Tune help
Tune help
Unread postby Turbo95stang » Thu Nov 09, 2017 8:41 pm
just woundering if i can get some help on tune CBAZA U4P2.
i put in my injector settings for 60lb and maf transfer curve for pro m calibrated 80lb then scaled settings by 2.836
car starts good when cold then when it reaches 130deg on i get a stumble here and there but if i shut off car it wont start until its cold. just would like to get suggestions. THANKS
Turbo95stang
+Premium Plus Member
Vehicle Information: 95 mustang 5.0 with hellion fox turbo kit 76mil Turbonetics turbo jgs wastegate 50mil tail bov and gt40p heads with trick flow upgraded valve springs,93 cobra upper,lower intake,3in pro m maf ,80lb seimen deka injectors,PRO M fuel pump hanger 8an feed 6an return,Glen performance fuel rail,aeromotive remote regulator with BBK pressure gauge ,foxbody timing cover with alternator,power steering,water pump accessories 70 mil throttle body,sailor Bob strategy, quarterhorse tuned by Michael Decipha
Re: Tune help
Unread postby decipha » Fri Nov 10, 2017 6:29 am
if it doesnt fire off when warm the cranking pw needs to be kicked up in the hotter temps
have u dialed in your fuel ?
Return to <<--Tune Review-->>
