first build of a tune just want a look over to make sure
Unread postby allmotormark » Wed May 25, 2016 12:31 pm
here is what i got , i know i'm obviously going to have to tune things but can you go over this just to make sure its good? I scaled airflow by 1.226
its a 2003 mustang 4.6L auto, turbo, sct ba5000 maf 2.5" tube, 80lb ford injectors everything else is stock including rear end.
<merged with other thread>
allmotormark
Premium Member
Vehicle Information: 2003 mustang gt
wbo2-AEM
Re: fbfg2 deltap mutipliers???
Unread postby decipha » Wed May 25, 2016 3:56 pm
you didn't update the most important variable in the ecu, XTALHPS the clock speed
you didn't half ass the pct_load table
i gotta run i'll check it out more later
Name: Michael Decipha Ponto
06 Chrysler 300 AWD
Unread postby allmotormark » Wed May 25, 2016 4:11 pm
using fbfg2.
not sure i edited all the auto trans parameters correctly some parameters are missing from the transmission write up
these are them
TMVEDN DOWNSHIFT DELAY
TMVEUP UPSHIFT DELAY
TMVETOUP
MNOSSPER
RTNVMX
RTNVMN
GR_SEQ_421
UNLKDLYTM
and i started to search for these but the first bunch i coulndt find so i assume i can't find them
++|TVPMINPT_1 1ST GEAR MIN TV PT 0.0 MINIMUM TV PRESSURE CLIP IN 1ST GEAR AT PART THROTTLE
++|TVPMIN1 1ST GEAR MIN TV 0.0 MINIMUM TV PRESSURE CLIP IN 1ST GEAR
++|TVPMINST_1 1ST GEAR MIN TV NON SHIFT 35.0 MINIMUM TV PRESSURE CLIP IN 1ST GEAR NON SHIFTING
++|TVPMINPT_2 2ND GEAR MIN TV PT 8.0 MINIMUM TV PRESSURE CLIP IN 2ND GEAR AT PART THROTTLE
++|TVPMIN2 2ND GEAR MIN TV 0.0 MINIMUM TV PRESSURE CLIP IN 2ND GEAR
++|TVPMINST_2 2ND GEAR MIN TV NON SHIFT 35.0 MINIMUM TV PRESSURE CLIP IN 2ND GEAR NON SHIFTING
++|TVPMINPT_3 3RD GEAR MIN TV PT 8.0 MINIMUM TV PRESSURE CLIP IN 3RD GEAR AT PART THROTTLE
++|TVPMIN3 3RD GEAR MIN TV 0.0 MINIMUM TV PRESSURE CLIP IN 3RD GEAR
++|TVPMINST_3 3RD GEAR MIN TV NON SHIFT 40.0 MINIMUM TV PRESSURE CLIP IN 3RD GEAR NON SHIFTING
++|TVPMINPT_4 4TH GEAR MIN TV PT 15.0 MINIMUM TV PRESSURE CLIP IN 4TH GEAR AT PART THROTTLE
++|TVPMIN4 4TH GEAR MIN TV 20.0 MINIMUM TV PRESSURE CLIP IN 4TH GEAR
++|TVPMINST_4 4TH GEAR MIN TV NON SHIFT 45.0 MINIMUM TV PRESSURE CLIP IN 4TH GEAR NON SHIFTING
TVPMIN_ENG TV MIN CLIP 4 MINIMUM TV PRESSURE CLIP (GLOBAL) - USED EVEN AT IDLE DO NOT EXCEED 12 UNDER ANY CIRCUMSTANCES
++|TVPMINPT_ENG TV MIN CLIP PT 20 MINIMUM TV PRESSURE CLIP AT PART THROTTLE (GLOBAL)
++|SCINT1 1ST GEAR STATIC OFFSET 0 STATIC OFFSET PRESSURE IN 1ST GEAR
++|SCINT2 2ND GEAR STATIC OFFSET -10 STATIC OFFSET PRESSURE IN 2ND GEAR
++|SCINT3 3RD GEAR STATIC OFFSET -4 STATIC OFFSET PRESSURE IN 3RD GEAR
++|SCINT4 4TH GEAR STATIC OFFSET -1 STATIC OFFSET PRESSURE IN 4TH GEAR
++|SCSLP1 1ST GEAR STATIC SLOPE 0.219 STATIC TQ MULTIPLIER FOR NON-SHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++|SCSLP2 2ND GEAR STATIC SLOPE 0.270 STATIC TQ MULTIPLIER FOR NON-SHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++|SCSLP3 3RD GEAR STATIC SLOPE 0.301 STATIC TQ MULTIPLIER FOR NON-SHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++|SCSLP4 4TH GEAR STATIC SLOPE 0.320 STATIC TQ MULTIPLIER FOR NON-SHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++SCSLP1SD DOWNSHIFT SLOPE IN 1ST 0.039 STATIC TQ MULTIPLIER FOR SHIFT CAPACITY - REDUCING THIS VALUE INCREASES DOWNSHIFT PRESSURE
++SCSLP2SD DOWNSHIFT SLOPE IN 2ND 0.250 STATIC TQ MULTIPLIER FOR SHIFT CAPACITY - REDUCING THIS VALUE INCREASES DOWNSHIFT PRESSURE
++|SCSLP3SD DOWNSHIFT SLOPE IN 3RD 0.250 STATIC TQ MULTIPLIER FOR SHIFT CAPACITY - REDUCING THIS VALUE INCREASES DOWNSHIFT PRESSURE
++|SCSLP4SU 4TH GEAR UPSHIFT SLOPE 0.078 STATIC TQ MULTIPLIER FOR UPSHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++|SCSLP2SU 2ND GEAR UPSHIFT SLOPE 0.180 STATIC TQ MULTIPLIER FOR UPSHIFT CAPACITY - REDUCING THIS VALUE INCREASES TV PRESSURE
++|SCSLP3SU
is it just that they are not in this strat?
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed May 25, 2016 4:41 pm
i don't know what happened there, i checked XTALHPS this one set to 4.0, that is correct right?
i posted this in tune review but i guess ill post it here
these are them
TMVETOUP
MNOSSPER
RTNVMX
RTNVMN
GR_SEQ_421
UNLKDLYTM
++|SCSLP3SU
allmotormark
Premium Member
wbo2-AEM
Re: first build of a tune just want a look over to make sure
Unread postby decipha » Wed May 25, 2016 5:33 pm
I dont have those scalars in the def by thwir actual names, no worries tho they are already set correctly.
observations
you didn't disable hego 2
no vin or pats code
you corrupted the maf curve by putting the top value as 5 volts instead of maximum
you didn't scale the injector breakpoint
the mew1 ecu has a 3.0 clock
all of the tvpmin scslp and scint scalars are in there, go to the search and type them in they will pop up, they are already setup in the sym3 cal
the ones above i hadn't added in, if they exist i changed them in the base tunes though
you are aware the fbfg2 write up ONLY applies to the base tunes correct? the stock tunes require a lot of work to get them up to my standard
here's the sym3 adjusted for you, copy out your stock tune and just copy over your vin and pats code, re-enable pats and begin tuning from there
06 Chrysler 300 AWD
Unread postby allmotormark » Wed May 25, 2016 5:56 pm
Thanks , which ones are the base tunes, I downloaded the package from your post I thought they were all base tunes , sorry went and looked at your post for fbfg2 and its says write there, that you haven't released base tunes , sorry missed that
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed May 25, 2016 6:05 pm
nope those are all stock tunes, the base tunes i only had posted for a few days until i deleted them cuz I've shifted my focus to another strat instead of fbfg2, i still have some work to do though before its ready to take over the world
06 Chrysler 300 AWD
Unread postby allmotormark » Wed May 25, 2016 6:14 pm
Ok great, Thanks for the help, ive tuned Honda ecus and a few stand alones but this eec is another level, thanks so much I've read over all your write ups 2-3 times and will read again. Thanks for all the work you do the write ups alone must have taken a long time. I can apreatiate that.
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed May 25, 2016 6:52 pm
I'm sure it did, I didn't do them all at once though they were brought up as needed and evolved over the years
I appreciate the sentiment
the Ford ecu is quite different than what you might expect coming from hondata or the like, the ford's require you have some more in depth knowledge of controls since it's aimed more toward the engineers that calibrate them from the factory
06 Chrysler 300 AWD
Unread postby allmotormark » Wed May 25, 2016 6:59 pm
Ya for sure, thanks for the help
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Thu May 26, 2016 1:24 pm
do i need to scale airflow? and add my maf flow #s for my sct ba5000 maf?
the maf flow in this base tune is higher then allowed?
from what i read in your scaling write up
"If you have a MAF that flows over 1,750 kg/hr for EEC-V or 2,350 kg/hr for EEC-IV you will have to scale airflow"
Also base fuel table is fn1360b?
base spark is bdl knock fn2200?
sorry for the new guy questions the write ups seem like they were probably written for different bins just verifying the terms
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Thu May 26, 2016 1:32 pm
no i already put it in there, the maf doubler is enabled so no scaling needed and that raises the max maf flow to 1750*2=3500 kg/hr
the base fuel table is the enrichment table, I have it disabled with all 0s
fn1360b is the wot multiplier, until you get fn035 dialed in its best you use that instead
bdl knock is the spark table
everything in the write ups apply
06 Chrysler 300 AWD
Unread postby allmotormark » Thu May 26, 2016 1:49 pm
ok just to confirm the maf (since im not 100% on how the doubler works)
the max flow on the current inputted values is 2999.201
but the max flow of the HPX High Flow Slot 2.5" - PMAS is 1840.22
the new flow numbers because of my previously scaled transfer numbers?
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Thu May 26, 2016 1:57 pm
the doubler just doubles the maximum range of the maf transfer
it could be off, i took a 3" hpx maf i tuned and just multiplied by .86 to approximate for a 2.5" pipe, you can either leave it as is or toss the other transfer in, you'll be tuning it regardless so either way it'll have to be dialed in
06 Chrysler 300 AWD
Unread postby allmotormark » Thu May 26, 2016 2:32 pm
Ya no prob I had a feeling you did something like that, the math was just throwing me for a loop, thanks!!
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed Sep 26, 2018 1:27 pm
back from the dead , project took longer than i thought
the turbo piping is 3" so i added 1.16
heres my issue fuel pumps are not coming on its a returnless system i checked and i think its patched correctly.
care ran a few days ago no issue before i installed maf, injectors and quareterhorse
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed Sep 26, 2018 4:18 pm
I see, thats the same 5-25-2016 tune with yours pats code and vin number added in, progress is progress though
pump type 3 returnless is enabled in the tune so it should control the pump fine, not to mention you said it worked fine the other day, if nothing changed then your fuel pump is suspect
one thing worth noting, your injectors slopes are clipped so you'll have to scale it back regardless
Also I just posted a base auto tune for fbgi0 just yesterday that I use for all the 02-04 mustangs i tune now, would be best to use that, if you want I can copy your pertinents over for you and post your tune back for fbgi0 or you can continue with fbfg2 up to you, regardless its not the tunes fault the pumps aren't coming on
06 Chrysler 300 AWD
Unread postby allmotormark » Wed Sep 26, 2018 4:28 pm
Odd I didn't change the injector slopes at all,
Other then the vin and pats
I changed the maf upped it by 1.16
If you could that would be great then I can use the new universal datalogging
But I've filled out a form I'm not sure I want to spend the time at this point tuning I may just get you to do it.
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed Sep 26, 2018 4:55 pm
What about
FP_DRIVER
What should that be set to?
Not the pumps I have a triple pump setup and I can manually get them to turn on
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed Sep 26, 2018 5:01 pm
fp_driver is set correctly at 0 in your tune
it is returnless correct?
with a triple pump how do you have the fpdm's hooked up?
06 Chrysler 300 AWD
Unread postby allmotormark » Wed Sep 26, 2018 5:08 pm
Zone 5 mdm controller
Yes it's returnless
Ran on the stock computer no issues now the pumps aren't coming on
Odd looked it over I guess I didn't save the changes to the maf
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed Sep 26, 2018 5:32 pm
only issue would be if your pats code didn't copy over and its setting an anti theft fault, is the theft light flashing with the key on?
set the pats disable sw and write the tune then turn the key on and see if it works correctly
theres nothing in that tune that would disable the fuel pumps
06 Chrysler 300 AWD
Unread postby allmotormark » Wed Sep 26, 2018 5:44 pm
Initially it was but then I set the pats switch and the light stopped flashing I'll check it again tomorrow
What do I set the pats disabled switch to? ok answered my own question , but if i disable pats with =1 would i need to fill in the pats code with ff's ? or i can leave it?
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed Sep 26, 2018 6:16 pm
ok now im not sure whats going on
tried to upload original you sent me then theft light flashed and fans came on and dashboard was -----------
now anything i upload does the same event the same bin as before
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed Sep 26, 2018 6:30 pm
if u disable pats then the pats code can be anything as it wont get used
sounds like a communication issue, read the stock tune out and write it to the qh and see if it acts right
I got your vehicle info, can whip something up for you here shortly, if u want to proceed go ahead and shoot over the paypal and we'll continue on in the premium member section
06 Chrysler 300 AWD
Unread postby allmotormark » Wed Sep 26, 2018 6:36 pm
Ok I will try that think I have to sort this out before we go further
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed Sep 26, 2018 6:42 pm
ok so theft light goes out and mileage shows up now , but fuel pumps still not coming on
with stock tune in
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Wed Sep 26, 2018 7:31 pm
So what should I do now maybe take out computer re seat plug or what are your suggestions?
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Wed Sep 26, 2018 7:38 pm
remove the qh and verify if the pump comes on without the QH in there, if it does then that means the QH is not getting a good connection
attached fbgi0 startup tune after you get it worked out
no reason at all why it shouldn't fire up and run fine with this loaded once you get the pump situated
attached adx for it as well
06 Chrysler 300 AWD
Unread postby allmotormark » Wed Sep 26, 2018 7:42 pm
Ok thanks will update tomorrow
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Thu Sep 27, 2018 7:17 am
do i need another xdf for this? I can't find universal datalogging patch
ok never mond figured it out on my own i did need the new xdf
allmotormark
Premium Member
wbo2-AEM
Unread postby allmotormark » Thu Sep 27, 2018 7:43 am
ok so update, this is for anyone else that has this issue on sn95 or eec-v. i removed the pcm found the quarterhorse was dislodged do not force the computer back up as there is a plastic bracket that wont let it go all the way in. just let it sit there.
it started up great thanks decipha!! ill be in touch
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Thu Sep 27, 2018 8:06 am
no the xdf doesnt matter but youll need tjhe fbgi0 xdf to edit it, no need tho u can write it and it shud fire up, logging is already enabled in it
fbgi0 xdf is on homepage
I got your email, no tuning doesn't stop til its dialed in. Once you become a premium member youll see some of those guys I tuned over 10 years ago and they'll pop in with a datalog or a ? from time to time.
06 Chrysler 300 AWD
Unread postby allmotormark » Thu Sep 27, 2018 8:24 am
Ok thanks sorry I emailed you and pm'd you I forgot I pm'd you
allmotormark
Premium Member
wbo2-AEM
Unread postby decipha » Thu Sep 27, 2018 8:49 am
u didn't. No worries though. When i get an email a PM an automated form or reply in the premium member section they all come to me the same. Private section is easiest to reply followed by PM hence.
Link to your thread in the premium member section, you'll see your account has been upgraded
viewtopic.php?f=80&t=2971
06 Chrysler 300 AWD
Return to <<--Tune Review-->>
