 55 psi as you state and now I'm going to re run my load scaling and MAF Transfer numbers.
Idles much better now :)
Someone82
Premium Member
Unread postby decipha » Sun Oct 06, 2019 6:37 pm
fuel pressure doesn't change the maf just the injector data
06 Chrysler 300 AWD
Unread postby Someone82 » Sun Oct 06, 2019 6:55 pm
SO then I should leave the load scaling and MAF transfer alone? I feel like I'm completely starting over now. I just perload histogram and now have a multiplier of .85+/- across the board.
Someone82
Premium Member
Unread postby dleach1407 » Sun Oct 06, 2019 8:00 pm
Yes. The maf transfer tells the computer how much air is going into the engine, it is not affected by injector changes. The High/Low/breakpoint are the variables used for fuel injectors you need to change. If you increase your fuel pressure, your injector slopes and breakpoint all need to be multiplied by the percentage of change. If you went from 39 to 55 you would multiply all of those variables by 1.16 Since 55-39 is roughly 16psi. You can approximate 1% per 1 psi increase.
A+ Contributor
Vehicle Information: 1995 Mustang T5 CBAZA/T4M2 Moates QH BE or TpRT
331 10.2:1 compression, TFS 11r 190 56cc heads
HPX MAF 3.25 OD tube with SaxonPC air straightener
F303 Cam, 1.6 Miller Mid-Lift rockers
T5 with an XTD clutch that somehow holds my power
80lb Dekas, Stock lines and rails 340LPH in tank
Minor upgraded T5 with counter gear stiffening plate
76mm On3 turbo, HP hotside, Custom coldside
560WHP and 606TQ 8lbs tapering to 6 91 octane
27degrees total timing.
Vehicle 2 Information: 1957 Ford F100
Mustang II front suspension -done
C-notched rear frame - done
Luxury ECU using RZASA - have
Fuel injected explorer 302 - have
4r70W -have
Lots of stuff planned including air bags and twin 55mm turbos.
Return to <<--Tune Review-->>
