455 Olds for GMC Motorhome
Unread postby RaceFink » Thu Nov 05, 2015 1:47 pm
I build up a 455 Olds that sould replace the weak 403
Crank rods an pistons are stock Comp Cam towing cam Edelbrock heads and intake roller rockers
The motor is on a dyno and it run surprising good with an A9M starting well and have good power but idle is problem
In dyno room we have much problems with electric smog and QH so when you have solutions let me now
Udo
RaceFink
Premium Member
Vehicle Information: GUFB
76 GMC Motorhome 455 Olds Edelbrock heads EEC IV
Vehicle 2 Information: 75 Ford Granada (german modell) station wagon 5.0 HO AODE EEC IV
Re: 455 Olds for GMC Motorhome
Unread postby jsa » Thu Nov 05, 2015 7:05 pm
Was a usb cable connected ?
Do you have a moates opto isolator ?
Cheers
John
EEC-IV GHAJ0 ANTI or COSY
Unread postby RaceFink » Fri Nov 06, 2015 12:00 am
The ECU is in dyno room and we have 3m extension USB cable. Direkt after ECU is a ferro filter without them no log possible.
Moates opto isolator is next thing I order... do you have used them ?
RaceFink
Premium Member
Unread postby jsa » Fri Nov 06, 2015 5:24 am
Yes i have one. Works well.
Cheers
John
Unread postby decipha » Fri Nov 06, 2015 8:28 am
from the log it looks like the ecu was not powered up
Unread postby RaceFink » Fri Nov 06, 2015 10:47 am
was not powered up ?
Can you explain ?
RaceFink
Premium Member
Unread postby decipha » Fri Nov 06, 2015 10:57 am
it looks like the ecu was not getting ignition power at the power pins
Unread postby RaceFink » Sat Nov 07, 2015 5:45 am
I checked and have battery on pin 1 and ignition power on pin 37 and 57
Udo
RaceFink
Premium Member
Unread postby red5.0fogger » Sat Nov 07, 2015 6:39 am
On my car, the USB cable was touching a metal part of the dashboard and the qh would not log that way. The cable picked up some kind of noise. Is your cable away from potential noise sources?
Premium Member
Unread postby RaceFink » Sat Nov 07, 2015 7:33 am
That is the Problem
in dyno room there was a lot elecric noise and I carefully grunded all parts
First time when we have no ferro filter on usb-wire motor stop when we start loging now looks much better but motor surging when start loging
RaceFink
Premium Member
Unread postby red5.0fogger » Sat Nov 07, 2015 8:51 am
What software do you have binary editor or tunerpro? If tunerpro I could check the log.
Sounds like it's lean on fuel at first guess.
You entered all of your injector specs in the tune?
Premium Member
Unread postby RaceFink » Sat Nov 07, 2015 10:06 am
get more frustrated....
playing around and try to get TunerPro RT running have conection can read and write but log is not working..... than switched to BE and when I start datalog when motor is not running fuel pump start running and still run when log is stopped and usb cable is disconect after get power off pump running one second after get ignition on.....
RaceFink
Premium Member
Unread postby red5.0fogger » Sat Nov 07, 2015 10:12 am
When the fuel pump stays running the tune is corrupted. The qh battery may be dead.
Premium Member
Unread postby RaceFink » Sat Nov 07, 2015 10:20 am
checked 3 Volts
why it goes corrupt when start log ?
found problem QH canged mode by them self ...grrrrrrr
maybe problem with electric smog ?
should I order the opto before get futher ?
RaceFink
Premium Member
Unread postby red5.0fogger » Sat Nov 07, 2015 11:39 am
I'm not sure whats happening, we need decipha to help on this.
Premium Member
Unread postby jsa » Sat Nov 07, 2015 2:46 pm
RaceFink wrote:checked 3 Volts
Recent BE updates choose mode automuckuply , go to hardware/advanced and choose your mode manually.
If that don't solve it you don't have much choice but to try an opto. May not be the solution but that's how it is.
Cheers
John
Unread postby decipha » Sat Nov 07, 2015 6:37 pm
write the tune with tunerpro and read it back
Unread postby decipha » Mon Nov 09, 2015 7:18 am
any luck?
Unread postby RaceFink » Mon Nov 09, 2015 10:43 am
when I read bin from ecu and compare with the bin file that I saved when I read our the ecu first time there was difference and when I send that to QH pump is running. With thes saves file all is normal. So I think that the bins in ecu memorey corupted.
I order the optoisolator and a new version BE for my new laptop because I am not sure what make that mystery thinks happen I dont trust that old pc
This week we are out for the motorsport expo in Colone so next week I hope to have time and the parts to play
two evenings I try to get TunerPro log working have seen toutorials on Youtube read all infos and totaly sure that I done anything right but get no conection.
Can read and send files to QH but no log....
my english sould be better... will work on it
Udo
RaceFink
Premium Member
Unread postby RaceFink » Sat Nov 21, 2015 5:07 am
Ok I got the opto isolator but it will not work
I have contact Moates about and he told me to power the ECU but I do.
Can you explain what you mean with : "from the log it looks like the ecu was not powered up"
maybe that the problem ?
RaceFink
Premium Member
Unread postby red5.0fogger » Sat Nov 21, 2015 8:14 am
Can you send a picture of the USB cable routed in the dyno room. Try to show the entire path from ecm to laptop.
Premium Member
Unread postby decipha » Sat Nov 21, 2015 2:04 pm
RaceFink wrote:Ok I got the opto isolator but it will not work
none of the values were moving which means the ecu wasnt getting any power
Unread postby jsa » Sun Nov 22, 2015 4:28 am
Non changing values could also be poor contact between QH and J3 port.
Cheers
John
Unread postby RaceFink » Tue Nov 24, 2015 10:00 am
contact on J3 port should be OK cleaned carefully
USB port works fine but no datatransfer with opto
New BE dongel stuck in customs..... :(
RaceFink
Premium Member
Unread postby jsa » Tue Nov 24, 2015 8:21 pm
I think opto goes on QH PCB not on tune switch connector.
Cheers
John
Unread postby RaceFink » Wed Nov 25, 2015 3:07 am
hmmm.
I got this picture from Moates wen I ask for conection the link on Moates page for instriúction will not work
You have picture from your instalation ?
http://support.moates.net/wp-content/uploads/2010/04/qh_w_switch_and_knob.jpg
RaceFink
Premium Member
Unread postby jsa » Wed Nov 25, 2015 4:35 am
Yep thats a pic of the tune switch.
No, i don't have a pic of mine.
I'll see if i can find the info for you.
Cheers
John
Unread postby RaceFink » Wed Nov 25, 2015 4:38 am
that will great
I got the Dongel for BE today :D
the right info from Moates the instruction online again.
Now the opto work
cange in preferences . instead of , for decimal dividing now BE is working
hope to find time to try on running motor
RaceFink
Premium Member
Unread postby RaceFink » Sun Dec 06, 2015 1:22 pm
testet with running motor.
with the opto isolator motor run much better and dont stall when start loging.
in EA I can not open the log "error 29" is it possible that problem is with decimal dividers ?
RaceFink
Premium Member
Unread postby decipha » Thu Dec 10, 2015 12:23 am
ipsibr looks good its not adding any fuel and your idle looks stable
mafv err
1.00 1.14
she needs 14% more fuel at 1.00 mafv
thread moved to tune review
Unread postby RaceFink » Thu Dec 10, 2015 2:23 am
Ok,
I have Inovate WB in use how can I conect to ECU for log ?
fund it : viewtopic.php?f=35&t=469
Still have the Problem with EA that I can not open my log files so I must send them unseen so please give me advice that I can send usefull logs
RaceFink
Premium Member
Unread postby decipha » Sat Dec 12, 2015 4:31 pm
udo, startup tune added to the tune repository in your private progress thread
I checked over your setup and I'm going to add a wot timer vs fuel multiplier to the gufb strategy so when your making extended climbs you get enrichment fuel, that will make her much more efficient and safer
we can keep all communications in you private thread from now on so it all stays together, be sure to subscribe to that thread so your alerted of tune updates
viewtopic.php?f=92&t=1584
Return to <<--Tune Review-->>
