89 coupe running rich at wot
Unread postby 89mustangcoupe » Sun Jul 10, 2016 9:41 pm
heres a datalog of my car running the stock a9l.bin. seems to run rich at WOT. have fuel pressure set at 55psi with vac disconnected. what do you guys think with the mods I have. anyone have any sugestions on what to change for my mods.
89mustangcoupe
Vehicle Information: 1989 ford mustang lx coupe a9l ecu, moates quarter horse, plx dm6 wideband,tuner pro rt, 302 stock block,9:9:1 CR sealed power forged pistons, eagle I beams, eagle crank, gt40p heads with mild porting on exhaust, crane conical valve springs ,1.7 crane cams cobra rockers, Anderson n-21 cam, Vortech V1 S-trim, FMIC, Siemens Deka 60lb injectors, pro products AFPR, PMAS HPX-E Blow thru MAF, typhoon professional products intake with 1 inch spacer, bbk 75mm tb with egr delete,msd blaster coil,accel distributor module, Mallory hyfire 685, T5 trans, strange 35 spline axles and full spool with 4:10 gears, FMS shorty headers bbk x pipe, flow masters to tail pipes, Autolite 103's
Vehicle 2 Information: 89 Camaro RS 305 TBI Auto Stock
Re: 89 coupe running rich at wot
Unread postby 89mustangcoupe » Tue Jul 12, 2016 2:43 pm
updated tune with new datalog
89mustangcoupe
Unread postby decipha » Tue Jul 12, 2016 4:10 pm
im not ignoring u just no time to take a gander, this is the busy season lol
Unread postby 89mustangcoupe » Wed Jul 13, 2016 6:54 am
let me know when you get time thanks
89mustangcoupe
Unread postby 89mustangcoupe » Wed Jul 13, 2016 11:17 am
I got slope breakpoint and offset for my injectors now. it idles very well but when I go wot I get 1.2 to 1.3 fuel error % and I get a wideband reading on tuner pro of 7.80-8.20 actually gauges shoes 10:1 then it pegged rich. I'm not sure what I need to adjust maybe something like WOT VS RPM would help I'm still learning and I adjusted my maf at idle to get the right fuel error of 1.00 at idle and around 2000 rpms I try to get it to match 1.00. my adjusting the maf transfer at that mafv voltage then I multiply wherever the fuel error is for that voltage and change it to a new value for each voltage I could get a reading from idling in my garage up to 2000rpm. I'm not sure if that's the correct way to do it as I used 98 explorer bin injector info someone posted in the forum that I asked for there the F6VE-A5A 0280 155 710 19lb injectors. but then again I am running more fuel pressure than stock so not sure everything is set right for 55psi.
89mustangcoupe
Unread postby decipha » Thu Jul 14, 2016 6:21 am
you have the wrong adx file for tunerpro
the wot lambse multiplier cannot dial in fuel, you need to dial in the maf
Return to <<--Tune Review-->>
cron
