tune check
tune check
Unread postby brewster » Sun Jun 23, 2019 4:43 pm
Attached is the tune I've been working with if you guys can take a peak at it. Running A9L2 with mechanical idle mod. It starts up cold fine and warms up good but I find the fueling isn't very stable. I think most parameters are entered correctly for injector info as per the injector data reference. Biggest issue atm is it doesn't want to warm start unless I floor it and then it doesn't want to idle unless I touch the throttle and help it along. Attached is a warm idle log, free rev log between a couple a imaf points and then a retry of starting warm. Thanks in advance for taking your time to check it out if doing so.
brewster
Vehicle Information: 1992 fox A9L2 GUFB 347 10.5:1, AFR 185cc, Tremec TKO600, 373, Multi port NOS
Vehicle 2 Information: 2014 mustang gt, cai, short shifter, bama tuner,
Re: tune check
Unread postby brewster » Sun Jun 23, 2019 4:49 pm
just one more of a warm start to idle. Whats the best way to lower idle rpm a bit as if I close the throttle screw any it messes it all up and doesn't want to re start or idle correctly. I ve also tried closing the throttle screw and resetting kams. also very shakey idle like its lean shaking even at stoich
brewster
Re: tune check
Unread postby brewster » Sun Jun 23, 2019 5:47 pm
oups forgot to post my tune. Just realized am I posting in the wrong section and is this supposed to be sent down to the tune review section of the forum?
brewster
Re: tune check
Unread postby decipha » Sun Jun 23, 2019 8:09 pm
u made two threads, i deleted the other
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Re: tune check
Unread postby brewster » Sun Jun 23, 2019 8:45 pm
No problem, I realised after that there was a tune review section. This fricken car is doing some funky stuff that is beyond me that's for sure. Even my last idle log the lambses are climbing all the way up to 1.250 etc. Unstable idle hunting etc. I'm missing something
brewster
Re: tune check
Unread postby brewster » Mon Jun 24, 2019 9:48 pm
CUSTOM TUNING VEHICLE INFORMATION
www.efidynotuning.com rev.2018-05-23
__________________________________________________________
FORUM USERNAME (if applicable): Brewster
TELE#: 780 554 5609
EMAIL: brewster_ryan@yahoo.ca
DATE: June 24 2019
ESTIMATED ALTITUDE (FT): 2221'
POSTAL ADDRESS (FOR SHIPPING ONLY):
TUNE SERVICE TYPE [DYNO/REMOTE/ONLINE/PCM-SHIPPED]:
---IF DYNO TUNE---
IS VEHICLE BEING DROPPED OFF [Y,N]:
IS VEHICLE DRIVEABLE [Y,N]:
LICENSE PLATE#:
HOW DID YOU HEAR ABOUT EFIDYNOTUNING:
PRE-TUNE CHECKLIST VERIFIED [Y,N]: yes
If NO, Verify the Pre-Tune Checklist (linked above) Before Proceeding!
IS VEHICLE 100% READY TO BE TUNED [Y,N]? Yes
LIST ALL DEFICIENCIES/COMMENTS/NOTES BELOW:
VEHICLE YR/MAKE/MODEL: 1992 mustang lx
VEHICLE WEIGHT: 3400lbs ???
PCM/ECU CODE: A9L
TUNING DEVICE (None,SCT,QH,Tweecer,etc): QH
TUNING SOFTWARE (BE,TunerPro,Caledit,SCT,etc): TPRT
PRIMARY VEHICLE USE (street,strip,weekend,show,daily,etc): street / strip
IS THIS YOUR PRIMARY VEHICLE[Y,N]: no
PREFERRED IDLE RPM: 750
DESIRED REV-LIMITER RPM: 6500
BILLET OIL PUMP GEARS [Y,N]: no
TRANSMISSION TYPE [AUTO,MANUAL]: manual TKO600
Gear Ratios: 1st: 2nd: 3rd: 4th: 5th:
REAR WHEEL TIRE SIZE:
REAR GEAR RATIO: 3.73
TQ CONVERTER MAKE & STALL SPEED:
TRANS FLUID TYPE & SPEC:
INJECTOR SIZE/BRAND/COLOR: ev14 black
INJECTOR PART NUMBER:
INJECTOR PURCHASE PRICE $:
INJECTOR VENDOR PURCHASED FROM: The Mustang Shop
FUEL SYSTEM TYPE [STOCK,RETURN,RETURNLESS]: return
ADJUSTABLE FUEL PRESSURE REGULATOR [Y,N]: yes
AFPR MAKE & MODEL#: on rail flow tech
BASE FUEL PRESSURE: 55psi
FUEL PUMP QUANTITY & SIZE [LPH]: 255lph
FUEL RAIL SPECS: billet
THROTTLE BODY SIZE: 90mm
BRAND AND PART #: bbk
MASS AIR FLOW SENSOR TYPE: OEM slot maf
MAF TUBE/HOUSING SIZE: 3.5"
MAF/INLET PIPING SIZE: 3.5"
MAF CALIBRATION SIZE:
MAF CALIBRATION VEHICLE:
MAF CALIBRATION CURVE [Ex: GT,COBRA,SC,etc...]:
MAF BLOW-THROUGH or DRAW-THROUGH:
ADDITIONAL MAF NOTES/COMMENTS:
***IF MAF FLOW SHEET IS AVAILABLE, LIST HERE OR ATTACH BELOW*** OEM slot maf in 3.5" tube from reference section
EXHAUST HEADER TYPE [LONGTUBES/MID/SHORTY]: 1 3/4" long tubes
EXHAUST CROSSOVER TYPE [X,H,Y-PIPE]: x pipe
EXHAUST PIPE SIZE, SPECS, & COMMENTS: 2.5" magna flow with straight through mufflers
o2 SENSOR AGE & MILEAGE: 5 years old Ntk with 2500k on them
WIDEBAND PRESENT & MODEL#: AEM
WIDEBAND WIRED IN TO PCM? [Y,N]: yes
***IF YOU HAVE YOUR WIDEBAND TRANSFER, LIST HERE OR ATTACH BELOW
FUEL TYPE OCTANE & GRADE: 91 octane
FUEL QUALITY [POOR,FAIR,AVG]:average
METH INJECTION NOZZLE GPH:
METH ACTIVATION TYPE OR PSI:
N2O SHOT / NOZZLE SIZE: 100hp
N2O Wet/Dry Shot: wet shot multi port
N2O Bottle Warmer Present [Y,N]: yes
N2O WOT Safety Switch [Y,N]: yes
CYLINDER HEAD BRAND, MODEL# & SIZE: AFR 185cc
STATIC COMPRESSION RATIO: 10:0.1
ENGINE BLOCK SPECS: stock block, scat 9000 rotating assy
CUBIC INCH DISPLACEMENT/LITERS: 347
APPROX. HOW MANY MILES ON ENGINE?: 2500k
CAM SPECS: comp cam
Intake Lift: Duration: Centerline:
Exhaust Lift: Duration: Centerline:
CAMSHAFT COMMENTS:
***IF CAM CARD IS AVAILABLE, ATTACH FILE AT BOTTOM***
POWER ADDER TYPE [Turbo,SC,n2o]:
TURBO/SC MAKE/MODEL#:
TURBO SIZE & AR / PULLEY SIZE:
#s BOOST MAXIMUM:
BOOST CONTROLLER PRESENT [Y,N]:
BOV/BYPASS LOCATED BEFORE OR AFTER MAF?:
IGNITION COIL TYPE: msd blaster
DISTRIBUTOR TYPE: MSD, I know I just read there not great at all
SPARK PLUGS BRAND, ITEM #, and GAP: NGK copper core .035
SPARK PLUG WIRES, SIZE, BRAND & AGE: MSD in good shape
IGNITION BOX TYPE & AGE: A9L2
***BASE IGNITION TIMING MUST BE 10 BTDC ON DISTRIBUTORS***
IS BASE TIMING AT 10 dBTDC [Y,N]?: yes
ELECTRIC FANS PRESENT [Y,N]: yes
HIGH AND LOW WIRED TO PCM: no
COOLANT THERMOSTAT TEMP:190
AIR CHARGE TEMP SENSOR LOCATION: in maf
QUICK CHECK LIST:
DOES ENGINE BURN OIL? [Y,N]: no
IS FUEL FILTER NEW? [Y,N]: yes
ARE SPARK PLUGS NEW? [Y,N]: yes
CAP AND ROTOR NEW? [Y,N]: cleaned with Emery
SPARK PLUG WIRES NEW? [Y,N]: no
AIR FILTER NEW? [Y,N]: no
O2 SENSORS NEW? [Y,N]: no
EXHAUST SEALED NO LEAKS? [Y,N]: yes
IS BASE TIMING AT 10 dBTDC [Y,N]: yes
FIRING ORDER VERIFIED [Y,N]: yes
LIST ANY ADDITIONAL VEHICLE DETAILS/COMMENTS/NOTES BELOW:
(ERASE THIS TEXT AND EXPAND THIS SECTION IF NEEDED)
___________________________________________________________
www.EFIDYNOTUNING.com - EFI Dyno Tuning LC - New Orleans, LA
brewster
Re: tune check
Unread postby decipha » Thu Jun 27, 2019 8:52 am
you have some major hurdles to take care of first
1st your hegos are old, you need new brand new hegos in order to tune a vehicle correctly if your having fuel issues and more so since they have to be extremely accurate in order to dial in the injectors
2nd your odd injectors will require dialing in, what have you done to dial it in?
3rd you need to throw away that junk msd distributor and upgrade to a stock oem distributor
you have not cut back your cranking pw as detailed in the a9l2 write up nor did you adjust the spark table as described either
the warm start log was useless since it never got to warm stable operating conditions
the warm idle log looked perfect other than hego1 setting a fault and not being used
your fuel is all over the place and hego1 is stuck full rich. Verify first your not sucking fuel through the fuel pressure regulator vac port and then dial in the injectors. Impossible to tell anything useful about their flow from those logs but if I had to guess based on the little I could see I would estimate the high slope needs to be raised quite a bit and the breakpoint needs to be raised significantly.
06 Chrysler 300 AWD
Re: tune check
Unread postby brewster » Thu Jun 27, 2019 9:19 pm
Thanks for taking the time to check over things decipha
1) I never knew hegos could go bad over time as they only have about 2000k on them but are at least 5 years old and the car has sat a long time. I'll get some new ones, any brand specific better then the other ??
2) The injectors are out of a 2011 mustang from my under standing are ev14 style and are approx 34lb hr, I used to info off the injector settings reference on the homepage. I did put the low slope down quite a ways and obviously havent played with break point and offset much as I dont quite understand what pids would give me the info I need to be able to dial in slope, break point and offset. Will def do some more reading over and over on it when I can find the time.
3) the mad distributor I didnt realize until I recently read your blog on them and when I can get the coin together I'll change it out asap
4)didnt mess with crank pw much yet because it starts great all the way up until It got hot. I did play with it before in another bin but it didnt make a difference, possibly didnt adjust it enough.
5) is there a flag or way to tell when the ecu is stabilized fueling as I thought if the hegos are switching and lambse and kamrf are moving then it's in closed loop doing what it needs to do ?
6) how did u know that hego 1 is faulting and not being used, far as I seen there switching from lean to rich?
7) I'll take a look at mechanicals and make sure there isn't anything funky going on with the fuel press reg etc. Is just the low slope used at idle and how does a guy know how to adjust the break point between low and high slope. Thats something I havent clued in on yet not knowing which data could or would tell me what needs to be adjusted and when.
Really appreciate the feed back thanks again for taking 5he time to look it over. Oh also what would make the lambses climb like that commanding it lean, guessing hego 1 showing its rich if was trying to lean it out.
Also I never touched the spark table yet as I've been fighting with fuel atm. Figrued baby steps
brewster
Re: tune check
Unread postby decipha » Fri Jun 28, 2019 2:59 pm
the ntk hegos are best but if they are low km hegos they are probably fine I would leave them unless you blew a head gssket or burned oil through them etc...
if u have known injectors put their actual info in and dial in the maf, once u get the maf dialed in you can then use the fuel err histogram in tunerpro plotted over imaf and rpm to dial in the injectors if needed
you did not out the injector details in your info so i assumed they were generic. Its always best to give as much info as possible especially for a critical peripheral like injectors or maf.
just cuz its in closed loop fueling doesnt mean its stabilized. The engine has reached stabilized fueling when its been running at least 5 minutes at full operating temp and no throttle inputs.
you can see both lambses and kams are the exact same number and switching with hego2. Hego1 never switched lean it stayed >0.3 volts.
06 Chrysler 300 AWD
Re: tune check
Unread postby brewster » Sat Jun 29, 2019 8:23 pm
couple of idle logs, just curious if someone can take a look and tell me why its hunting for idle. The ipsibr i'm able to get at 0.00 if I open the throttle blade a little but then its revving way to high for an idle. It seems like the hegos are reporting back properly but I may be wrong. Whats the best method for lowering idle when using mechanical idle control, and why is this damn thing hunting.
brewster
Re: tune check
Unread postby brewster » Sat Jun 29, 2019 8:25 pm
Also here is the current bin, finally been able to get it to warm start since I messed with crank PW vs ECT
brewster
Re: tune check
Unread postby brewster » Sun Jun 30, 2019 1:43 pm
Here is the current warm idle log with the 30lb injector settings somewhat known. As well as the .bin. Engine starts great, idles way better with barely a hunt and runs well.
brewster
Re: tune check
Unread postby brewster » Sun Jun 30, 2019 3:32 pm
Ok here is the latest revision I've been messing with. All is well except I've noticed hego 1 is reporting rich at idle. If I touch the throttle and clear out the cylinders I can get it to report lean and switch but it eventually reports rich again. I checked the fuel press regulator vacuum source and it doesn't seem to be leaking. Guessing maybe the injectors might be a bit leaky from sitting for quite a few years, maybe have some varnish built up on them and there not sealing well? Or I guess its possible the hego its self might be pooched ?
brewster
Re: tune check
Unread postby brewster » Sun Jun 30, 2019 4:04 pm
Ugh this was idling great and I could blip the throttle no problem then I went for a drive and once I stopped at a stop sign it would richen up and stall. Re start would start, hunt and stall showing rich on wb. Had to play with throttle to keep it running.
brewster
Re: tune check
Unread postby brewster » Thu Aug 01, 2019 8:40 pm
Please check out this log and bin. I know I have a long way to go but I just want to confirm that the lambses are climbing while accelerating because I have to dial in preload? Lambse are super close while idle and cruise but add more load and they climb into the red. I don't understand though that when I look up PRLDSW and want to set it to 0 as it says in the instructions it only gives me and option to SET.
brewster
Return to <<--Tune Review-->>
