Tune review (Hot start)
Unread postby Fasterthangas » Sat Sep 01, 2018 5:05 pm
ESTIMATED ALTITUDE (FT):1000 ft above
POSTAL ADDRESS (FOR SHIPPING ONLY):
__________________________________________________________
PRE-TUNE CHECKLIST VERIFIED [Y,N]:
If NO, Verify the Pre-Tune Checklist (linked above) Before Proceeding!
IS VEHICLE 100% READY TO BE TUNED [Y,N]?
LIST ALL DEFICIENCIES/COMMENTS/NOTES BELOW:
VEHICLE YR/MAKE/MODEL: 95 Ford Mustang GT
VEHICLE WEIGHT:3400
PCM/ECU CODE: T4MO
TUNING DEVICE (None,SCT,QH,Tweecer,etc): QH
TUNING SOFTWARE (BE,TunerPro,Caledit,SCT,etc):BE
PRIMARY VEHICLE USE (street,strip,weekend,show,daily,etc):Street/Strip
IS THIS YOUR PRIMARY VEHICLE[Y,N]:N
PREFERRED IDLE RPM: 950
DESIRED REV-LIMITER RPM: 6200
BILLET OIL PUMP GEARS [Y,N]:N
TRANSMISSION TYPE [AUTO,MANUAL]:Manual
Gear Ratios: 1st:3.35 2nd:1.99 3rd:1.33 4th:1.00 5th: .68
REAR WHEEL TIRE SIZE: 10.5-315/35-17
REAR GEAR RATIO: 3.73
TQ CONVERTER MAKE & STALL SPEED:
TRANS FLUID TYPE & SPEC: ATF Mercon V
INJECTOR SIZE/BRAND/COLOR: Ford 34lb Black
INJECTOR PART NUMBER:LU34A
INJECTOR PURCHASE PRICE $:
INJECTOR VENDOR PURCHASED FROM:
FUEL SYSTEM TYPE [STOCK,RETURN,RETURNLESS]:Stock
ADJUSTABLE FUEL PRESSURE REGULATOR [Y,N]: N
AFPR MAKE & MODEL#:Ford
BASE FUEL PRESSURE: 39
FUEL PUMP QUANTITY & SIZE [LPH]: 190LPH
FUEL RAIL SPECS:Stock
THROTTLE BODY SIZE:
BRAND AND PART #:Accufab 75mm
MASS AIR FLOW SENSOR TYPE: 90mm Lightning
MAF TUBE/HOUSING SIZE:
MAF/INLET PIPING SIZE: 4"
MAF CALIBRATION SIZE:
MAF CALIBRATION VEHICLE:
MAF CALIBRATION CURVE [Ex: GT,COBRA,SC,etc...]:
MAF BLOW-THROUGH or DRAW-THROUGH:
ADDITIONAL MAF NOTES/COMMENTS:
***IF MAF FLOW SHEET IS AVAILABLE, LIST HERE OR ATTACH BELOW***
Voltage Flow
16.0 1686.5
5.00 1686.5
4.75 1405.8
4.50 1207.1
4.25 1029.7
4.00 864.9
3.75 718.6
3.50 594.7
3.25 487.6
3.00 395.1
2.75 311.4
2.50 239.8
2.25 180.0
2.00 135.0
1.75 101.1
1.50 74.1
1.25 50.4
1.00 30.7
0.75 19.3
0.50 13.6
0.25 9.5
0.05 6.3
0.00 0.0
0.00 0.0
0.00 0.0
0.00 0.0
0.00 0.0
0.00 0.0
0.00 0.0
0.00 0.0
EXHAUST HEADER TYPE [LONGTUBES/MID/SHORTY]:Shorty
EXHAUST CROSSOVER TYPE [X,H,Y-PIPE]: H
EXHAUST PIPE SIZE, SPECS, & COMMENTS:2,5" Full length Straight through mufflers
o2 SENSOR AGE & MILEAGE:Bosch one year 7000 miles
WIDEBAND PRESENT & MODEL#: Y AEM 30-4110
WIDEBAND WIRED IN TO PCM? [Y,N]:Y
***IF YOU HAVE YOUR WIDEBAND TRANSFER, LIST HERE OR ATTACH BELOW
FUEL TYPE OCTANE & GRADE: 91 10% ethanol
FUEL QUALITY [POOR,FAIR,AVG]:Poor
METH INJECTION NOZZLE GPH:
METH ACTIVATION TYPE OR PSI:
N2O SHOT / NOZZLE SIZE:
N2O Wet/Dry Shot:
N2O Bottle Warmer Present [Y,N]:
N2O WOT Safety Switch [Y,N]:
CYLINDER HEAD BRAND, MODEL# & SIZE: AFR 1422 185
STATIC COMPRESSION RATIO: 10:1
ENGINE BLOCK SPECS: Stock
CUBIC INCH DISPLACEMENT/LITERS: 347
APPROX. HOW MANY MILES ON ENGINE?: 1500
CAM SPECS:
Intake Lift: 230 Duration: .050 Centerline:108
Exhaust Lift: 238 Duration: .050 Centerline:108
CAMSHAFT COMMENTS:
***IF CAM CARD IS AVAILABLE, ATTACH FILE AT BOTTOM***
280/290 advertised
230/238 @ .050
7 BTDC 43 ABDC
55 BBDC 3 ATDC
112 separation
108 ICL
POWER ADDER TYPE [Turbo,SC,n2o]:
TURBO/SC MAKE/MODEL#:
TURBO SIZE & AR / PULLEY SIZE:
#s BOOST MAXIMUM:
BOOST CONTROLLER PRESENT [Y,N]:
BOV/BYPASS LOCATED BEFORE OR AFTER MAF?:
IGNITION COIL TYPE: Motorcraft
DISTRIBUTOR TYPE: Motorcraft
SPARK PLUGS BRAND, ITEM #, and GAP: Autolite 3924 .045"
SPARK PLUG WIRES, SIZE, BRAND & AGE: Ford Racing 9mm )One year
IGNITION BOX TYPE & AGE: Factory original
***BASE IGNITION TIMING MUST BE 10 BTDC ON DISTRIBUTORS***
IS BASE TIMING AT 10 dBTDC [Y,N]?: Y
ELECTRIC FANS PRESENT [Y,N]:Y
HIGH AND LOW WIRED TO PCM: Just high
COOLANT THERMOSTAT TEMP: 180
AIR CHARGE TEMP SENSOR LOCATION: Between MAF and TB inserted into intake tubing.
QUICK CHECK LIST:
DOES ENGINE BURN OIL? [Y,N]: Y (Through pcv into intake)
IS FUEL FILTER NEW? [Y,N]:Y
ARE SPARK PLUGS NEW? [Y,N]:Y
CAP AND ROTOR NEW? [Y,N]:Y
SPARK PLUG WIRES NEW? [Y,N]:N
AIR FILTER NEW? [Y,N]:Y
O2 SENSORS NEW? [Y,N]:N
EXHAUST SEALED NO LEAKS? [Y,N]:Y
IS BASE TIMING AT 10 dBTDC [Y,N]: Y
FIRING ORDER VERIFIED [Y,N]:Y
Car cranks and cranks when hot. It will eventually start and smells like raw fuel out the exhaust. Car will hot start if I floor the gas pedal. Fuel pressure leak down is normal.
Fasterthangas
Vehicle Information: CBAZA
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
230/238 @ .050 custom cam
AFR Renegade 185 heads
Ford Racing EV14 34lb. injectors
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
1-3/4" shorty headers into 2.5" duals out the back with H pipe. Jones Maxflow straight through mufflers
Re: Tune review (Hot start)
Unread postby decipha » Sat Sep 01, 2018 5:06 pm
go kick down the crank pw when warm until it gets better
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby Fasterthangas » Sat Sep 01, 2018 5:55 pm
decipha wrote:go kick down the crank pw when warm until it gets better
Thanks. Will do.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Sat Sep 01, 2018 7:20 pm
Would that be FN348A?
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Sun Sep 02, 2018 6:05 am
yes
06 Chrysler 300 AWD
Unread postby Fasterthangas » Sun Sep 02, 2018 10:47 am
Thanks!
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Thu Sep 06, 2018 5:41 pm
Well I'm not getting anywhere. I keep reducing the multiplier and she still won't fire unless I put the pedal to the floor. She fires right up when stone cold.
I'm currently here:
65534.00 0.50
230.00 0.50
210.00 0.40
180.00 0.40
120.00 0.67
70.00 1.50
40.00 3.02
20.00 4.25
0.00 6.03
-20.00 10.05
-65536.00 10.05
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Thu Sep 06, 2018 6:52 pm
go to the cranking pw multiplier table and shut off the injectors for the first few pips at hot start
06 Chrysler 300 AWD
Unread postby Fasterthangas » Thu Sep 06, 2018 7:17 pm
Double post.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Thu Sep 06, 2018 7:18 pm
decipha wrote:go to the cranking pw multiplier table and shut off the injectors for the first few pips at hot start
So probably change only the 175* and 200* rows at 0 5 6 15 PIPs?
Change to a value of 0.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Thu Sep 06, 2018 7:41 pm
I just found this and it only confuses the issue. Does one use the table or multiplier? Both?
https://eectuning.org/forums/viewtopic.php?f=5&t=9290
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Fri Sep 07, 2018 5:36 am
ignore that link
the table is thr multiplier, just simply set it to 0 for thr first few pips when hot to shut off the injectors
keep in mind thats not normal and usually indicates a mechanical fuel injector problem or poor fuel dial in causing it to dump fuel on shut down
06 Chrysler 300 AWD
Unread postby Fasterthangas » Fri Sep 07, 2018 2:07 pm
decipha wrote:ignore that link
I tried this and the problem still persist. I had the injectors cleaned and flowed before installing them. Wouldn't injector issues show up while driving or in the logs?
Thanks.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Fri Sep 07, 2018 5:41 pm
anything that shows up while driving will show up in the log
do you have your fuel dialed in ?
are you sure your problem is crank and not enrichment? cranking pw is directly responsible for how long you have the leave the key in the crank position before it fires off, enrichment is from there after
06 Chrysler 300 AWD
Unread postby Fasterthangas » Fri Sep 07, 2018 6:23 pm
decipha wrote:anything that shows up while driving will show up in the log
Fuel is dialed in. Engine cranks 10-15 seconds before firing. It runs perfect after it fires.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Tue Sep 18, 2018 4:33 pm
Michael,
I tried adding and subtracting to cranking pulsewidth vs. ECT.
I zero'd out a few pips in cranking table.
I added and removed fuel to open loop startup table.
Nothing makes a difference except opening the TB during startup.
Any ideas?
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Tue Sep 18, 2018 5:09 pm
kick up the crank iscdc function, it may be too low at your hot start
did you verify your iscdc is below 35% at a warm stable idle and ipsibr is at 0 along with isckam correction?
06 Chrysler 300 AWD
Unread postby Fasterthangas » Tue Sep 18, 2018 5:22 pm
decipha wrote:kick up the crank iscdc function, it may be too low at your hot start
I'll double check these and kick that function up.
Thanks!
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Tue Sep 18, 2018 5:30 pm
Here's where I'm currently at with FN884:
254.00 0.9922
150.00 0.9922
90.00 0.9922
60.00 0.9922
-256.00 0.9922
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Tue Sep 18, 2018 5:43 pm
well thats not it
is it starting up then dying or is it the actual crank thats the problem ?
06 Chrysler 300 AWD
Unread postby Fasterthangas » Tue Sep 18, 2018 6:03 pm
decipha wrote:well thats not it
When hot; I try to start and she cranks quite a bit before starting. I don't touch the gas. She cranks over fine.
If I put the gas to the floor when starting; she starts right up.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Tue Sep 18, 2018 6:14 pm
set the crank pw multiplier to 0 for longer
06 Chrysler 300 AWD
Unread postby Fasterthangas » Tue Sep 18, 2018 6:47 pm
decipha wrote:set the crank pw multiplier to 0 for longer
Will do. Thanks.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Tue Sep 18, 2018 7:38 pm
Here's where I'm at:
iscdc - (32.81)
ipsibr- (-0.4)
isckam2 - (-0.052)
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Tue Sep 18, 2018 8:57 pm
Success!!!! FN1350 was the key. Here's where I ended up. She started hot twice tonight. ECT was 170* both times. Fingers crossed that tomorrow brings the same success.
0.00 0.00 0.00 0.00 0.00 1.00 1.00 1.00
0.00 0.00 0.00 0.00 0.00 0.59 0.30 0.09
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Tue Sep 18, 2018 9:00 pm
i wouldnt zero it out when cold
06 Chrysler 300 AWD
Unread postby Fasterthangas » Tue Sep 18, 2018 10:16 pm
decipha wrote:i wouldnt zero it out when cold
Ok. Thanks.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Thu Sep 20, 2018 11:16 am
Well that was short lived. I don't know what changed or maybe I did something different, but the car still cranks and cranks when hot.
I'm at a loss. Here is my latest FN348A values:
65534.00 0.31
230.00 0.31
210.00 0.31
180.00 0.31
120.00 0.46
70.00 1.50
40.00 3.02
20.00 4.25
0.00 6.03
-20.00 10.05
-65536.00 10.05
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Thu Sep 20, 2018 12:38 pm
did u try holding the throttle to the floor when hot to see if it starts? if so its flooding out?
06 Chrysler 300 AWD
Unread postby Fasterthangas » Thu Sep 20, 2018 1:38 pm
decipha wrote:did u try holding the throttle to the floor when hot to see if it starts? if so its flooding out?
Yes. It starts every time that way. Sometimes it seems a bit loaded up, but nothing major. It will start right up and idle fine.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Thu Sep 20, 2018 3:42 pm
Ok; well this car keeps making a liar of me. It seems that my tune has progressed and now the car does a long crank before starting even when holding the pedal to the floor.
This is one hour after warming the car up.
When the car started; grey smoke came out of the exhaust in a small cloud.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Thu Sep 20, 2018 5:11 pm
sounds like u got a leaking injector
06 Chrysler 300 AWD
Unread postby Fasterthangas » Thu Sep 20, 2018 6:42 pm
decipha wrote:sounds like u got a leaking injector
I've been thinking the same. Last time I threw a fuel pressure gauge on it; the pressure took 45 mins to bleed off. Sound normal?
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby Fasterthangas » Mon Sep 24, 2018 5:58 pm
It was leaky injectors. All is fine now. Thanks.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Mon Sep 24, 2018 8:23 pm
what kind of injectors were they?
06 Chrysler 300 AWD
Unread postby Fasterthangas » Mon Sep 24, 2018 8:45 pm
decipha wrote:what kind of injectors were they?
LU34A
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Return to <<--Tune Review-->>
