E-85 Blow ups
Tuning for alternate fuels such as: CNG / LPG, Ethanol (E-85), Methanol, etc...
E-85 Blow ups
Unread postby red5.0fogger » Mon Jan 18, 2016 1:08 pm
So I was wondering.. If someone gets greedy with E85 and tries too much timing or leaning it out too much what is their reward? burned pistons? Head gaskets? Does e85 detonate at all? If it does ping does it sound the same? I've heard bits here and there that it will still break stuff.
Premium Member
Re: E-85 Blow ups
Unread postby decipha » Mon Jan 18, 2016 1:53 pm
E85 blow ups are usually from over-stressing components so crankshafts snap, pistons break, etc... its no different really than what you would expect with race gas
that rattling detonation pinging noise you hear is the actual piston ring fluttering, an engine detonates when peak cylinder pressure is reached before the optimal fulcrum angle is met so the engine fights itself, something has to give and the weakest link is the piston ring, that noise you hear is the charge making its way past the rings
Re: E-85 Blow ups
Unread postby NxCoupe » Tue Jan 19, 2016 1:08 pm
I have tuned quite a few E85 setups, a lot with high hp, and not one has burned a piston or blown a head gasket that I know of. My 600 rwhp procharged 347 was a stock 302 roller block, lasted for 2 years, driving it hard and beating the snot out of it, but not drag racing it. It didn't even miss a beat. That engine is now been through several hands and rests in an n/a setup stang. It really is a magical fuel, lol.
NxCoupe
Vehicle Information: 2012 5.0 6 spd, on E85, offroad pipe, GT500 mufflers, just started tuning process, gained 40 rwhp over stock so far.
Black with black interior, base model, built shortblock.
SCT Xcal4, using Advantage to tune it.
Vehicle 2 Information: 1992 Mustang Coupe, coyote 5.0, turbo, 5 spd, race car build in progress. Used to run in NMRA Real Street, now building it for NMRA Coyote Modified
Vehicle 3 Information: 1993 Calypso Mustang Coupe, 5.0 no options, strip down coupe. Only has auto and cruise, didn't even come with a radio, lol. Future plans are to put a Windsor with an On3 turbo kit and an AOD with a brake.
Additional Vehicles: 1993 2.3L 5 spd Mustang coupe, future turbo 2.5 build.
Moates chip, BE tuned
GSS340 pump
Spec Stg 3 clutch
V8 T5 with custom input shaft, billet shifter
8.8 rear end with 3.55 gear, 4 wheel disk
V8 front spindles and brakes,
V8 sway bars front and rear
CC plates
FRPP cockpit adjustable shocks and struts. Soft to race with the flip of a switch!
Have 57mm turbo, Stinger header, ebay blow off and waste gate purchased so far.
Re: E-85 Blow ups
Unread postby decipha » Tue Jan 19, 2016 1:12 pm
that means you didnt exceed the limits of your components
I guarantee you go throw 45lbs of boost at it something is gonne give
Re: E-85 Blow ups
Unread postby NxCoupe » Thu Jan 21, 2016 1:02 pm
Yes, but doesn't that apply to Race fuel or 93 oct as well? I took his question as asking if anyone has had a detonation related failure. I may have misspoke if that was not his intention. Any component will fail if it has had enough stress put on it. I look more towards E85 as being a longevity insurance policy as most of the failures I get through my door are from detonation.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Re: E-85 Blow ups
Unread postby decipha » Thu Jan 21, 2016 1:30 pm
that was my fault, I misunderstood your post, my bad pimpin no hard feelings lol
Re: E-85 Blow ups
Unread postby NxCoupe » Fri Jan 22, 2016 9:12 am
lol. cool. I wasn't butt chapped.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Re: E-85 Blow ups
Unread postby JETFAST » Wed Feb 03, 2016 12:41 pm
In my experience, the power falls off. if it's to lean, it doesnt make power, if it's to rich, it doesn't make power. when you have it where it wants to be....it usually wants timing, and lots of it.
JETFAST
Vehicle Information: Horsepower Breader
Return to Alternate Fuel Tuning
cron
