4r100 to 4r70w swap - 2001 Harley F-150
Links and technical articles that contain useful information
Unread postby decipha » Tue Mar 03, 2015 8:50 am
Original Post viewtopic.php?f=24&t=978
well I swapped in the 4r70w
swap was stupid easy, by far the easiest trans swap i've ever done in my life, i simply unplugged the 4r100 trans harness and plugged in the 4r70w trans harness, ripped out the 4r100 and tossed the 4r70w in, flipped the 4r70w trans mount bracket backwards and bolted up my original 4r100 cross member, i cut the bigger 4r100 cooler lines and hosed them into the 4r70w cooler ends, last i made a few tune changes, fired her up put a couple gallons of fluid in her and drove away, start to finish only took 6 hours all said and done I guess pulling the transmission 7 times in the past couple months really makes the process so much easier
Truck has been running flawless, I will be locating a 4r70w cross member for the trans though so it can be mounted correctly, my make shift mount has no give to it at all, the guy in mississippi has the cross and he won't be using it, i'll probably go snatch it from him if i can't find another local
Name: Michael Decipha Ponto
91 4r70w swap - Skarlett
Other Vehicle(s): Others:
95 Beretta - Delores
08 Grand Prix - Tara
06 Chrysler 300 AWD - Sharifa
12 Explorer - Rystacia
Re: Automatic Transmission Dimensions & Measurements
Unread postby 85GT » Tue Mar 03, 2015 9:39 am
Merc 3? Pretty sure they want merc 5. Unless your experience says other. Stupid fluid cost a lot when I did the swap. Now it's more normal.
85GT
Advanced Tuner
Other Vehicle(s): 91 Caprice 5.0 TunerPro RT
Unread postby 85GT » Tue Mar 03, 2015 9:59 am
PS - don't blame the converter for the wrong fluid lol ;)
85GT
Advanced Tuner
Unread postby decipha » Tue Mar 03, 2015 12:02 pm
yep its supposed to be merc5 i tossed merc3 in it cuz i had an abundance of it laying around, i tossed it in there just to make sure she was legit before i drop the coin on the synthetic merc 5 since i didn't know the history of the trans, its not gonna hurt it, imma put a few more miles on it and toss some synthetic merc5 in it, even at my wholesale price its still ex$pen$ive so I wanted to make sure all was well
no worries but i appreciate the concern lol
Unread postby 85GT » Tue Mar 03, 2015 12:24 pm
Cool... Good plan. There was suppose to be an LOL at the end of the converter comment.
85GT
Advanced Tuner
Unread postby decipha » Tue Mar 03, 2015 12:49 pm
fixed
just drove the truck to rallys to get that 5 star meal, 2for5 me say, the double that has the fries on in it is legit, stay away from that chicken tho
the truck drove impeccable though
Unread postby YaBoyHalle » Thu Mar 05, 2015 3:46 pm
it mostly just messes with the lockup when you have the wrong fluid. so did the lengths end up being the same? driveshaft worked for both?
YaBoyHalle
A+ Contributor
~97 hp
Other Vehicle(s): 1987 Bronco 5.0
~0 hp
Unread postby decipha » Thu Mar 05, 2015 4:33 pm
no the 4r70w is 7 and 1/4 inches shorter so it requires a 7 1/4" longer driveshaft
i found one on craigslist, that was the hold up on the swap
all works well though
Unread postby decipha » Thu Mar 05, 2015 11:43 pm
I put exactly 107 miles on the trans since i swapped it in with absolutely no issues
i yunk the pan and replaced the filter, the magnet looked really clean for having almost 200k miles on it
cleaned her up and pulled the upper return line from the trans, crunk her and let she bleed out 3 gallons of funk while i pumped the new stuff in she
shes got fresh Merc LV synthetic in her now
I know i know, you shouldnt use merc LV in lieu of merc V
But my ford engineer trans guru recommended it and said it will be fine, I trust the guy, in an case I suppose imma be the guinea... we shall see
Unread postby YaBoyHalle » Fri Mar 06, 2015 8:13 pm
well you're certainly asking for it! lol, now i know why your autos keep breaking.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Mar 06, 2015 9:48 pm
nah its not like that lol, i got a newish 4r70w with only 64k miles, this trans I got off craigslist so i wanted to make sure it was cool before i dropped some coin on fluid
Unread postby decipha » Thu Oct 08, 2015 2:40 pm
well its been 7 months and just over 10k miles, I've taken the truck on many 3+ hours drives and not a single issue, the trans and converter have been flawless, **knock on wood** all has been excellent
minus a header bolt that sheared off, got an exhaust leak/tick that I gotta get the courage up to fix, me figures, if imma yank the header I might as well flip it forward right?
as much as i'd like to ol' girl is tired at over 200k on the clock, maybe year after next when I rebuild her and forge her out lol
Re: 4r100 to 4r70w swap - 2001 Harley F-150
Unread postby decipha » Tue Nov 07, 2017 10:25 pm
I sold the truck some time ago and just seen my old truck again at a car show and then once more cruising down the street, the owner is still driving her around and not a single issue with her trans or otherwise :)
now if only i could keep my engine in my whipple harley truck for that long i'd be doing good
Unread postby decipha » Fri Dec 28, 2018 12:18 am
just talked to the guy i sold it to again. He just recently sold it but said he never once had any issues with it.
Return to Tech Articles & Links
