Tune and Data log Review
Unread postby Gatorsfan1979 » Thu Dec 03, 2015 7:57 pm
I would like for you to look over my tune and data log. I'm looking to improve low end power. The car runs great on top end. I changed from 3.55 gear to 3.23 and ran about an 1" taller Street ET tire and lost half a second in a 1/8th mile it was all in the 60' time no wheel spin. I was thinking that I might could tweak timing to help. The data log attached is cruising and a 2nd gear pull on the street. I don't have a recent drag strip data log and I can't really test 60' on the street blows tires off. Any help would be appreciated
Thanks.
ONLINE / REMOTE TUNING VEHICLE INFORMATION
________________________________________________________
TELE#:
EMAIL:
DATE: 12/3/2014
VEHICLE YR/MODEL: 1991 Ford Mustang
ECU CODE: A9P
J3 DEVICE: Tweecer RT
PRIMARY VEHICLE USE: Street/Strip
MINIMUM IDLE RPM: 800
MAXIMUM ENGINE RPM: 6000
INJECTOR SIZE: 80
INJECTOR BRAND: Siemens Deca
INJECTOR COLOR: Black
FUEL PRESSURE REGULATOR: Aeromotive 13103
BASE FUEL PRESSURE: 39
FUEL PUMP SIZE: 255LPH & Vortech T-Rex
MASS AIR FLOW SENSOR TYPE: SCT BA 3000
MAF TUBE SIZE:
PIPING SIZE: 90mm
MAF CALIBRATION SIZE: N/A
MAF CALIBRATION VEHICLE: N/A
MAF CALIBRATION GT or COBRA: N/A
ADDITIONAL MAF NOTES:
***IF MAF FLOW SHEET IS AVAILABLE ATTACH AND SEND***
IGNITION COIL TYPE: Accel 110-140012
DISTRIBUTOR TYPE: Mallory TFI
PLUGS BRAND, ITEM #, and GAP: Autolite 3294, .032
PLUG WIRES: Ford Racing 9mm
IGNITION BOX TYPE: Mallory Hyfire VI Digital 685
***BASE IGNITION TIMING MUST BE 10 BTDC***
POWER ADDER TYPE: Vortech V3 SCI
TURBO SIZE & AR OR BLOWER PULLEY SIZE: 2.95"
#s BOOST: 10 psi
FUEL TYPE OCTANE & GRADE: 93 octane E10
METH INJECTION GPH and ACTIVATE#: 625ml/min, 4lb
N2O SHOT: N/A
O2 SENSOR AGE AND MILEAGE: 1 year 3000 miles
CYLINDER HEAD BRAND, MODEL AND SIZE: Roush RHS Alum 200
STATIC COMPRESSION RATIO: 9.1
ENGINE BLOCK SPECS: Dart
CUBIC INCH DISPLACEMENT: 327
CAM SPECS: Comp XE270HR-14
***IF CAM CARD IS AVAILABLE ATTACH AND SEND***
TRANSMISSION TYPE: PA Super Streeter C4 Trans 2400 Stall
WHEEL AND TIRE SIZE: 17" 275/40/17
REAR GEAR RATIO: 3.23
EXHAUST HEADER TYPE: BBK Ceramic Coated Shortie
EXHAUST SPECS: Flow Master 3"
OTHER DETAILS:
http://www.EFIDYNOTUNING.com - EFI DynoTuning LC - New Orleans, LA
1991 Mustang GT, 327 Dart Block 9.1 Comp Ratio, Vortech V3 SCI 10 psi, Roush 200 RHS Alum
Heads, Comp XE270HR-14 Cam, 1.7 FRP Rockers, 80lb injectors, SCT BA-3000 MAF,
Snow Stage 2 Kit with safe injection, Mallory VI Digital 685, 255lph,
Vortech T-Rex Booster Pump, Aeromotive 13103 FPR, BBK Ceramic Coated Shorties, 3" Flow
Master exhaust x-pipe, PA Super Streeter C4 Trans 2400 Stall, 3.23 Gear,Tweecer RT, BE, EEC
Analyzer, A9P.
Gatorsfan1979
Vehicle Information: 1991 Mustang GT, 327 Dart Block 9.1 Comp Ratio, Vortech V3 SCI 10 psi, Roush 200 RHS Alum
Snow Stage 2 Kit with safe injection, Mallory Hyfire VI Digital 685, 255lph,
Master exhaust X-Pipe, PA Super Streeter C4 Trans 2400 Stall, 3.23 Gear,Tweecer RT, BE, EEC
Analyzer, A9P.
Re: Tune and Data log Review
Unread postby decipha » Thu Dec 03, 2015 10:09 pm
you didnt max out the backflow clip fn037
your maf transfer is inverted
and its got two pretty good humps in there
it looks to be heavily over advanced at WOT
I wouldn't try to squeeze any more timing into if anything she would most likely pick up some power by taking some timing out of her
your fuel looks close but not dialed in too well, you have quite the fueling offset between bank 1 and bank 2
Unread postby Gatorsfan1979 » Fri Dec 04, 2015 8:51 pm
Okay I maxed out the backflow clip in fn037, not sure why maf transfer was inverted something to do with BE it appeared to invert almost everything I reloaded strategy and tune seemed to fix, I massaged the maf curve to be smoother, I disabled WOT Spark advance parameters and I am using Spark Sealevel Table, and Spark-Advance vs ACT to pull timing. I have copied your A9L2 timing table ,Spark-ECT Adder over. To be honest I have no idea what set the timing at I have read your timing write up and i'm not sure where my heads fall in on the MBT chart. I will upload head specs. As far as fueling offset between banks i'm at a loss on that one any advice on how to fix that would be greatly appreciated.
Analyzer, A9P.
Gatorsfan1979
Analyzer, A9P.
Unread postby decipha » Fri Dec 04, 2015 9:14 pm
those heads should mbt somewhere around 32 degrees
with 10lbs on her you should probably back it down to 24 degrees or so, iirc you had 26-28 degrees in her, can u post a pic of a plug showing the burn across the backstrap ?
Unread postby Gatorsfan1979 » Fri Dec 04, 2015 10:02 pm
Here is the best I could do with cell phone.
Analyzer, A9P.
Gatorsfan1979
Analyzer, A9P.
Unread postby decipha » Fri Dec 04, 2015 10:11 pm
damn what kinda cell phone takes a 3.7 meg pic
that plug looks aweful, the engine is detonating badly, those specs of metal on the plug is pieces of the piston from detonation
Unread postby Gatorsfan1979 » Fri Dec 04, 2015 10:26 pm
Galaxy S6... That doesn't sound good at all I would have thought that I would have noticed if it was detonating that bad. Guess that's why you pay somebody that knows what they're doing.
Analyzer, A9P.
Gatorsfan1979
Analyzer, A9P.
Unread postby decipha » Fri Dec 04, 2015 11:09 pm
I would recommend pulling the wot timing down to 18 degrees for now, start off by dialing in your fuel first with the meth disabled, it would be easiest if you simplify the maf to 0.25 volt increments, if you can bypass boost for the time being dont exceed 32 degrees until you get the fuel dialed in, then toss a new plug in it onee cylinder at a time while swinging timing around and checking the plug after each pass to see exactly where shes happiest n/a, then once you find mbt n/a hook up the blower and drop the wot timing 8 degrees of so, re enable the meth and see what kinda timing she likes with boost
I wouldnt recommend beating on it too hard until you get it dialed in safely
Unread postby Gatorsfan1979 » Wed Dec 16, 2015 11:26 am
Thanks for all the help. Going back through my tune I found that I had scaled my breakpoint wrong and it was causing the humps in my Maf curve.
Analyzer, A9P.
Gatorsfan1979
Analyzer, A9P.
Return to <<--Tune Review-->>
cron
