What da prolem is? IX
Off topic subforum for just goofing off and wasting time on possibly fun non-sense
Unread postby red5.0fogger » Mon Dec 29, 2014 9:22 am
Hey Decipha, Can you send out the next installment of this game? I think we're up to #9.
Premium Member
Re: What da prolem is IX
Unread postby decipha » Mon Dec 29, 2014 11:22 am
no prob, this one is easy
Vehicle in question is my 90 supercoupe 5spd, 3.8L v6 with the stock eaton blowah @ 15lbs
When I first got the car it had a problem going into boost as soon as it would reach 5lbs or so it would misfire and buck some aweful.
The previous owner changed, cam sensor, crank sensor, TFI "DIS" module, spark plugs, plug wires, fuel pressure regulator, fuel pump, and upgraded the battery wiring. Still problem persists.
When I got the car I went through all of the same as well, and the problem remained. Plugs used were autolite double platinum 103s gapped at 0.045
car ran fantastic otherwise and had excellent power but as soon as it reached 5lbs it was a nasty bucky misfiring mess
car had no chip on it running on the stock tune, which wasnt the problem
injectors were all flow tested and cleaned by me found to be fine
so, any takers wanna guess what the prolem is ?
Re: What da prolem is? IX
Unread postby red5.0fogger » Mon Dec 29, 2014 2:05 pm
was the air filter clogged with something or something blocking airbox inlet?
Premium Member
Unread postby ranga83 » Mon Dec 29, 2014 6:17 pm
Something to do with the fpr?
ranga83
Unread postby decipha » Mon Dec 29, 2014 7:30 pm
nope inlet was upgraded to a magnum powers 4" pipe with 9" cone filter -no probs there
fuel pressure was set at 40psi base which came out to about 30 at idle with 19 in of vac at 700 rpm
there was a slight exhaust leak due to a misaligned exhaust hack job due to the mid length headers, i cut it realigned it and welded it sealed no probs there
also, bank2 was consistently about 13% leaner than bank1 across the board (+1.13 kamrf2), reading the plugs revealed that bank was actually running rich, I found that the previous owner had tapped in a narrowband air/fuel ratio gauge, I removed the gauge and that fuel trim went back to 0
Unread postby YaBoyHalle » Mon Dec 29, 2014 11:05 pm
spark "blowout?" platinum is not am amazing conductor...
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Tue Dec 30, 2014 7:11 am
thats what is was doing but the question is why
the double plats are the preferred plugs for boost
Unread postby red5.0fogger » Tue Dec 30, 2014 8:22 am
Coil going bad or bad ground to coil. ground wire missing from back of engine?
Premium Member
Unread postby decipha » Tue Dec 30, 2014 3:35 pm
I swapped the coil with one of my other supercoupes and the misfire was still there but not as bad
theres a twist to it though
Unread postby red5.0fogger » Wed Dec 31, 2014 8:35 am
Is it a partially broken wire to coil that gets better or worse when flexing it such as when you changed it?
Premium Member
Unread postby decipha » Wed Dec 31, 2014 5:07 pm
no wiring is all intact
Unread postby decipha » Wed Dec 31, 2014 5:11 pm
its impossible to figure out so ill just give it up
the coil was bad as well as a new plug wire including an old plug wire too
i found the coil was bad when my red supercoupe started doing the same exact thing after i swapped the coils
eith the good coil on thr black sc it still missed just not as bad, thats when i started checking all the plug wires and found two of them to be bad from the headers heating them up, the same two plug wires were bad on the older set too
stock headers back on it with a new wireset and she made a clean pull up to 15lbs of boost no prob
Unread postby YaBoyHalle » Wed Dec 31, 2014 8:10 pm
i would have figured it out if i got on soon enough! pretty annoying problem though. did you figure out how to put the headers back on without burning them? wire covers?
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Wed Dec 31, 2014 9:00 pm
nah she had wire covers, the headers were ceramic coated too, i gave it another try once after that and it took out two plugs again so i just ditched the headaz
Unread postby YaBoyHalle » Thu Jan 01, 2015 6:49 pm
unfortunate. also, why is the double plat preferable? just for boost?
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Return to Games & Recreation
