94 mustang GT t4m2 base tune wont stay running.
Unread postby Scurvy94GT » Mon Apr 04, 2016 9:03 pm
I cannot get my frshly rebuilt 5.0 to stay running. It cold starts well but surges bad, pops(intake backfire?) and then dies after about 10 seconds. It then gets harder and harder to start and eventually just starts and revs to 1500 RPM and then dies. smells extreemyl rich. Iam currently in the process of getting a wideband hooked up. I didnt get a datalog of the cold start but i can get one tomorrow afternoon. I would just like to know if the tune i have put together should be working. If its acceptable then i must have other problems.
I have tried the following to troubleshoot.
checked TPS voltage (1.04 at CT and smooth sweep to 4.75 at WOT)
traced vacuum lines to ensure no leak
sealed PCV to ensure no leak there
checked fuel pressure at rail 39.5psi
Scurvy94GT
Vehicle Information: 94 mustang GT, WH40, CBAZA strategy, QH W/BE
Re: 94 mustang GT t4m2 base tune wont stay running.
Unread postby decipha » Mon Apr 04, 2016 10:31 pm
welcome to the forum
i deleted your vehicle info sheet since you put your tele number in there, i figured you wouldn't want that publicly available
the tune looks good, i don't see any reason why it shouldn't fire up and run
make sure your distributor isn't installed 180 out
if its not firing up hold the throttle to the floor during cranking to kill the injectors so you don't wash the cylinders out
the only thing i really seen was that you didn't disable hego2 for your x-pipe, it wouldn't prevent the engine from firing up though
here you go, i copied your changes over to an updated t4m2, you reminded me i had to update it
Unread postby Scurvy94GT » Mon Apr 04, 2016 10:43 pm
Thanks very much for letting me know im on the right track, and thanks for making the base tune and for all the information you provide. I thought that if my distributor was 180 that there would be no way it would idle at all? Iam going to check again anyways. Ive posted on non-tuning mustang forums so hopefully someone has an idea for me of what else could be going wrong. the car hasnt idled much at all due to these problems but i Have changed the oil and filter once already, Im very afraid of damaging my fresh engine.
Scurvy94GT
Unread postby decipha » Mon Apr 04, 2016 10:47 pm
well its safer to be leaner, you can go take 25% out of the maf curve at the maf voltage it idles at
what mafv does it idle at when it does idle?
Unread postby Scurvy94GT » Mon Apr 18, 2016 8:11 pm
I was finally able to get to get my wideband hooked up and get a few datalogs. My car is still reacting the same way, starts quite well the first time after sitting for a while and idles rough for 5-10 seconds. then dies and becomes harder and harder to start. Iam able toi keep it running by applying a little bit of throttle, but as the log shows it only idles at 400-500 rpm and has zero throttle repsonse. it will die if i let the thottle close, but does not respond at all if i apply more throttle. it just continues to idle very rough popping and snorting at 400-500RPM. The shorter datalog is the first start without me applying throttle, and the longer one it struggles it start and i have to apply throttle to start. I tried swapping the MAF back to the stock one from the lightning and setting back to the stock MAF curve from the T4m2. reacts the same either way.
The wideband is all over the place when it is running, but it leans more towards the lean side bouncing between 13-19 AFR, but once the car dies it settles at around 10.
Any further help would be appreciated.
THX
Scurvy94GT
Unread postby decipha » Mon Apr 18, 2016 9:57 pm
what is the mafv when its running during this time?
did you try holding the throttle to the floor while cranking to see if its rich?
Unread postby Scurvy94GT » Mon Apr 18, 2016 10:10 pm
on the first start wheere i dont apply throttle its around .4-.5
when i have to apply throttle after that its between .95-1.05
ill try the WOT while starting.
do i add or remove from the kg\hr at the correspdonding voltage to lean it out?
Scurvy94GT
Unread postby decipha » Mon Apr 18, 2016 10:28 pm
remove
less air == less fuel
Unread postby NxCoupe » Thu Apr 21, 2016 10:41 am
Have you set your base timing with a light on a properly marked balancer that's had TDC confirmed? Sounds like your car has very retarded timing to me. Exhaust headers glowing?
NxCoupe
Vehicle Information: 2012 5.0 6 spd, on E85, offroad pipe, GT500 mufflers, just started tuning process, gained 40 rwhp over stock so far.
Black with black interior, base model, built shortblock.
SCT Xcal4, using Advantage to tune it.
Vehicle 2 Information: 1992 Mustang Coupe, coyote 5.0, turbo, 5 spd, race car build in progress. Used to run in NMRA Real Street, now building it for NMRA Coyote Modified
Vehicle 3 Information: 1993 Calypso Mustang Coupe, 5.0 no options, strip down coupe. Only has auto and cruise, didn't even come with a radio, lol. Future plans are to put a Windsor with an On3 turbo kit and an AOD with a brake.
Additional Vehicles: 1993 2.3L 5 spd Mustang coupe, future turbo 2.5 build.
Moates chip, BE tuned
GSS340 pump
Spec Stg 3 clutch
V8 T5 with custom input shaft, billet shifter
8.8 rear end with 3.55 gear, 4 wheel disk
V8 front spindles and brakes,
V8 sway bars front and rear
CC plates
FRPP cockpit adjustable shocks and struts. Soft to race with the flip of a switch!
Have 57mm turbo, Stinger header, ebay blow off and waste gate purchased so far.
Return to <<--Tune Review-->>
